E36 (1991 - 1999)
Old 02-27-2012, 11:51 AM
JustRich JustRich is offline
Send a message via MSN to JustRich
Mein Auto: 318ti
Heater Control Problem
Hi guys. this is my first post.... ive just ran out of suggestions from other sites ive combed through in the last few months...I drive a 96 318ti. it had overheated and owner replaced thermostat and water pump as well as new radiator. but no heat. i checked the heater core its not leaking and both pipes going in and out of it are cold. it seems like the both the inlet and outlet hoses into the heater valve are cold as well or maybe ive got to wait longer than 10 min to keep checking? even after the temp reaches 12 o clock. unless i run the car for about 15 mintues then well everything gets hot. the car doesnt overheat and has no coolant leaks and ive tried bleeding it just in case there was air in the system. i checked the bowden cable behind the heater knob nd everything is intact. the outlet hose from the waterpump is hot n i believe its the house that circles the block into the heater valve coolant level is perfect.. ive tried a rebooting knob step which i read in a earlier post but nothing. I really dont want to put in someting like a heater core or heater valve if i dont have to and thatd be blindly throwing money but im tired of arriving at work and having no feeling in my toes :/ thansk guys any suggestions would be appreciated and done P.s My Email is arachnodude@hotmail.com
Old 02-27-2012, 01:56 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Search for 'bleeding an e36'.
My email is 2lazy2search@gmail.com. <--Yes, this is a real email. I just finished making it
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-27-2012, 04:27 PM
Mein Auto: 318ti
K.. Tried bleeding it again and nothing new. I'm wondering though if it could be a bad heater valve...? Also was thinking of that happens to be the problem would replacing it without flushing the heater core cause problems or is flushing it out of whatever is in it the best idea? Air or water? I can feel the slight change in temperature when I turn the heater knob from cold to hot cold on cold and slightly mild cold on hot but no hot air from anywhere
coolant, heater, knob, radiator
