Old 02-27-2012, 06:13 PM
lekitoa lekitoa is offline
Mein Auto: 2004 745Li
car jerking, transmission failsafe on and engine service light on
First and foremost, I would like to say that I really like the 745Li I have. It looks great and runs awesome! but it sure gives me a headache when something weird happens to it. I've had my share of sorrows and they do weight heavier than the good counterparts. If I had known id be so difficult to asses any internal damage to this car, I would not have bought it.
Y
I need advice and help to see if this has happened to anyone. These are the specifics:
1) I have a 2004 745Li, with 109K miles now and I am the third owner.
2) saturday at 12:00pm the car jerked while driving in a small street. it jerked me forward when shifting to 2nd gear (i believe) then again right after that. it was a rather abrupt jerk that felt like it moved me forward very fast. I pulled over, turned off the car, waited a minute or two then turned it on again and moved forward.
2) sat afternoon: did the jerking thing again, but not as hard. i took the same actions.
3) sat night: drove around town and even went up a hill or two, and in freeway, but did not have a single problem.
4) sunday: drove on and off without a single problem.
5) Sunday night: I was picking my little sister and car did the same abrupt jerk, then again as in Sunday. I was going to pull over, but the message board said "transmission failsafe on, drive moderately" almost as soon as I was going to pull over. I did pull over, turned it off and turned it on again. Car went back to normal and then same issue happened. This problem happened on and off about 5 times, but drove the car slowly home since i was not far away. when i got home the transmission failsafe light didnt come on anymore, but instead it had something about a "emissions problem"
6) Sunday night: checked all fluids and seemed fine.
7) Monday morning: turned car on and just had the "service engine soon" light on
8) Monday morning: called triple AAA and had the car towed to a trusted mechanic.
9) Monday morning: called mechanic at 4pm and he said he drove it around and found no problem. He asked for more time to keep checking it.
10) Monday afternoon typing this: Personally feeling sad and lost becuase I cant find out what it is and fear that it will be a tranny issue
Old 02-27-2012, 06:34 PM
Catanzaro Catanzaro is offline
Mein Auto: 2004 BMW 745Li
Take a look @ PDF, Do not know if this will help. Go to this website and turn to PDF, please read over. Can not guarantee but worked for me.
http://www.bmwtis.com/tsb/bulletins/...p/B241707g.htm
Old 02-27-2012, 06:41 PM
collins912's Avatar
collins912 collins912 is offline
Mein Auto: 745i; 750Li; Yukon Denali
Sounds like you need to change out your tranny fluid, spark plugs, and your cats might be clogged as well.
Old 02-28-2012, 08:27 AM
alex0404 alex0404 is offline
Mein Auto: 2002 745i
Its electrical. it has nothing to do with fluids.
First check the integrated supply module. ( located under the hood/ passenger side, under the micro filter) Part is about $120, very easy to install.
http://www.realoem.com/bmw/showparts...=12&fg=35&hl=1
Then check the power Module (make sure theres no corrosion in the contacts) located in the trunk by the battery)
part is about $500-$550 requires coding.
http://www.realoem.com/bmw/showparts...=61&fg=25&hl=5
2002 745i
Old 01-14-2013, 09:41 PM
Roberto Gonzale Roberto Gonzale is offline
Mein Auto: 2004 bmw 745 li
I am having this same problem...can anyone help?
Old 01-15-2013, 07:11 AM
7Figurez's Avatar
7Figurez 7Figurez is offline
Mein Auto: 2005 745I
Look at this thread :P
http://www.bimmerfest.com/forums/sho...d.php?t=669900
Old 02-20-2013, 09:24 PM
blockhead702 blockhead702 is offline
Mein Auto: 740il
I have a 1996 740 IL. how do you change transmission fluid. I'm getting rough shifting and grinding noise at startup. please help cause I love this car.
emissions problem, jerk, jerking, service engine soon, transmission
