Old 05-22-2017, 11:55 AM
E60_Kalembu E60_Kalembu is offline
Mein Auto:
Dynamic Drive Malfunction
Need some help guys. This comes on once in while, dont knw y.
2010 550i M package.
Old 05-24-2017, 09:36 PM
SingerLin SingerLin is offline
Mein Auto: 2004 545i
Does it go away after restart(s)? It could be caused by a low hydraulic fluid, check your fluid level. Or it could also be the early sign of a weak battery. I have seen it occasionally on my car.
Old 05-24-2017, 10:12 PM
H F H F is offline
Mein Auto: 2005 545i
I agree , its probably low fluid .
Old 05-24-2017, 10:21 PM
Good to see you again, H F.
Old 05-25-2017, 06:25 AM
NedB NedB is offline
Mein Auto: 550i
And that is power steering fluid, as that is used by the active roll bars also. Use whatever the cap says - probably Pentosin CHF 11S.
Old 05-25-2017, 11:58 AM
H F H F is offline
Yup , you are correct . Top it off with the engine cold ..
Old 05-25-2017, 11:59 AM
H F H F is offline
Same here ,,
Old 05-26-2017, 07:24 AM
Mein Auto:
Yes it does reset once i restart the car, kk i will definitely check the power steering fluid!...Thanks guys!
