E46 (1999 - 2006)
Old 01-23-2013, 01:31 AM
SamxK SamxK is offline
Mein Auto: BMW 330i 2001
Exclamation Possible oil leak/seepage under corner of engine
I own a 2001 330i with 95k and love it, just like you guys
However, I've recently (about 1.5 weeks ago) noticed an oil leakage right beneath the bottom left corner of the engine. It seems odd because around the leak seems to be electrical connectors.
I've attached pictures (my key is pointing at the location) Sorry pictures seem to be rotated. However, the front end of the car is on the right side. This is at the lower left of the hood of the car.
Anyways, any suggestions in defining the problem? All help and time devoted to help me is greatly appreciated. And here's a "thank you" beforehand. Thank you.
ID:	358862   Click image for larger version
Old 01-23-2013, 01:56 AM
heztheone heztheone is online now
Mein Auto: 330i ZHP M/T
it seems u have a VCG leak or the CPS has a failing O-ring.
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
Old 01-23-2013, 02:10 AM
I actually believe I might have a vacuum leak because my car idles roughly at times, especially when cold. And SES is on with lean bank 1 and 2. Does this have anything to do with it?
Old 01-23-2013, 03:05 AM
nope not related.
Old 01-23-2013, 06:24 AM
joegr joegr is offline
Mein Auto: 2002 325i
Originally Posted by SamxK View Post
... I've recently (about 1.5 weeks ago) noticed an oil leakage right beneath the bottom left corner of the engine. ...
To reduce confusion, the correct way to describe the location you are pointing to is the front, right side of the engine at the top.
With a car, right is always to your right when you are sitting in the car facing forward. If you are in front of the car looking back at it, the right side of the car will be to your left.
Old 01-23-2013, 08:08 AM
tcphoto tcphoto is offline
Mein Auto: '01 325Cic TiAg
I would pull the Camshaft Position Sensor and install a new O Ring, it appears to be leaking.
Old 01-23-2013, 09:12 AM
We covered all the o-rings you may need for an M54 over here:
- Let's create a list of o-rings (by size & by part number) to buy when ordering parts
Excerpt below:
Originally Posted by doru View Post
CPS to engine O-ring p/n 12141748398 (Item #9)
CPS O-ring (Intake & exhaust) p/n 12141748398 (Item #6)
EDIT: M54 CPS locations are in this thread.
Old 01-23-2013, 04:41 PM
Thank you for this information. I will remember the next time I locate something.
So it seems like I have a worn exhaust side CPS O-ring. would replacing that be difficult?
I took a look and it seems like space is very limited around that area
Old 01-23-2013, 05:53 PM
Scottji's Avatar
Scottji Scottji is offline
Mein Auto: 2004 325i
Looks like CPS o-ring, but just as an alternative, could be seeping from an electrical connector itself. It's been known to happen. Ask me how I know...
http://www.bimmerfest.com/forums/sho...d.php?t=569509
Old 01-23-2013, 07:01 PM
There are multiple videos posted on YouTube and I found them very helpful before I replaced both exhaust and intake sensors. It makes it much easier to do the exhaust side when you remove the mechanical fan and shroud. It only takes a 5mm Allen wrench and BMW recommends a new fastener and o ring when doing the sensor. I saw a thread that talked about oil leaking through the sensors connector, I would find it, read it and compare to your vehicle.
Old 01-24-2013, 01:23 AM
Smile
Thanks for your help. I've looked on YouTube to find out how to remove the Exhaust CPS in order to replace the O-Ring and couldn't find any helpful DIY videos. May I request that you provide me with a link for one? Having to remove the fan and all that seems complicated and I would like to know the big idea of what I'll be doing before I order the parts and start. That would be great if you could. Thank you
Old 01-24-2013, 01:30 AM
[QUOTE=bluebee;7332243]We covered all the o-rings you may need for an M54 over here:
Wow awesome, thank you for pointing out the part and a possible solution to my problem! With the four pictures you provided, can I say that I have an Exhaust CPS O-Ring failure? I only understood one of the pictures. We're the pictures pointing out the different CPS's?
Old 01-24-2013, 05:55 AM
Yesterday, I clarified (and colorized) the realoem diagrams in that M54 engine thread - but you might not have seen it yet.
Old 01-24-2013, 06:03 AM
All the o-rings in the above post look like this:
And, here's the original pictures of this thread, as used in that o-ring thread:
Old 01-24-2013, 09:27 AM
gesoffen gesoffen is offline
Mein Auto: 2001 325iT - Sienna Rot
If it is indeed a CPS or VCG leak, they could indeed be related. Anything leaking oil out can easily let air in. Any difference in air volume between what is measured at the MAF and O2 sensors can trigger SES codes.
----Brian
oil leak
