Old 02-25-2012, 09:16 AM
rumbleM3 rumbleM3 is offline
Mein Auto: E92 335i
I'll pass 328i until they fix the turbo lag problem
Just went and test drove the F30 328i and noticed quite a bit of turbo lag at WOT compared to a 335i. This is the same problem they had when the first E90 335i came out. Did anyone else get the same assessment? I'll pass the 328i until they fix this turbo lag and get rid of the requirement to purchase premium package for a xenon headlight option.
Old 02-25-2012, 09:43 AM
Carlos Thomas Carlos Thomas is offline
Mein Auto: 2012 BMW 328i Sport
Drive in Sport mode.
Old 02-25-2012, 10:10 AM
justinnum1's Avatar
justinnum1 justinnum1 is offline
Mein Auto: F30 335i mSport
For real.
Old 02-25-2012, 10:52 AM
westwest888's Avatar
westwest888 westwest888 is offline
Banned
Mein Auto: 2010 Audi S4
Audi 1.8T had bad turbo lag. Took them a while to nail it with the 2.0T. People still complain the transmission is laggy in the regular A4.
The easy way to solve that is to overcome the marketing, do what your heart tells you, and get the 6 speed manual. I'm sure the 328i is quite good with a manual.
Old 02-25-2012, 11:56 AM
7or8 7or8 is offline
Mein Auto: '09 335i msport
Originally Posted by westwest888 View Post
The easy way to solve that is to overcome the marketing, do what your heart tells you, and get the 6 speed manual....
True that.
Old 02-25-2012, 12:02 PM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
Originally Posted by 7or8 View Post
True that.
+1 the only transmission the n20 in the 328i should be sold with.
Old 02-25-2012, 03:09 PM
Mein Auto: E92 335i
That's not normal if I have to switch to sport mode. Initially, E90 335i had the turbo lag in standard mode but not in sport mode also but that does not make it right. After some major complaints BMW fixed the 335i turbo lag even in the standard mode.
Old 02-25-2012, 03:24 PM
justinnum1's Avatar
Yes it is normal. If you are in comofort or eco mode you will not get the full performance. IF you put it in sport(not talking about DS) but toggle to sport(or sport+) and turbo lag is hardly discernible. Its not so much the lag your feeling as much the engine is just not going full power(if that makes sense) in comfort or eco. At first i didnt like the toggle switch, coming from N54, i was used to just getting in and going. But i like being able to switch between comfort, eco, and sport. On a long highway drive, eco saves you some gas. But when i need to be aggressive i can just switch it sport and pass everyone
Also, coming from 2 N54's, i dont think N20 has any more or less lag.
Old 02-25-2012, 06:26 PM
johnc_22's Avatar
johnc_22 johnc_22 is offline
Squeal like a BMW
Mein Auto: 2013 Audi A4
The E90 328i, when not in DS (sport mode), would start in 2nd gear and was very sluggish off the line unless you punched it.
2013 Audi A4 - Premium+/Sport/MMI/B+O Audio
2007 BMW E90 335i (retired)
Old 02-25-2012, 06:49 PM
tkeonce tkeonce is offline
Mein Auto: 2011 328xi Jet Black
I don't think you will find this car to have much lag when driven in the "Sport" setting. As others referenced this is not popping the steptronic shifter over to m/s. The 328i modern or luxury line has 3 modes eco, comfort and sport. The sport line has the sport + mode added. It's like having 4 cars in 1. It sounds like you were sent out on a test drive without a client advisor giving you a good walk around on the car. Give it another shot and try the car in all 3/4 modes. IMO this car blows away anything else in it's class and will be a worthy successor to an already great car.
Old 02-26-2012, 01:16 PM
jmatero jmatero is offline
Mein Auto: 2015 i3 REX
This car with the manual in Sport mode has little-no turbo lag. If you're in the Bay area, there is a 328i Manual at Stevens Creek BMW in San Jose. The difference in feel over the 8-speed is NIGHT and DAY.
Old 02-26-2012, 01:45 PM
raleedy's Avatar
raleedy raleedy is offline
Mein Auto: 2016 228i 6-speed
1. All turbo engines have some degree of turbo lag. It's inherent in the very concept of an exhaust-powered turbine.
2. It will be more, rather than less, noticeable with a manual transmission than with an automatic. This is because normal manual shifts-up or down--involve momentary loss of rpms and because power development is not linear.
Old 02-26-2012, 01:46 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
If it is like the E9X the real fix will come from Burger Tuning. It is easy to mistake the throttle mapping for a turbo lag.
Old 02-27-2012, 10:10 AM
AK AK is offline
Button Pusher
Send a message via Yahoo to AK
Mein Auto: '10 C2S, '04 4Runner
Why would the car have any less turbo lag in Sport mode? Throttle calibration software tricks can't overcome physics. It will always take X amount of time to spool up a turbocharger to a set boost level. Since the N20 runs more boost than the N54/N55 it would make sense that there's more perceived turbo lag. It takes longer to spool up to ~18psi than it does to ~8-9psi.
Disclaimer: I've not yet driven a car with the N20 motor.
Old 02-27-2012, 10:25 AM
justinnum1's Avatar
Its not that there is less lag in sport, but it might feel more laggy in comfort and eco....if that makes sense.
Old 02-27-2012, 10:29 AM
soledoc soledoc is offline
Mein Auto: '09 328i sedan, '02 525iT
Agreed. That's what I just ordered. Tell that to the dealerships...they only stock automatics.
2015 BMW 428i M sport coupe, estoril blue/venetian beige sensa tec, manual trans, DHP, cold weather (European Deliver 3.28.15)
2016 BMW 528i sedan dark graphite/beige (european del 11/15)-wife's first BMW
2012 BMW 328i sport line, imperial blue/black with red/6MT,xenon, cold weather and premium, variable steering
(PCD)
2007 BMW 530xi wagon green/beige, sport, premium, cold weather
2002 BMW 525i topaz blue wagon (sold)
2009 BMW 328i montego blue sedan (european delivery 2009, turned in)
Old 02-27-2012, 10:30 AM
AK AK is offline
Button Pusher
I really hate all this throttle remapping stuff. It all seemed to start with the advent of drive-by-wire throttle. IMHO, the throttle opening should track your right foot exactly with no curve remapping. I actually dislike putting my 335i in "DS" mode for this reason; the throttle becomes too sensitive. There's no need for it.
Old 02-27-2012, 10:37 AM
justinnum1's Avatar
Its all good, i like that i can put it in eco mode and save gas, but when i need sport, i can get it.
Old 02-27-2012, 06:01 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
The easy way to solve that is to overcome the marketing, do what your heart tells you, and get the 6 speed manual. l.
they don't make manual car anymore
you have to special order
and you may get a dodgy manual gearbox like what lexus did to IS250... they put Hilux gearbox in
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 02-27-2012, 06:05 PM
justinnum1's Avatar
huh? bmw manuals are great, i dont like how much the clutch goes in after it catches, but you can def get a bmw manual. But the zf8 is awesome
Old 02-27-2012, 06:37 PM
malc410326 malc410326 is offline
Mein Auto: '12 MB SLK 350 & BMW 328i
So very true....3 cars in 1 or I think in your case, you have 4 cars in 1, since you have the additional sport+ mode.
Old 02-27-2012, 06:49 PM
justinnum1's Avatar
you do to kind of, just put it in sport and press the traction button once and thats pretty much all sport+ is.
Old 02-27-2012, 08:09 PM
krafty81 krafty81 is offline
Mein Auto: Acura MDX
Does the base mode (not sport/lux/modern) have three driving modes as well (sport, comfort, eco)? Thanks.
Old 02-27-2012, 08:13 PM
justinnum1's Avatar
yea
Old 02-27-2012, 09:34 PM
This is interesting. Makes sense. But why is it that a manual feels less laggy? Is it the torque convertor in an AT vs a MT that is causing the delay?
