Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 02-16-2012, 05:46 PM
Quarter till 8 Quarter till 8 is offline
Mein Auto: bmw 745i, 535i, 635csi
Harness this problem will ya ?
I'll try to make simply, I swap my 1985 635csi engine(body shot) into my 1986 535i same engine, both 5 speeds, kept wiring on 635 of course, made some minor retrot fits at fuse panel with locations of relays and connections, swap MCU out in glove box adjusted mounting brackets, Stay with me,here the problem,(I think) there is a 4 pin whiite connector(BK, WT/BK,&WT/BK,same pin.GR, and BK with a sleeve) coming off harness where 35 point MCU connects in glove box, on 535 its a 5 pin (BK,GR,WT/BK,GR/YL,GR/BR) ck my Bentley bk and others cannot find diagrams or schematics am I blind in one eye and can't see out the other, when i try to spice, what i thought, it effected my starting figure that out now it starts and keeps on reving up 1500,2000,3000, rpms quick, have to turn it off. ck IAS valve ok, all V hoses and throttle housing,air flow and oxgen sensor is my problem in those two different white connectors (if i knew what and where those wires go I would be writing and tellin how nice that car looks andrun after the swap) if indeed that is the problem, lets make it happen people, give me some inputs Thanks wasn't that simple
Old 02-16-2012, 07:32 PM
catso's Avatar
catso catso is offline
catso
Maybe you can find a helpful diagram here: http://www.bmwtechinfo.com/repair/main/137en/index.htm
![/I][/FONT]
Old 02-18-2012, 05:10 AM
thanks Catso, very helpful
HTML code is Off
