Old 02-29-2012, 08:46 AM
valve79 valve79 is offline
Mein Auto: 740il
740il transmission problem slipping
Just bought a 740il 2000 and knowing it had problems with the tranny i bought it anyway and planning on getting used tranny to put in.
Bought it and drove it home since it can still move. When stopped and steped on gas the engine revs up and car starts to move really slowly. Once i get up to speed seems like the tranny is fine its only the take off is slipping.
Is this a sign of new tranny in need or could i change the filter and fluid to help the problems go away ?
Has any one out there had this problem ?
BTW just when i drove the car home for 20 min i fell in love with this beast.
Thanks In advance
Old 02-29-2012, 09:30 PM
agyarkwa233 agyarkwa233 is offline
Mein Auto: 525i
i'm having the same problem only that mine is a 525 i.. did u change the fluid and air flitter yet... i'm about to do that to mine since i just bought like some couple of weeks ago
Old 03-14-2012, 06:45 PM
facemobb facemobb is offline
All I Drive Is A BMW
Send a message via Yahoo to facemobb
Mein Auto: 2001 740il
Try pushing the manual and automatic switch to the automatic position before putting it in drive..
Old 03-15-2012, 06:02 AM
Mein Auto: 740il
Problem solved
The transmission was in Limp mode. I disconnected the ABS module and tada transmission works like new. Sent off the module to get rebuild and thank god i don't need to do the transmission job - big relief....
Old 01-16-2013, 06:36 PM
Kevin Halbleib Kevin Halbleib is offline
Mein Auto: 740il
I am having a similiar probelm. What is the ABS module and how do you disconnect?
problem, tranny, transmission
HTML code is Off
