7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#26
watever
#27
I was cranking before than stopped I believe it was battery issue. the code 2D03 i can't no one with this problem. I am waiting now for new battery and fuel filter. Once i installed them i will check fuel pressure and try to re-aline DEM. that is only thing does not respond with dis (?). I will let you know guys. Thank you
#28
Hey Khabar I am having a very similar issue have you been able to resolve the problem.
Thanks, Any help would be appreciated. |
#29
I fix my car after 3 months of unknown. My DME failed. I bought new one from RMP motor sport. The car started right the way. Thank you guys for you help .
#30
That's good to hear. How much did they DME run you?
$ 860 programmed just" plug and play" with latest software self installation and coding using DIS 57. Not too bad
#32
wow!
WOW Is it good or bad
#34
BOTH Good its Fixed Bad it cost so f****** MUCH $$
dealer wants 1500 -1700 for that. MAF sensor cost 300 for our cars
#36
Where did you get it from?
#38
Thanks Khabar
I am having similar issues as well. I bought a used bmw car brought it into get it repair for cosmetic reason. All of a sudden the auto body told me the next the car had starting issues. the car was working fine just the day before. Here is a video i uploaded The issue with mine is the car would crank but it wont start and the throttle keeps clicking. I tried changing the throttle body still the same. changed Crankshaft sensors too still the same. I am not sure if the battery is the main issue but when i brought it to a Oreilly's auto parts they did a test on the battery and said the battery is fine. So I am not sure what is wrong. Now that you got yours fixed khabar I think mine could be the DME since someone tried connecting a scan tool to the system and it couldn't connect. I did connect the odb2II code reader and it came up with the following codes. P1720, P1727, P1721, P0120, P123, P222 I have a BMW 545i 2005 btw. Last edited by Totalfixation; 06-16-2012 at 01:26 AM. |
#39
btw where is the ECU normally located?
#40
under hood next to firewall. U need to remove cabin filter left tnan u would see black box everything in it. No used DME would work for u
#41
My car has some check engine lights going on and transmission failure but i think it has something to do with the below P Codes.
So basically today i took apart the DME, no physical damage. I ended up putting it back together and the Throttle stopped clicking the video I posted above. It did however make a smaller clicking noise. I check the fuse box next to the DME and non of the fuses have been blown. I plug everything back in still nothing. I pulled out the spark plug and coil and started the engine. Non of the spark plug seem to be getting any electricity. So i am not quite sure what is stopping the system from sending electricity to the to spark plugs. I would check the fuel but it wouldn't make any sense the goal first would be to get the spark plugs to spark. So before I was getting ODBII codes for the throttle but now it's only P1720, P1721, and P1727. The codes above seem to be point to CAN Timeout. Is it possible to still crank the car if the key and the car are mismatch? meaning there is no pairing between the car and the key transponder? My key can remote unlock and lock the car. Note: My auto body place has a voltage tester and said the battery is good and passed the test. So i don't know yet if i should buy another battery, Cant return if it's not the battery. I mean how often does the battery create this sort of problem? Anyone can help me out on this, much much appreciated |
#42
check the voltage from DME to throttle body and potentioner 1 and 2
#43
I dont have a voltage tester but the power coming from the DME to the Throttle body is pulsating. Also no power is going to the spark plugs. So My guess is it has to do with something in the DME. or it needs to be reset. Do you know if the DIS V57 can reset the bmw DME?
#44
voltage may come to DME but at my not supply potentioter. read more about it works. if you want to fix your car u need buy tools, software. It is kind of complected car. I spent 4 month before i order new DME
#45
OMG really
a throttle body flapping just when i thought i have heard all the crazy problems on this car, i find something that tops the chart!
'03 745i - modded - GONE - |
#46
happens
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
