3.2L Goodness - Page 11 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 03-20-2012, 01:11 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
you need a relay so you dont overload the circuit you're drawing power from.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 03-20-2012, 01:13 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
Hell yea I gets mad gurgle yo, and I get 20-22 mpg
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 03-20-2012, 01:14 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
So the relay acts as a resistor?
Damn, that's more than my M50 got.
-CJ
Old 03-20-2012, 01:21 PM
cj.surr's Avatar
some kid
Originally Posted by drive by72 View Post
here ya go. it was a quick i might have messed up the numbers on the relay but you get what i mean
Shouldn't "30" be the fused power, since that's the power going to the fan? And the other two are just opening the switch?
-CJ
Old 03-20-2012, 01:38 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Cj relax. Kennys right. Without a relay you'll melt wires from too much electrical load on the stock wire.
A relay is simply a switch, that's controlled by some kind of power. 30 is the signal. When 30 gets power, it tells the relay to close, which connects 86 and 87 (which is the wires that would go directly to the fan if you wanted it to run 24/7) You don't fuse 30 because it's already fused and has no load on it.
86 needs a fuse because that's the power to the fan, and of it shorted without a fuse it could cause a fire/melt. You have to create your own power source for it, basically you need to tap the jumper block in the engine bay.
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 03-20-2012, 01:59 PM
cj.surr's Avatar
some kid
That's what's confusing me... It doesn't look like that on the diagram on the relay.
Diagram on the relay resembles this, which shows 30 as the fused power. 85/86 are the switch, and 87 goes to the part.
-CJ
Old 03-20-2012, 02:53 PM
cj.surr's Avatar
some kid
Ok, I understand the relays now. I set it up and the power to the fan is too high. The fan is spinning faster than it needs to be. What I would like to do is set up a 5-pin relay.
87a- goes to fan with resistor to limit speed
87 - goes to fan without resistor.
I'll run a switch in the cockpit so that I can choose between high and low speeds.
I just don't know how to choose a resistor. Can I just try different ones until I find one I like? And is it going to get too hot or something? I can't think of very many resistors in the E36.
-CJ
Old 03-20-2012, 04:21 PM
cj.surr's Avatar
some kid
Aha! I found the problem as to why the stock circuit wasn't working. It was a 318-specific fuse that sits under the steering column. I didn't know about it since I had a 325 fusebox cover on my 318.
It's a jumbo 40A fuse, twice the size of a regular one. I'll have to see if Autozone has it tomorrow. It's not in a 325, so I don't have any spares.
-CJ
Old 03-20-2012, 05:39 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
A maxi-40 can be found at Walmart or anywhere else stereo stuff is sold. Maxi fuses are used in stereos.
As far as using a resistor, yes that could work. Get a bunch from RadioShack and just start playing around with what works and what doesn't. I don't really know what values to recommend, i don't play with resistors much outside of testing
Old 03-20-2012, 05:53 PM
cj.surr's Avatar
some kid
Cool. I figured I recognized it from the ghetto sound system in the silver E36 I had.
Hopefully I won't have to worry about the resistor, since the stock circuit should work once I replace that fuse.
-CJ
Old 03-20-2012, 07:33 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
Sweet deal. And if your OEM aux fan doesnt work, just tap the blue wire and follow my DIY
Old 03-20-2012, 07:41 PM
cj.surr's Avatar
some kid
I'd be using the stock circuit, but still the Mishimoto fan. I'll probably rig a manual switch for the high-speed relay.
-CJ
Old 03-20-2012, 09:26 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Mine too, and I get 24.5-25 mpg
Aren't PO's awesome?
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 03-20-2012, 09:32 PM
cj.surr's Avatar
some kid
For my silver E36? Hell yeah he was awesome. He gave me a car for 450 and I sold over 2000 worth of parts while keeping some for myself
-CJ
Old 03-21-2012, 08:08 PM
cj.surr's Avatar
some kid
I replaced the sneaky fuse, and now the stock fan circuit is working properly. The only problem is that the Mishimoto fan is at the same speed for high and low. I noticed that the stock aux fan has two separate wires going into the motor casing, one for each speed. There must be a resistor in the fan itself, which would explain why the Mishimoto fan won't change speeds.
The fan spins very fast, and causes quite a racket. So I want to put a resistor on the low-speed circuit. I know that the blower motor resistor has a heat sink, but I probably wouldn't need that if I mounted it in the air stream of the fan, right? I just wanna make sure it's not gonna burn up.
-CJ
Old 03-23-2012, 08:18 PM
cj.surr's Avatar
some kid
Any of you electricity geeks wanna check my calculations? I want the fan speed to be about half of what it is now.
Current: 7.5A
Desired Current: 4A
Resistance = 12V/7.5A = 1.6ohm
Desired Resistance = 12V/4A = 3ohm
So about a 1.5ohm resistor in the low speed circuit will do the trick?
-CJ
Old 03-23-2012, 08:44 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Amperage isn't what you change. It's the voltage you want to drop to slow the fan.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 03-23-2012, 08:55 PM
cj.surr's Avatar
some kid
Hmm really? How would I calculate the resistor size? Or do I have to use trial and error?
-CJ
Old 03-23-2012, 08:58 PM
D'oh, You Kids!
You'd need to know what voltage runs the motor at the low speed you want, then you could calculate the resistance using Ohm's law. Google is your friend.
Quotes to live by:
BMW-CCA #441426
Old 03-23-2012, 09:23 PM
cj.surr's Avatar
some kid
Voltage and amperage are directly related, I got the same answer
So I need 1.5ohm resistance, but there is a lot of power going to the resistor (90W). So I need one of those big 100W resistors, but it seems that all of them have very high resistances (10k ohm)
http://www.radioshack.com/product/in...uctId=12582666
-CJ
Old 03-24-2012, 07:50 AM
Hellawut??
Mein Auto: who knows?
http://sd.craigslist.org/cto/2879017988.html
thought you would like that cj
-Franklyn
Old 03-24-2012, 08:43 AM
cj.surr's Avatar
some kid
Maybe if it wasn't 2500mi away... Why are you looking at SD listings anyway?
-CJ
Old 03-24-2012, 08:46 AM
cj.surr's Avatar
some kid
So much fail with this intake elbow. Tried using rtv, goop, 60min epoxy to get the rubber hose to stay on the elbow, no luck with any. Epoxy was closest though. Might cave and buy the bimmerworld boot.
Anybody know of a hose fitting that might work? Like one that I could stick in the hole and thread a nut on the other side?
-CJ
Old 03-24-2012, 02:40 PM
alwayshear alwayshear is offline
Mein Auto: '94 BMW 318i
You could use a bolt with a hole going through it, a nut and two washers. Or you could use a brass fitting with two nuts and two washers. Let me see if I can find something to show you a little better.
or drill a hole down the center of an appropriately sized bolt in this configuration:
Bam, and you're driving tonight! ......And order the right boot next week!
Old 03-24-2012, 02:42 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Buy the boot Cj lol.
Sent from my ADR6400L using Bimmer App
Turbo Build Here
:3, i was here
