Old 06-16-2015, 09:55 AM
elimitchellbmw elimitchellbmw is offline
Mein Auto: e60 545i sport
Oil in coolant, no coolant in oil.
I've looked everywhere for some ideas. No luck.. So here we are! I checked my coolant yesterday because the light came on, it does about once a week, lost a gasket for the pipe that connects to the bottom of the coolant expansion tank. It drips out of there. Last week when I topped it off I saw no problems, yesterday when I opened it, it was this milky mayonnaise looking substance all in the tank and on the lid. I drained the radiator and flushed it and filled it with fresh distilled water.. Checked it today at work and it looks like chocolate milk. I replaced my alternator three days ago and two days ago noticed jerky acceleration/ transmission between 1000-2000 RPMs. Nowhere else. No smoke no other symptoms, brand new battery and voltage regulator relay in the trunk. Brand new water pump and belts, coolant transfer pipe job done 3000 miles ago. What's going on? Cracked head? Leaking somewhere? 2004 545i n62 v8, auto 123k miles.
Old 06-16-2015, 09:58 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Check oil filter housing gasket.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 06-16-2015, 10:07 AM
I would need to drain the oil to check that right?
Old 06-16-2015, 10:49 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
No, you don't need to drain oil to check/replace oil filter housing. You will loose just a littlebit of oil when remove the oil filter housing.
Old 06-16-2015, 10:52 AM
You also loose coolant if you do not clamp the hoses.
Old 06-16-2015, 11:34 AM
All hoses are clamped, it's leaking from that one spot and I have no idea where to get a new gasket for that one hose specifically. I will jack the car up tonight after work and see if I can spot any problems... But what should I even be looking for when I remove it?
Old 06-24-2015, 10:00 AM
Bump
Old 06-24-2015, 10:01 AM
The radiator is pumping out clean antifreeze while the coolant in the tank is still chocolate milk looking? Not losing oil or coolant, not running rough except a jerky acceleration between 1000-2000 RPMs and no smoke. Ideas?
Old 07-06-2015, 06:14 AM
Checked the oil filter, there is oil leaking from that location. What next?
Old 08-31-2015, 04:22 PM
leviq leviq is offline
E60 Beast Mode
Mein Auto: 2008 535i JB3
Hey buddy, I agree with fdriller9, go ahead and replace your oil housing gaskets--should be two, at least one of which is for your oil cooler (the oil is cooled by coolant). At least some will crack, start to gunk up with dirt, etc. It sounds like you've got oil in the coolant system. Read up on this forum and you'll find oil leaks are common from oil filter housing (OFH) gaskets.
Here's a video to give you an idea of what might be going on:
Old 08-31-2015, 04:46 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
We recently had a guy who got oil in his coolant -- but it was transmission oil.
Couldn't figure out why his engine oil was clean.
Check the transmission fluid loop. In his case, he got a leak between the tranny oil cooler and the radiator.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
Old 09-09-2015, 06:00 PM
E60 Beast Mode
Do any other BMW engines have issues with their gaskets I wonder, past or present?
