Old 02-28-2012, 12:53 PM
clspruiell clspruiell is offline
Mein Auto: BMW 335i
335i Engine Overheat went into limp mode
I'd been driving about 20 minutes in traffic and interstate. Car lost all power but was running fine. It sounded like I could hear a cooling fan really rev up. Warning messages started flashing telling me the engine was overheating and to stop the car etc. So I did for a min or two. Cranked back up, still loss of power, then zero power.
Here's the thing, the engine temp needle was around 240 degrees which should NOT be overheated. That's not even halfway.
Heard of this one before? I pray my dealership has a loaner.
Old 02-28-2012, 01:16 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
thats the engine oil temp.
when the relay for my fan went, my car shut down to protect the engine with the needle in the middle.
my guess would be water pump or a sensor issue.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 02-28-2012, 01:23 PM
YVR CANUCK YVR CANUCK is offline
Mein Auto: 2007 335i CPE
Same thing happened to me last month on my 07' 335i, car was overheating but oil temp was relatively low BUT my fan was not kicking in at all. It turned out to be the electric water pump.
Old 02-28-2012, 01:24 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Sounds like the water pump went out and the coolant temp rose faster than the oil temp or a temp sensor has malfunctioned, causing the ECU to believe the temp is much higher. Be curious to know the cause.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 02-28-2012, 03:19 PM
Haley Haley is offline
Mein Auto: 2007 3series
You guys with the 335's have to get the 328i no of these problems. Though not a fast. How fast can you go? I have really never blasted this car yet. I don't need a $500 ticket.
Old 02-28-2012, 03:23 PM
thekurgan's Avatar
Bad Lieutenant
Tell yourself what you like N52 has it's share of "unique" problems all on its own.
Ilse
Bruna
BMWCCA #453648
Old 02-28-2012, 03:37 PM
Killjoy's Avatar
Killjoy Killjoy is offline
OEM Hoe....
Send a message via AIM to Killjoy
Mein Auto: 1999 M3, 2002 tii
You guys really need to get a Honda accord, you won't have any of these problems!
Haley, if reliability were truly the number one priority for most of us on this board, we wouldn't be getting BMW's.
Originally Posted by Cmy_bimmer View Post
Oh your talking about THAT hole.. yeah thats an inspection hole
Old 02-28-2012, 03:44 PM
the 328i uses the same type of electric water pump, so you're still in the same boat. plus the n52 has the joys of the aluminum valve cover bolts that like to snap.....
coming from the same person that doesnt change brake fluid untill it looks dirty....
Brake fluid may not need if not dirty. Check it out yourself. If you garage your car don't need it done. Don't do it until gets dirty
Old 02-29-2012, 06:30 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
Waterpump and thermostat time.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 02-29-2012, 07:23 AM
///MyLittlePony's Avatar
///MyLittlePony ///MyLittlePony is offline
Outside looking in
Mein Auto: 2015 Mustang GT
My Little Pony
Old 02-29-2012, 07:54 AM
Mein Auto: BMW 335i
I just had a thermostat replaced. I understand we don't buy BMW's for reliability, but they do need to at least scratch the surface of reliability. I don't expect a Honda, but I also don't expect to be laughed at by my Infinity friends either.
Old 02-29-2012, 08:09 AM
Mein Auto: BMW 335i
http://reviews.cnet.com/8301-13746_7-20020820-48.html
Old 02-29-2012, 08:50 AM
Mark K Mark K is offline
Mein Auto: '16 981 CS '13 Golf TDI
Look at it this way ... they laugh at you 0.1% of the time. 99.9% of the time YOU are grinning like an idiot while driving and laughing at them.
_
2016 981 Cayman S | 6-speed MT| Active suspension | Sport Exhaust System | Torque vectoring (with LSD) | Sport seats + | Sport design steering wheel
2013 VW Golf TDI . Black on black cloth (yay!), 5 door hatchback, 140hp diesel. MT | Standard go flat tires | Spare tire (yay!) | No moonroof (yay!) .
2011 E92 335i 6MT ZSP ZCW (ED May 17th 2010) [SOLD]
Old 02-29-2012, 08:52 AM
Mein Auto: BMW 335i
Ha thanks Mark! I'm going to tell my wife this. My WAF was already low. It's especially low now.
Old 02-29-2012, 11:18 AM
You guys are too funny I will always have a BMW until I buy a Porsche They are more reliable
Old 02-29-2012, 12:00 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
AHA! The admission I've been looking for....the N52 has no water pump!
Being burdened with such a pump, however, after replacement, what OP clearly lacks is JB4 + Meth.
Most know that advanced ignition timing results in a cooler running engine, and that Meth both enables more advance and can cool certain engine parts.
A little slice of heaven....see Terry @ BMS!
Old 02-29-2012, 12:06 PM
dhc3's Avatar
dhc3 dhc3 is offline
Mein Auto: 335i
Mine went last week. Water pump and thermostat.
dhc3
Old 02-29-2012, 12:17 PM
Mein Auto: BMW 335i
SA just called and said its the water pump. CALWATERBOY what do you mean that I clearly lack JB4. Stop telling me that! My wife will have an all out FIT if I try to upgrade to get more power. She doesn't understand.
Old 02-29-2012, 12:20 PM
johnc_22's Avatar
johnc_22 johnc_22 is offline
Squeal like a BMW
Mein Auto: 2013 Audi A4
What year are your 335i's and mileage that this part is failing. I may be on borrowed time. . .
2013 Audi A4 - Premium+/Sport/MMI/B+O Audio
2007 BMW E90 335i (retired)
thekurgan's Avatar
Bad Lieutenant
Your mistake is informing her
Ilse
Bruna
BMWCCA #453648
Old 02-29-2012, 12:28 PM
Mein Auto: BMW 335i
Well said theKurgan. Let's hope she does not google my username exposing this thread. Did you put your JB4 in yourself? Can I quickly take it out if/when the car goes to the dealership?
johnc_22 2008 335i convertible with 70k miles.
Old 02-29-2012, 12:35 PM
thekurgan's Avatar
Bad Lieutenant
We had the Dinan Stage II with their intercooler, local shop did that. I believe, Calwaterboy does his own and it's not difficult.
Ilse
Bruna
BMWCCA #453648
Old 02-29-2012, 12:40 PM
Mein Auto: BMW 335i
Yeah Dinan sounds great but I hear its like 2k for about the same improvement as the JB4. The best thing about dinan is the dealership blesses it and it doesnt void warranty I don't believe. Either that or Dinan warranties anything caused by it.
If/when I'm ready for JB4 (or similar mod) I'm going to find someone around Birmingham, AL to help me install it. I want to be able to take it out anytime. And I want to know if this will damage any part of my car. Heck its already in the shop enough for breakage, I don't need to offer up more opportunities to waste more money on it.
Old 02-29-2012, 12:48 PM
thekurgan's Avatar
Bad Lieutenant
Yeah, Dinan matches the warranty. My local dealerships were/are Dinan shops, so it was respected. The intercooler made a nice difference.
Ilse
Bruna
BMWCCA #453648
Old 02-29-2012, 01:14 PM
dhc3's Avatar
Mein Auto: 335i
57K miles.
dhc3
