Old 03-03-2012, 10:43 AM
rob.mcquaid rob.mcquaid is offline
Mein Auto: 740il
Front-seat side airbags liner replacement
I recently purchased a 2000 740il and about to have the headliner replaced. Should I be concerned about the Front-seat side airbags when removing the side panel?
Any advise would be appreciated.
Rob
Old 03-04-2012, 09:50 AM
exred92 exred92 is offline
Mein Auto: 2001 740i sport
NO, I wouldn't even remove side panel,just carefully untucked headliner from top of the side panel (b-pillar), but you'll need to remove both sides a-pillars which has a torx screw behind the cover I think T20 or T25 and c-pillars you will need to remove light fixture and behind it there is a 8mm screw.If you just removing and replacing headliner it should take no more than an hour of work.
Good luck.
750il, front-seat side airbags, head protection system, headliner replacement
HTML code is Off
