E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Homemade strut brace
I had some free time in class today and built a rear strut brace. I used 1'' steel pipe (I think it was old gas line, one end was threaded) and the mounts are just 1/4'' steel plate I heated and cut. I then but it on the drill press and drilled two holes per mount. I took a level and hammer and set the brace where I wanted it then drilled holes through the strut tower making sure I didnt hit anything. Added four bolts, nuts and thread lock.
I wire wheeled the whole thing and got it looking shiny. The whole thing was made out scrap laying around the shop and mig welded. All together it cost me nothing. Ill have pictures tomarow! Sent from my SCH-I110 using Bimmer App
Primered Black 92' 325i. Ireland Engineering Header, Ireland Engineering Catback, TMS Underdrive pulleys, TMS chip, Bav auto fpr, Power Flow cai, Bav auto coil packs, Cool Carbon pads, Eiback springs, Bilstien Sport HD shocks/struts, 3.23 LSD, Understeer short shifter, 16'' Spal Fan, Goodridge Steel Brakelines, M3 Bumper, Black out grill, clear tails, M3 mirrors. |
You should have had pictures today....
I always wanted to make my own bar(s), but don't have the extra scrap laying around, nor do I have the equipment necessary
![]() Pics
-Usama ![]() "The American Dream only makes sense if you're sleeping" - Lowkey |
![]() ![]() Its not the greatest and it isn't lightweight but it was free and so far works great. Dont mind the dust and dirt, i have to take gravel roads everday. Sent from my SCH-I110 using Bimmer App
![]() Sorry, double posted the same picture. Sent from my SCH-I110 using Bimmer App
.... I may be ignorant so please educate me but I thought they went over the top of the struts and connected with the actual shock mount. Or is this unnessessary?
I hate to say it, but to my understanding, the purpose was to control the movement of the shocks& struts more than anything. These seem (to me) as though they would add stress to the shock towers, potentially enabling failures.
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
That strut bar looks pathetic...
![]() They're supposed to go ABOVE the shock tower and bolt up with the shock mounts.
![]() Last edited by Gooby; 03-03-2012 at 07:32 AM. |
Strut and shock bars add rigidity by stiffening the mounts, keeping them from flexing. The only area spanner bars are used are behind the front seats in sedan applications (mostly). This wont reduce body flex during high torque, and certainly does nt work as a shock reinforcement bar. :/
E36, because to me, everything else is just a car. |
So the towers themselves dont flex, just the small area at the top flexes?
The loads from the shocks in in the rear and struts in the front tend to try to push the mounting points inward toward the center line of the car. This creates variability in the suspension geometry at the point where you least want it to happen. The bar spanning from one tower to the other holds the spacing between them constant and reduces or eliminates the geometry variability. The best and most effective point to do this is at the shock or strut mount.
In the OPs design the idea of trying to maintain the spacing is there, but I thnk the flexibility of the sheet metal where it's attached is going to defeat the purpose. I suspect there will be some placebo effect from it, but without before and after skid pad results it's going to be really hard to tell if it's made a difference. OP, one thing you've definitely done if you didn't put some RTV or some other form of metal protectant where you drilled the holes is create a perfect place for rust to start.
Reference: ![]() Spanning from rsm to rsm. edited redundancy
E36, because to me, everything else is just a car. Last edited by Archetype; 03-03-2012 at 10:15 AM. |
Even if it was made correctly, how many people say adding a rear strut bar made them love their car again?
Sounds like front strut bars are way more aesthetic than functional, can't imagine what a rear brace would be for.
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
To ruin the placement of your speaker box?
My rear strut bar runs through my box. n00B
My speaker box is muh strut bar.
My rear strut bar was free and does not interfere with speakers, I use it as a clothes hanger for my towel after drying car lol
Part out. http://bimmerfest.com/forums/showthr...67#post7418867 "Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI Stock 2004 X5 3.0i (Wifes) E30 87 325e |
I have seen this b4 lets have a pic!
From what I've heard/read, the rear bar makes virtually no difference, and doesn't add any noticeable stiffness. Many people say the same thing about the front strut bars, but I've heard from some people who've said the front bars made a big difference. The biggest improvement I've heard reported comes from the addition of the x-brace underneath the car.
Regardless, a lot of race cars have the rear braces welded to the rear shock towers in the exact same position as what is seen above, so I think there is certainly some bracing going on.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
But he is calling this a strut brace. The strut isn't being touched at all. I imagine the bar will reduce body roll but it won't be noticeable.
And If I were to mod the handling on another E36, only AFTER I replaced every bushing, ball joint and control arm in the suspension, would my order would be, X-brace, camber plates, sway bar, springs/dampers, strut braces. Now, I'd likely get the camber plates with the new springs/dampers, but if I were to do it piece meal, I've discovered that camber is more important on an E36 than a front sway bar... *I strongly discourage doing the latter anywhere but on the track, skid pad or autocross course. Too often a 9/10ths drive in the twisties can result in an 13/10ths OH SH!T!!! moment
Example: ![]() ![]() ![]() And if you want to get technical, they aren't called strut or shock braces, they are called strut/shock TOWER braces. You don't need to be on top of the strut or shock to brace the tower. You just need to ensure that the towers themselves cannot move inward toward one another under heavy load. The OP put his bar in a very commonly used location. The only thing he did differently (and is something that I probably wouldn't do) is how he attached it with the hardware. I'd have welded it, since the idea of drilling holes in that location seems like an unwise idea.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 03-03-2012 at 06:50 PM. |
When e36 mounts fail, they are nt ripped from the sides. It is the top that is mangled and twisted up from lack of support. exempli gratia: I think these address two different issues, not the same one. How would OP's bar prevent the twisting and flexing of the mounts that caused this ^?
E36, because to me, everything else is just a car. Last edited by Archetype; 03-03-2012 at 07:38 PM. |
A shock tower brace in intended only to increase chassis rigidity, which is why the OP installed a brace. If he wants to protect the towers from ripping out, that's what reinforcement plates are for.
#25
| Bookmarks |
| Tags |
| :3 |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
