Old 02-14-2012, 04:00 PM
brewder brewder is offline
Mein Auto: 2011 328i xDrive
E83 Fog Light Bulb replacement?
I found a DIY and changed out my headlight bulbs to some VisionPlus "white" ones (very nice btw)... I couldn't get the high beam case open so I didn't replace those bulbs just yet.... BUT, anyway... now my fog lights look yellow so I want to replace them with something a little whiter to match the low bulbs..
Is there a DIY for those? Embarassingly enough, I haven't even looked at the fixture before posting this.
//Brew...KCCO
('11 E92 328i xDrive - Deep Sea Blue | '07 E92 328xi - Space Gray)
Old 02-14-2012, 07:02 PM
dyrwlf59 dyrwlf59 is offline
Mein Auto: 2008 BMW X3
It's a piece of cake--just take a phillips head and remove the one screw from the inside middle quadrant of the lens mount. The entire assembly comes right out--unplug the back of the bulb, replace it, re-plug and then seat the assembly back into the mount--replace screw. Done. If it takes you more than 4 minutes per side, you should not own any tools. Instructions are also in your owner's manual----
Old 02-15-2012, 03:52 AM
LOL.. thanks!
//Brew...KCCO
Old 03-19-2014, 01:02 PM
G Wiz G Wiz is offline
Mein Auto: 07 BMW X3
To get to the screw, does the front clear plastic cover come off or slide out?
Or does the bulb/housing need to be accessed from inside the hood?
Old 02-07-2015, 11:12 AM
Palmer85 Palmer85 is offline
Mein Auto: 2009 X3
Another way if you don't want to remove assembly is to go under earth remove 2 screws that hold plastic flap. This gives you access to the bulb. Took 5 min.
Old 02-07-2015, 11:13 AM
Mein Auto: 2009 X3
Underneath
