Old 03-05-2012, 05:35 AM
ncord ncord is offline
Mein Auto: 2006 X3
Tranny Fluid
What would be the best ATF to use in my 06 X3.I have 78K on it and would like to change the fluid.I have done the Diff.& TC & rad.
Old 03-05-2012, 10:11 AM
timarnold timarnold is online now
TA
Mein Auto: 2003 bmw 525i 2005 X3
It will depend on what type transmission you have. You have either a ZF or GM transmission. You can use this chart to figure it out: http://www.bmwtips.com/tipsntricks/Tranny/chart.htm. There is a label on the bottom of the transmission that will be referenced by the chart.
Old 03-05-2012, 10:31 AM
Mein Auto: 2004 X3 2.5i
It definitely is a GM transmission, and for the OP will be a Green metal tag on the underside.
Although the above chart only goes up to 2002, you should confirm that it is a A5S390R transmission - same as some 2002 3 series.
The difficult part is then finding out if the indicated fluid is still available, and if not, whether the recommended replacement really is suitable.
Old 03-05-2012, 11:16 AM
bimmernut1 bimmernut1 is offline
Mein Auto: Porsche, BMW
I was checking just today and both the Dextron and Texaco brands are still sold; at least by my local dealer. One was about $5 per quart bottle. The other was $10 per liter and you bring your own containers in. If I remember correctly, 8.8 liters or two gallon jugs are needed if you don't drain the converter.
1979 Porsche Tobacco Metallic 911SC
1996 Porsche Guards Red 993 C4S
2005 Porsche 996 Turbo S
2003 BMW Ti Silver M5
2013 BMW X3 35i Carbon Black M-Sport
Old 03-05-2012, 11:32 AM
TA
Reading through other forums, the GM transmission used to be Texaco 8072B. That is no longer available and the BMW spec is now Dexron VI, available everywhere.
Old 03-05-2012, 12:16 PM
This site (which apparently is Habberstadt BMW in NY) appears to still have ETL 8072B:
http://iwantautoparts.com/bmw83-22-0-024-359.html
Old 03-05-2012, 02:50 PM
Mein Auto: 2006 X3
The lable on my Tranny is BLUE with the no.83220024359.
What type is it,and what fluid would I use
Old 03-05-2012, 05:13 PM
The part no. is more dependable than the color of the sticker it seems.
Maybe those sticker colors change over time from heat, etc.?
This DIY by a 2002 325 owner seems to have the same sticker as you, and interestingly compares the color and viscosity of fresh 83220024359 fluid with Dexron VI - quite different:
http://www.bimmerfest.com/forums/sho...d.php?t=443800
If you can still get the ETL 8072B (BMW part no. 83220024359) I'd say that is your best plan.
Old 03-06-2012, 05:23 AM
TA
It's certainly your call & there is probably no correct answer, just opinions & debate. I changed my fluid/filter 40k miles ago with Castrol Dex VI & have been running flawlessly ever since.
Old 03-06-2012, 07:28 AM
Mein Auto: 2006 X3
Thanks for all the info.I think I will go with the Castrol Dex VI. Im thinking 6 qts.will do the job if I just drain & fill?
Old 03-06-2012, 09:44 AM
TA
It's been a while, but I recall using a little more. Buy 8, if you don't need it all either return it or save it for the next time.
