Old 03-07-2017, 11:04 AM
RealTrapSquid RealTrapSquid is offline
Mein Auto: 2002 BMW 530i E39
Where do these belong?
The guy I bought this car from had one of these inside of the glove box and the other was zip tied to the trim above the pedals. The ziptie broke and it was in the way of my pedals so I had to unplug it. A quick search showed me the one with the bigger label was the nav system and the other was the radio. Does anyone know where these belong? Having it ziptied and in the glove box isnt going to work for me.
ID:	590969Click image for larger version
Sent from my SM-G925V using Bimmerfest mobile app
Old 03-07-2017, 11:13 AM
528iAut 528iAut is online now
Mein Auto: 528i
They are both navigation, you can find the location on realoem.com , I believe the navigation drive belongs in the trunk.
E39 528i Steptronic 1996, Comfort seats, Rear curtain, Oxford Green.
Old 03-07-2017, 02:06 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Ditto above. The 1st pic (ending in 226) is a Nav CPU...the 2nd pic is the "radio" (ending in 213) that is used when you have onBoard navigation option.
Ditto again, the Nav CPU is usually mounted in the left side of the trunk...and so is the "radio" BMW53 (in this case) in the sedans. In the Tourings...the radio is located below the cargo floor.
Since the 11 digit BMW part nbrs a clearly visible...you can input either of those numbers into the part nbr search on any online parts database to find more info about them. And to find which other BMW models may have used the same part:
http://www.realoem.com/bmw/enUS/part...&q=65908368226
http://www.realoem.com/bmw/enUS/part...&q=65126904213
The MK1, MK2, MK3, MK 4 Nav CPU were all located in the same place (but have different part nbrs:
Q {BMW CCA Member #191509}
(SOLD)
