Old 03-19-2012, 07:16 AM
carramrod_91 carramrod_91 is offline
Mein Auto: 325i
Exclamation A 325i Undercared for :(
Ok. so I bought a 2002 bmw 325i in late decmeber of 2011, with 136k miles. Upon taking leave in Feburary I had been passing a semi when my wife had started freaking out becaus of on coming traffic. I was in 3rd gear at 5k rpm's. When the screaming had started it startled me and i drop the gear into 1st. There is a ticking sound which i believe to be a valve tapping. There are a mass of codes being sent by the ECU. The fist code was a MAF sensor. i was told it would correct itself but after 5 days i gave in and replaced the MAF sensor Thanks to Am AutoParts. Also noted i don't run the stock air intake, I've got the K&N Cold air intake. The MAF sonsor didnt correct the problem so i checked my spark plugs. The 1st cylinder was coated with fuel, so i replaced all of the plugs. Problem still not corrected. Now at this point i found cylinder 1 has a missfire so i changed the ignition coil. still no fix. Now as of Sunday March 18 2012 i have driven the car around my parking lot twice once i parked the car and shut it off i then went to restart it and nothing happened. The starter didn't even engage. what should i do i love this car first BMW i've had and i have limited time in the US I am to PSC to Germany. PLEASE HELP
THANK YOU
-Mark
Old 03-19-2012, 09:02 AM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
Unfortunately, it sounds like you may have performed what is sometimes called the "money shift". If the engine was over-revved, the valves and pistons may have collided, resulting in internal engine damage.
Before buying any more parts, I would recommend some basic diagnostic work on the engine. Do a compression test. If you have low compression in one or more cylinders, you may have bent valves or damaged pistons. Next, do a leakdown test. Finally, look inside the cylinders with a boroscope. You may wish to have the last two tests done by a professional BMW technician.
If the engine is OK internally, then proceed with your other diagnosis.
The non-working starter may be simply a depleted battery.
Alpinweiß
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 03-19-2012, 10:27 AM
Mein Auto: 325i
i will do those test as for the battery its strong and healthy lol i checked the voltage with a volt meter and on the cars computer and they both read the same 12.5
Old 03-19-2012, 11:25 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Measuring voltage doesn`t mean sh!t when there`s no load on the battery. It`s the CCA (Cold Cranking Amps) that counts. Lots of older batteries will meter 12+ volts, but have no CCAs available to get the job done.
The road goes ever onward....
(R.I.P. Jever)
Old 03-20-2012, 06:16 AM
Mein Auto: 325i
In all reality voltage has alot to do with the battery AMPS run on voltage. Voltage is what moves the amps. So what I am getting at is i may be 21 and only have 10 years with being a mechanic but my post are no places for rude ASS COMMENTS. I'm only seeking alittle gudience. GOT IT!!!!!!! One last thing before you try and tell me something that i KNOW for sure is true look it up shoot your already on the internet use it.
Old 03-20-2012, 07:04 AM
ckleung100 ckleung100 is offline
Mein Auto: '99 323i
I happen to agree with Bob and so will everybody else that knows anything on this forum. I would explain why except I don't want to waste my time educating you. You are the one that is being quite arrogant for someone looking for GUIDANCE. Don't expect much help with that attitude. Good luck.
Look it up on the Internet ??... LMAO. I've been fixing cars before there was an Internet.
Measuring voltage doesn`t mean sh!t when there`s no load .
Oooooo Bob, you swore. Shame on you, there are children present.
Old 03-20-2012, 10:03 AM
Mein Auto: 325i
There's alot of ****in children on this site. I was only stating what voltage does, and how i only require guidance and im so sorry i typed to fast. Shoot me dead, however, if someone will advise me in the right direction i'll be done with these little problems thank you all.
Old 03-20-2012, 12:14 PM
Fast Bob's Avatar
Keeping it surreal
I think you would be better served over at E46fanatics....
(Don`t let the door hitcha where The Good Lord splitcha)
(R.I.P. Jever)
Old 03-20-2012, 01:40 PM
e46freak e46freak is offline
Mein Auto: BMW 328i, 3 Pedals
+1
Also, why on earth are you arguing over a battery? Im going to assume that if you were turning 5 grand in 3rd, and you moneyshifted into 1st, your engine is beyond screwed.
Old 03-20-2012, 02:00 PM
Toona79 Toona79 is offline
Mein Auto: 2003 325i
your valves probably look alot like these
03' 325i ZSP ZPP
Old 03-21-2012, 05:29 AM
Mein Auto: 325i
heres a thought BOB if your going to be no help quit opening your ****in mouth then
Old 03-21-2012, 06:20 AM
Mein Auto: '99 323i
You are from the internet generation so let me give you some advice about how to trust what you read on the net.
Bob gave you some sound advice and you chose to yell at him and insult him instead of discussing it or God forbid thanking him.
I have no clue what the hell that is supposed to mean. FYI, I can produce the same 12v reading on a voltmeter with 8 AA batteries but it's not going to start the car.
I don't know Bob personally or otherwise and I don't speak for him but he has 24,500+ postings on this forum since 2004. That speaks for itself. You have 6 since Monday. Do you really think Bob is an internet troll who's spamming your post?
Some food for thought Sparky. I will quit opening my ****in mouth too now.
Old 03-21-2012, 11:17 AM
Welcome
to my ignore list
03' 325i ZSP ZPP
Old 03-21-2012, 02:05 PM
Coconutpete's Avatar
Coconutpete Coconutpete is offline
Coconut Pete's paella!
Mein Auto: VW Wabbit
Thisguysuretalksalotofsmackforsomeonewhocan'tdrive amanualandwriteslongincoherentparagraphsoftext.
The word "there" can appear as a pronoun, as in “over there".
"Their" is a possessive pronoun. In a phrase like “Susan and Bill's car,” it could be used to to make a new phrase: “their car.”
”They're” is a contraction of “they are.”
“They are” should always be able to replace “they're.”
Extra credit: It's "I'm looking for an M3" not "I'm looking for a M3".
Old 03-21-2012, 02:42 PM
Old 03-21-2012, 06:09 PM
Gadget Gadget is offline
Mein Auto: 06 330cic
Seriuosly?? I'm with ckleung100.
I'm too old to get into internet 'fights'.
Respect the ones who have the knowledge...
'06 330cic
Monaco Blue, ///ZHP, ZPP, ZCW, Hard Top
Old 03-21-2012, 06:31 PM
Gryphon's Avatar
Gryphon Gryphon is online now
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
V=IR there's you're relationship. Bob happens to be completely right, Resistance is the "load" and will change dependent on a running car or measured across the terminals. I'm swallowing an angry retort based on the belief that you're a bit shocked from learning you may have an EXTENSIVE repair ahead of you. That's your pass, I advise biting down on that ego and stop being so quick to jump to a fight.
Damn, I stopped whipping it out to measure years ago....
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
