Old 01-21-2012, 11:34 AM
jclanin jclanin is offline
Mein Auto: 2003 540i 6 Speed
Water in drivers side floorboard - 2nd row
Hi all,
We've had a ton of rain in Atlanta the past 24 hours. My car has been parked outside and now has very saturated rear floorboard (drivers side). I assume I have a clogged rain gutter -- or something of the sort. Any ideas?
thanks!
JC
2003 540i 6 Speed, 35% Formula One Pinnacle Series Ceramic Tint, Saphire Black Metallic exterior, Black interior, 66K, Sunshades, M5 rear sway bar, shadow black grill, bluetooth, led interior lighting
Old 01-21-2012, 11:51 AM
pleiades pleiades is offline
Mein Auto: '99 5-spd
One possible cause is a loose/broken seal (butyl sealant) holding the insulative foam vapor barrier that's under/behind the interior panel of your rear passenger door. If it's that, it's very easy to fix. You'll need some butyl cord/tape or similar butyl based sealant to reattach the foam barrier. Check around here for threads on vapor barrier or vapor seal repair and how to pop off the interior door panel (one philips screw, 10 or so plastic clips).
Old 01-21-2012, 12:11 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Although I've been fortunate not to have experienced this problem myself, I've read enough posts on this board to recognize it as a classic sign of failure of the vapor barrier seal, as Pleiades described above. There are numerous DIY links, with photos, in the "very best links" thread at the top of the main page of this E39 board.
BMW--giving new meaning to the phrase "disposable income."
Old 12-15-2012, 09:09 AM
Rwelkins Rwelkins is offline
Mein Auto: 525i
I had the same problem, and agree that you should reseal the vapor barriers on the rear doors. I highly recommend doing both sides......the other one will fail too.
Old 12-15-2012, 11:23 AM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Like others have said, chances are it's the vapor barrier. It's an easy fix if you're handy. If it then still leaks, you may have a broken or detached hose on the sun roof drain...which is a pain to fix.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 12-15-2012, 11:25 AM
Tommylaw9 Tommylaw9 is offline
Boss Hogg
Mein Auto: 2001 530i
I just did the vapor barrier this week. holler at me and i can give you a little better insight that a guide might be able to. (while its still fresh in my head)
2001 Schiefergrün 530iA M-Sport Package
Old 12-15-2012, 12:11 PM
Type /vapor barrier F3 in the bestlinks and this comes up, among others:
- Vapor barriers: Sealant for door panel vapor barriers (1) & sizes for the adhesive (1)
