How about a logical answer to a window problem - Page 2 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 02-20-2012, 03:56 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
The auto-up-down feature for the window is not supposed to operate when the door is open.
Also, the computer in control of these things is a giant state machine. The door open part is probably one thing that tells the computer to go to a state where it can re-learn the extreme ends of the window motion. Just a guess. The window auto-ups until it hits something as a safety measure. I doubt it's a sensor involved, but more likely a current regulator. When the motor is pushing the window up and something is in the way, the current draw by the motor will jump, which may trigger it to stop (or in our case move slightly down, for safety!).
Again, just a guess.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 02-20-2012, 04:24 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
My windows will do auto-up/auto-down when the doors are open. They just go to the position they're supposed to be at when the doors are open, and then when you close the door it raises the glass the extra 3/8" or whatever to seal like normal.
1998 BMW 328is
1966 Pontiac GTO
Old 02-20-2012, 09:24 PM
DinanM3e36's Avatar
DinanM3e36 DinanM3e36 is offline
WayTooFastWhitey
Mein Auto: Dinan BMW M3 e36
Mine do too, they go up to the open door spot(lil gap so when the door shuts properly,then auto seal all the way up)
Old 02-21-2012, 12:24 PM
Damorava Damorava is offline
Mein Auto: BMW 316i 1998
Guys, I am new here. I own my first BMW . It is a 316i 1998 Euro. The driver window is suffering a kind of decease called " inching" as per some forums. I must press the button over and over and it only moves 1 inch at time up or down depending on what direction I am trying to put it. So it means that the switch is good and also the motor. I already tried resetting with the door closed and pressing the switch for 10 seconds when the window is up and down. The solution did not worked . Any thoughts ?
Old 02-21-2012, 12:36 PM
ZeGerman's Avatar
Warm Leatherette
If you want to make life easier, just push and hold the button down all they way, and the window will go up without interruption. You may not have noticed that the window switches have two clicks. Pushing it down and holding past the 2nd click will force the window up without stopping.
1998 BMW 328is
1966 Pontiac GTO
Old 02-21-2012, 12:45 PM
DinanM3e36's Avatar
WayTooFastWhitey
To the original OP it almost sounds like something's not lined up right causing the window to stop due to the overload of pushing on a foreign object/outta lined door seal or even outta line upper door frame, just sounds fishy
Edit: of course I could be wrong
Old 02-21-2012, 12:50 PM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
it does? cuz i dont think mine stops... i tried to push down on it a little while it was auto-upping and it didnt stop. maybe i didnt push hard enough?
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 02-21-2012, 12:51 PM
ZeGerman's Avatar
Warm Leatherette
You'd think that, but it's not usually the case. The one-touch up/down glitch is high common and is often times not the result of a bad regulator.
1998 BMW 328is
1966 Pontiac GTO
Old 02-21-2012, 12:58 PM
window inching problem
I did that already several times. For sure I know that the window works. has two clicks. i pushed it down and it passed the second one. I holded the switch there for 10s but any ways the window just travel 1 inch at time in any direction, does not matters if I hold the button.
Old 02-21-2012, 01:40 PM
DinanM3e36's Avatar
WayTooFastWhitey
Karl...?
Old 02-21-2012, 02:13 PM
ZeGerman's Avatar
Warm Leatherette
'Sup?
1998 BMW 328is
1966 Pontiac GTO
Old 02-21-2012, 05:44 PM
DinanM3e36's Avatar
WayTooFastWhitey
'Sup?
Might have some info on the post above
Old 02-21-2012, 05:50 PM
DinanM3e36's Avatar
WayTooFastWhitey
Man I've had tons of problems with e36 windows but usually I solved them with replacing the plastic slides, or even as simple as disconnecting the battery and reconnecting/ resetting the relays,
Old 08-31-2012, 07:44 PM
help needed with driver windows
Guys
I have a problem with my driver window. my is a BMW 1998 316i EURO.
I have tried almost everything possible at the door.
I tried resetting the relays by pressing the button during 15 seconds, I check the regulator and it is OK, took of the door panel and I tried opening the motor and moving the magnet back to its "original position" and even I removed the motor out of its position to check it by itself. By having the motor in my hand and connected to the power, it behave the same. It just make a couple of turns. Also, I swap the windows switch and put the right one instead but the same behavior
So, for sure the regulator is ok and also the motor, as well as the windows switch.
I need another solution.
Old 08-31-2012, 08:12 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Explain "make a couple of turns"? Is that all it will do with power jumped directly to the motor? It should continue to run as long as there's power to it if it's not meshed with the regulator gear. If it only makes a couple revolutions and stops, the motor is NOT ok.
Thanks for searching! Welcome to the fest!
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 08-31-2012, 08:52 PM
thanks for the quick reply.
Basically it turns a couple of time every time I press the windows button. even if i keep the button down all the time.
I went to a seller this afternoon and they lend me another motor. I plug it to the power connectors at my car and guess what: same behavior. That was the reason I thing is it not exactly the motor.
Old 08-31-2012, 08:57 PM
D'oh, You Kids!
Ah-ha! OK, find your comfort relay and replace it. It should be under the dash...location varies with year. Look it up on Realoem.com
Quotes to live by:
BMW-CCA #441426
Old 08-31-2012, 09:14 PM
Great.. let me try that. I'll let u know the outcome.
Thanks again.
Old 01-31-2013, 08:48 AM
Still with the window problem
Hi there.
I still have the issue with my driver window.
My car does not have comfort relay. Windows are controlled by ZKE module but according to another forum, that it unlikely the issue.
Any other guess?
Old 02-01-2013, 12:24 PM
redE36girl redE36girl is offline
Mein Auto: 1993 E36
Could also be a issue with the switch.
Sent from my SGH-T769 using Bimmer App
1993 BMW 325i
1990 VW passat wagon
1987 jeep(AMC) cherokee
1979 VW westy rabbit 4 door
Old 02-01-2013, 12:33 PM
switch
Switch already tested. Same thing.
Old 02-01-2013, 12:51 PM
Mein Auto: 1993 E36
could the track be off on that window.
1993 BMW 325i
Old 02-01-2013, 12:53 PM
Please give me more details
Old 02-01-2013, 01:13 PM
Mein Auto: 1993 E36
if the regulator bushings are failing it will cause the window to move hence it getting off track.
here is a DYI on how to fix the issue yes its on a coupe but the fundamentals should be the same for any other E36.
http://www.dvatp.com/bmw/diy/power_window/
1993 BMW 325i
Old 02-01-2013, 01:27 PM
nice link. let me go through it and see if I can fix the problem. thank you
drivers, e36, regulator, switch, window
