E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
I have a 03' BMW 330i been having lots of problems but the worst one is when I turn the key to start it and push the clutch in I turn to acc gets power fuel pump turns on, then I turn the start it starter relay clicks on and doesn't turn over. I'm starting to think its the starter solinoid. Can anyone help
It can be multiple things
first test the battery (free at any Autozone) mentioned that the fuel pump works so we can rule that out you can give the starter solenoid a decent tap and see if that help if none of the above work it can multiple things like key, ignition switch, clutch switch etc.. a little more info would help us festers' help you better diagnose
We never really grow up; we only learn how to act in public. -unknown I like Chile Verde Burritos |
Also it will sometimes start if I hold it in the start position for while. Sometimes. Or keep turning key repeated time. It takes half hour or more. Idk if that matter
How old is your battery ? If it`s over 4 years old, or you don`t know, replacing it with a new one ($100 at Walmart or Autozone) will likely solve your problem. Buy a battery terminal cleaning tool, and clean ALL cable connections, making especially sure the ground to the car`s chassis is clean & tight.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
Shop says to check fuse 12 check ground from chassis to subframe, battery is good they did a VAP 40 and it passed.
They also said it could be a 530 starting problem. Anyone know what that is??? They also said try unplugging the MAF so what's that??? Need help baddly
"VAP 40 is a test for *your cholesterol level* ![]() "VAT 40" is a battery test....do you know what kind of a load they placed on the battery ?
I do not but I could ask. And it's been a while since I last had a change to test the battery coulda swore it was VAP lol well my mistake.
| Bookmarks |
| Tags |
| starter, starter problem, won't crank |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
