Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 02-14-2012, 04:11 PM
J.Stainless J.Stainless is offline
Mein Auto: 318i
GM 4speed Tranmissiononl slipping in 3rd
i currently am the owner of a 1998 318i, As topic states i have a problem where my trans only slips in 3rd.i did an oil and filter change using valvoline dex/merc fluid and i still have the problem, i read that these GM transmissions carry a dextron oil,the oil i used passes dextron 3 spec's. Can any1 gave advise as to what may be the problem??? (question) there are 2oil covers under this particular transmission,the large 1 which inside carries the filter and theres a smaller1 just be4 the housin,when i did the oil and filter change i only removed the larger of the two,is any1 familiar with this smaller pan? can any1 gave advise as to why im only slipping in 3rd??
Old 02-26-2012, 09:32 PM
derrellz derrellz is offline
Mein Auto: bmw 1999 528i
i want to know also...
Old 03-01-2012, 03:37 PM
Eazy-E46 Eazy-E46 is offline
Mein Auto: is str8 gangsta
Was it slipping in 3rd before?
4speed transmission, gm transmission, transmission oil change, transmission slippage
