Old 02-12-2012, 12:42 PM
reo11 reo11 is offline
Mein Auto: 1999 E39
Thumbs up $3 Secondary Air System repair
After chasing gremlins related to fault codes P1421 & P1423 for a while now to no avail: (Confirmed air pump was working, replacing the "sponge" filter on top of the air pump, and replacing the check valve off the exhaust manifold), I used the wet finger vacuum check tool and determined that there was not enough vacuum in front of the check valve when the engine was cold - immediately after starting.
I finally traced the vacuum line back from the check valve (pic 1) and noticed a pinhole in the plastic tubing (pic 2). This hole was located right above and between the two O2 sensors. All of the rubber vacuum tubing on this section was dry-rotted, so I replaced the whole length of it. The only difficult parts were getting the old rubber off the nipple under the back of the intake, and finding that sucker again in order to put the new tubing on.
Ok, so overall I spent more than $3 bucks, but the valve and filter were due to be replaced anyway.
ID:	312016   Click image for larger version
Old 02-12-2012, 12:46 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
Nice work! Want to solve my P1421 code? I'll give you $5!
Sent from my ADR6300 using Bimmer App
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 02-12-2012, 02:02 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
On the 540's they dry rot where the tubing plugs into the side of the sec air valve.
Old 02-12-2012, 11:11 PM
JoePH JoePH is offline
Mein Auto: 97 528i
I think they can dryrot everywhere lol. Heat and age. Good job, why pay someone $$$ to run a tiny rubber airline across the engine bay. Was your check valve on the exhaust ok or was it actually bad? Thought about replacing mine or pulling it to test.
Old 02-12-2012, 11:49 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
I never get tired of success stories.
BMW--giving new meaning to the phrase "disposable income."
Old 02-13-2012, 10:25 AM
Blight67 Blight67 is offline
Mein Auto: 2002 530i Sport Pkg
Had you previously replaced the hose? At least on my e39, that area of hose where you have a leak is actually a plastic pipe, which I believe is more resistant to leaks. This is more evident on the realoem diagrams (part #3):
The dryrot issue is worst at the the check valve, presumably due to the high heat. I would think that having the hose close to the exhaust manifold would also accelerate the hose aging.
p1421, p1423, secondary air pump, secondary air system
