Old 02-15-2012, 07:11 PM
Ggreg Ggreg is offline
Mein Auto: 2002 E66
Dreaded Alternator Bracket Oil Leak
Is there an improved gasket or other sealing method that can be used when fixing the oil leak behind the alternator bracket? The car only has 55K miles, so I would prefer this repair to last a little longer if possible.
Any information about the failure mode for the gasket? Is it brittle, melted, or misformed? It would seem that a gasket made of the correct material would last a long time in this application.
Old 02-15-2012, 09:30 PM
coole65i coole65i is offline
Mein Auto: 2009 F01 SPORT
Take it from a person who's actually taken the time to DIY it. I actually did it on my E60 545i (N62) but the E65 750 (N62N) has the same engine block. Make no mistake about it, the replacement process is a PITA!!! The gasket behind the bracket becomes rock-hard and brittle. Loses its pliability basically and I had to pick it out of the groove. Along with a brand new gasket, I used some Permatex Oil resistant silicone sealer around it to help it along. The stealer will quote you anywhere from $1200 - 1600 to replace the $3.27 gasket. I couldn't swallow that pill thus the reason for me DIY'ing it. Good luck.
Old 02-15-2012, 10:21 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
+1, mine was brittle and extremely hard, and definitely headache to get to.
Sent from my ADR6425LVW using Bimmer App
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 02-15-2012, 11:49 PM
Tarek307's Avatar
Tarek307 Tarek307 is offline
Send a message via MSN to Tarek307
Mein Auto: 911 Carrera S
thats more like a suppository not a pill..lol
Current:
2005 Porsche 911 S
Previous:
2002 Porsche 911 C4S
2009 BMW 650i Coupe
2008 BMW ///M6
2012 Benz C250 AMG
2001 BMW ///M5
2005 Porsche 911S (Launch Edition)
2002 Porsche 911
2004 BMW 745Li
1997 BMW 528i
2004 BMW 530i
Old 02-16-2012, 05:13 AM
allgraph1 allgraph1 is offline
Mein Auto: 2003 745Li
Yeah, I am getting a daily oil leak, too. I guess I will have to take it to an Indy here in Houston. I don't know if I can do it myself.
Old 02-16-2012, 02:37 PM
Mein Auto: 2002 E66
From these responses of the gasket being hard and brittle it sounds like the elastomer doesn't have enough heat resisitance for the application.
It is probably made from Buna-N which is oil resistant and has a temperature range of -40 to 250 F. This is the most common elastomer used for o-ring and gaskets since it is inexpensive.
Not sure what temperature the block is at the point the gasket seals to the block, but it must be higher or right at 250 F.
A silicone or Viton gasket would have been a better choice since it is oil resistant and has a higher temperature rating of 400 F. I going to see if I can find or make a silicone or Viton replacement gasket.
Too bad BMW didn't do this, it would probably have been about $.05 more than the buna-n gasket.
Old 02-16-2012, 06:09 PM
HerbP HerbP is offline
Use the BMW gasket, & just add some extra silicone for good measure. This is a 8 to 10 job, that you only want to do 1 time!
Old 02-16-2012, 06:29 PM
bghubr's Avatar
bghubr bghubr is offline
BMW Driver
Mein Auto: 2011 activehybrid 7
Use permeatex o ring sealant. This is the same as Honda sealant and will make the gasket last forever
2011 Activehybrid 7
2011 535i xDrive
Old 02-16-2012, 07:10 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
Any one have the part # for the gasket I ended up with the wrong one.
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 02-16-2012, 07:46 PM
pkathee's Avatar
pkathee pkathee is offline
Mein Auto: 760 Li
Part #12317512327......Which one did you get?
1) 760Li- Logic7, Rear entert', Rear Climate, Comfort Access, 20" DP Wheels.
2) Lexus LX470- Mark Levinson Video/Audio, 22" Diablo Elite Wheels.
Old 02-16-2012, 07:48 PM
Rookie2008's Avatar
12317507996 Thank you
Old 02-16-2012, 08:09 PM
Mein Auto: 2002 E66
The part number is 12317507807 without oil cooler (GULF VERSION = No (L822A = No)
The part number is 12317507808 with oil cooler (GULF VERSION = Yes (L822A = Yes)
Part #12317512327 is for 760 models
Old 02-16-2012, 08:11 PM
Rookie2008's Avatar
I have a water cooled an NO oil cooled thanks guys
Old 02-16-2012, 08:15 PM
I get this number! 12317507807
http://bmwfans.info/parts/catalog/E6...ounting_parts/
http://parts.bmwofsouthatlanta.com/s...&searchString=
Water cooled
Old 02-17-2012, 03:18 PM
745Li31404 745Li31404 is offline
Mein Auto: 745Li
I saw the you tube video that explains that the gasket is a problem but does not give a DIY about how to gain access, disassemble anf reassemble. Has anyone doen a DIY on the process?
Old 02-17-2012, 05:32 PM
Mein Auto: 2002 E66
Have not found a specific DIY for the alternator bracket oil leak.
The video and this thread http://www.bimmerfest.com/forums/sho...d.php?t=417251 at post 22 and starting again at post 53 give you a pretty good idea on how to accomplish the job.
Old 02-18-2012, 05:55 AM
Mein Auto: 745Li
Good find. A little deeper that I was hoping for but will be very useful if I decide to tackle it on my own. THANKS!
Old 12-09-2012, 02:43 PM
N303CB N303CB is offline
Mein Auto: 745Li
Cool Dreaded Alternator Oil Leak
Can I use a floor jack to lift the engine or do I need an engine hoist? Also, do I need to remove both front engine mount bolts or just the side I am working on?
N303CB
Old 12-10-2012, 09:02 AM
Mein Auto: 745Li
Dreaded Alternator Gasket Leak
Do I need to loosen both front engine mounts to raise the engine enough to get to the alternator mount? Also, can I use a floor jack to raise the engine or do I need an engine hoist?
Old 12-10-2012, 05:33 PM
bayerisheteknik bayerisheteknik is offline
Mein Auto: ...
did mine couple months back...dont need to release both mounts only one and i used floor jack to raise/lower the engine to gain access to rear 2 bolts,take off the wheel so you have easy access...
here is a little video i made before putting it all back together......also i used silicone rtv gasket maker and no leaks of any kind...
Old 12-11-2012, 08:38 AM
Mein Auto: 745Li
Thank you.
Old 12-11-2012, 09:49 AM
Mein Auto: 745Li
Thanks for the video. In the video, you had an o-ring laying around the pulley on the table. What is that o-ring?
Old 12-11-2012, 12:31 PM
Mein Auto: ...
that o-ring was extra that came with alternator,but alternator already had o-ring on it..its used to seal the connection between alternator and alternator housing so its water tight...
Old 01-15-2014, 03:27 PM
chamboko chamboko is online now
sjambok
Mein Auto: 2006 BMW 750 LI
I just took the dreaded bracket off of my 06 750 li and I cracked the top right piece of the bracket taking that top bolt out of the mix, should I put it back like that, just want to get someone elses opinion on this...
Name:	Alternator Bracket.jpg
Old 01-15-2014, 05:18 PM
thunderkyss thunderkyss is offline
Mein Auto: 745Li; 2004
I wouldn't.
I don't know what it could hurt, but... that bracket isn't exactly easy to get to. If it turns out you have to go back in & replace it... I'd hate to go through all that again.
