E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
Hi Guys,
I'm having this issue with my 2008 550i since last July. I went to my local dealer back in July 2011 to have to brakes looked at for squeeking and noise (no vibration). They ended up replacing the front pads. Since then, after about a month or 2 of normal driving, a vibration in the steering wheel will be noticed upon braking from ~45-30 mph. Took it back to the dealer and they replace the rotors and pads. 2 month later again, same vibration. Took it back again and they checked for the hub to see if it's true and it was, so they replaced the rotor and pads again. ~2 months later, vibration is back. My car is there now for the 3rd or 4th time and they said they cannot warranty my brakes because they see discoloration on the rotors as if it's been over heated. My driving is pretty normal (probably more on the conservative side if anything) and I do not track the car. Has anyone encountered this situation? What can I do to convince them that this is BMW's responsibility?
2008 White/Cream 550i Sports, Navigation, Comfort Access, Sports Automatic Transmission, Heated Front Seats, Logic7, Sirius Sat, USB/Ipod, Auto Rear Sunshade. LED interior, license plate and side markers lights. Black powercoated OEM wheels, matte black kidney grills, shadowline rear "550i" emblems. Reus Audio System http://www.socal28.com/bmw/socal28bmw.htm |
Do you hose them down when they are still hot?
2007 550i Black Sapphire on Black (Sport, Prem., Nav., Cold Pkg., Logic7, Comf. Seats & Access) ![]() -Hard-Wired Escort 9500ix, Black Carbon Fiber Roundels (body & wheels), Black Kidneys, 35% Tint (sides & rear), Cont. Extreme Contact DWS, R1 Prem. Rotors w/ Hawk HPS pads from ACUTE, OEM MTech Front/Rear/Sides |
No. Nothing out of the oridinary when going to the car wash on any typical day.
In my driving habit, I wouldn't think that would cause any issues as people drive these cars in the rain right?
Well, BMW of Mountain View is refusing to warrant my brakes and is not going to fix this issue. They said that BMW will not reimburse them for this job.
They are accusing me of over heating them which in turn warping the rotors. Saying that I take turns too sharply judging from the side wall of my tires. This is ridiculous! If a BMW 550i can't handle my normal (I would say more on the conservative side) driving that my other Nissan Sentra can, something is wrong! Going to confront the service manager now. I think this is a initial "bedding" issue that they do not complete with new brakes.
How can I go about this taking it higher than the dealer?
Contact info for regional BMW USA service rep? How do I find this info?
Do they think you are taking it to the track??? Total BS. You can call BMW NA and start a claim. Also, ask them if you can speak to their BMW rep.
These are massive discs, hard to believe normal driving style or even aggresive braking can wrap these. As an update, got my car back and bringing it back next Tues when a BMW regional factory Tech will be there to evaluate.
They said that they can tell of the over heating from the discolorization on the discs.
Brake experts, anything unusual with these? With flash... ![]() Without flash... ![]() Maybe not the greatest pics. I'll try to get better one up later.
2008 White/Cream 550i Sports, Navigation, Comfort Access, Sports Automatic Transmission, Heated Front Seats, Logic7, Sirius Sat, USB/Ipod, Auto Rear Sunshade. LED interior, license plate and side markers lights. Black powercoated OEM wheels, matte black kidney grills, shadowline rear "550i" emblems. Reus Audio System http://www.socal28.com/bmw/socal28bmw.htm Last edited by socal28; 03-01-2012 at 10:17 PM. |
Rotors almost never warp. Have you considered thrust arm bushings? When they fail, they cause your exact symptoms.
. "Voters will always choose the beautiful lie over the uncomfortable truth" |
If anything, BMW's rotors are known to warp. The design on BMW rotors is intentionally thin to reduce weight. That's why the recommendation is to never turn BMW rotors. There typically isn't enough material on them to do so without going below the min thickness stamped into them. They're thin to start with and that's why they warp so easily. I had mine replaced at 70K. Pads were fine. Rotors were warped. I had the same symptoms as the OP. |
I believe there are topics discussing 'rebedding' by a member who owns an e39.
Most likely, there is no such thing as 'a warped rotor'. Recently I had all 4 rotors and pads replaced (all OEM), then I got shaky steering wheel during braking, and guess what, the cause of that was a nail in one rear tire. After fixing the tire, shaking steering wheel went away. |
Just because it hasn't happened to you, doesn't mean it doesn't happen. |
Calipers dragging?
I reccomend you get the front bushings checked, with my Blk 540i I had both warped rotors & bad bushings... Imagine my face going down a mountain with the shaking from the steeringwheel!
Changed the rotors/pads, good improvement, but still shaky..Changed the bushings, shaking was gone. Same thing with my 03' right now, I shake sometimes, but the rotors are good, even my tech noted the bushings are nearing the end of their life. Though i'm not 100% sure i can relate an E39 problem to the E60, but the concept may be the same.
~The Fun Cars~ 2003 BMW 540i [Sterling Gray / Gray] [Msport] [DSP] [AUX] [ICE V5] [BSWs] [DINAN Trans] [M Audio Subs] [E38 lighted int. door handles] [E46 Paddleshifters] [Two-tone Interior] 2008 BMW 550i [Jet Black / Black] [Sport] [Paddles] [Comfort Access] [IPOD] [Shades] [Nav] [PDC] A 5'er that was almost too good to be true. Stuff For Sale: OEM E39 Nokia Subwoofer [click] Last edited by Dking078; 03-02-2012 at 06:39 PM. |
A much more likely cause would be failed thrust arm bushings, as posted by others. |
Thanks for the input guys.
Yes, it seems that after they have replaced the rotors/pad, it is fine until ~1k to ~2k miles (1-2 months), then the vibration in the steering wheel while braking between 45-30mph is felt gradually increasing from then on. I currently have 46k miles on the car. Main warranty just expired Feb 13th this year and is now on CPO warranty. When I bring it back tomorrow morning, I will mention the arm bushings and see what they say.
Silly question - when was the last time the tires were balanced? The e39 was notorious for getting wheel shake from a slightly unbalanced tire. You wouldn't feel it during normal driving but as soon as you got on the brakes, you could feel it. Certainly not trying to discount the fact your rotors may be warped but you may want to insure the easy stuff is out of the way before calling BMWNA.
BMWCCA Member 368765 2008 BMW 535iA | Cobb stg 2+ | FBO | Meth
Before you purchased the car someone may have tracked it hard.
Common problem with a poor cool down lap.
94 530i sold (That was difficult for me) 01 530i >144,500+ miles SOLD ![]() 06 330XI winter's especially fun drive (SOLD) 10 M3 Sedan (sweet) 13 Nissan GT-R Black Edition ![]() 13 Porsche Cayenne Diesel ![]() BMWCCA 4215 |
If is indeed the bushings, I will fight to have it repaired under warranty has this issue has started well before my original warranty expired.
This saga only started after dealer changed out the brakes for some light squeeking noises.
Socal I have the same problem on my 535Xi. I have the third set of rotors on my car since last June. My problem is I seem to have the wrong pad rotor combination with regards to my driving style. I will agree I am harder than most when it comes to brakes. I will say that I have followed the instructions verbatim on "bedding in" the pads and it does help. My opinion is that the brake setup on my car are undersized for "spirited driving". Not sure if the 550 has larger brakes than the 535. I am currently waiting for my HPS Hawk brake pads as I know this will rid myself of brake pad deposits on my rotors. This will however cause decent amounts of brake dust and rotors that I will have to replace very frequently. Oh well, something has to give and I don't feel like spending 5K+ on a wheel and brembo brake upgrade. I have used the Hawk pads (blue) on my track car in the past and have had excellent results.
Here is a photo for viewing pleasure of the pad deposits. Notice, this didn't show up like this until I started to buff it with a disk. Before that it looked like a blue stripe on the rotor.
#25
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
