Old 02-23-2012, 07:46 AM
blackandcoke's Avatar
blackandcoke blackandcoke is offline
New York
Mein Auto: 528IA
Recommended swaybar links for lowering suspension
I have a 2000 528i and in the process of ordering my H&R SPORT SPRINGS and BILSTEIN SPORT STRUTS. Since this is such a popular set which swaybar (links) should I buy?
Old 02-23-2012, 07:58 AM
blz456's Avatar
blz456 blz456 is offline
Mein Auto: 2000 528i
I personally would stick with the OEM ones.
2000 528i steptronic
Blacked out
Old 02-23-2012, 08:01 AM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
Here's a really good topic from Graham on Mason Engineering's adjustable end links.
It's a good read.
Old 02-23-2012, 08:26 AM
Albo's Avatar
Albo Albo is offline
Der Ursprüngliche....Albo
Mein Auto: OO=[][]=OO
That is incorrect... on any lowered application, the OEM endlinks apply too much preload to the sway bar. The correct thing to do is install adjustable endlinks like these:
http://www.turnermotorsport.com/p-21...inks-pair.aspx
or these (as AnotherGeezer's link shows):
http://www.masonengineering.net/Subp...W_Products.htm
or here (powergridinc makes good stuff...they sell e39 adjustable links in their ebay store):
http://www.powergridinc.com/swaybar.asp
2003 530i (Alpine White/Sand Beige) - 18x8.5 & 18x9.5 ACS Type II Wheels - BC Racing Coilovers - Eibach Sway Bars - Beastpower Sway Bar Brackets - M-Technic Replica Bumpers - Slimmbones CSL-Style Spltters - Magnaflow Muffler - Dinan CAI - TopSpeed Performance Strut Brace - Carbon Fiber Valve Cover Fascias - Zionsville Autosport Radiator/Fan Kit - Revmax Stage II Torque Converter - AMG Paddle Shifters
Old 02-23-2012, 08:58 AM
blz456's Avatar
I did not know that! Ya learn somethin new everyday!
Blacked out
Old 02-23-2012, 09:04 AM
Albo's Avatar
Daily occurence for me too... I'm going to get some adjustable links when I upgrade my sway bars this summer.
Old 02-23-2012, 10:34 AM
blz456's Avatar
Yeah it makes life interesting for sure! And now that I know this I might look into it myself as my car is lowered.
Blacked out
Old 02-24-2012, 03:57 AM
StreetPro StreetPro is offline
Mein Auto: 530iA & Prado
I run Eibach 27mm front and M5 oem rear, perfect combination for me... I do not see any reason to buy shorter links unless you go deeper than 50mm (which I would doubt to call it a benefitial anyways)...
Old 02-24-2012, 04:43 AM
Entwicklung 39
I think the recommendation is to only use the front pair and those must be longer than stock to accommodate a drop. Seems like the rears are not required.
Could be wrong though.
Old 02-24-2012, 09:06 AM
Albo's Avatar
I think the greater problem is that there is a lack of adjustable rear links available:
CORRECTION: The rear endlinks the link below are not ADJUSTABLE...they are simply just SEXY!
I've found one example of a set made by an outfit called LI-Customs...
See here:
http://www.m5board.com/vbulletin/e39...-brackets.html
Website = www.Li-Customs.com.
In theory, an drop in height (front or rear) should require an increase in endlink length, but many people forgoe the rear links.
...and to be clear... 50mm...or nearly two inches in our parlance...is not a trivial amount. A two inch increase will cause the front sway bar to pivot upwards by a commensurate amount. A longer endlink is definitely need to compensate.
Here is neat little discussion about the topic with a nice pic that will let you visualize the problem:
http://www.m5board.com/vbulletin/e39...end-links.html
Old 02-24-2012, 01:20 PM
Entwicklung 39
The Heim joints would tend to handle the offset load a lot better than the fixed point stock part would.
Old 02-24-2012, 01:42 PM
Albo's Avatar
True..and after reading through Graham's post, it does make sense that the rear link is thrown less out of whack by a negative change in ride height.
Old 02-24-2012, 01:45 PM
Entwicklung 39
I'll be getting a set once I slap on the Vogtlands.
