The 1999+ Z3 Roadsters came with a single 6.5-inch subwoofer that, with very little work, could be retrofitted with a Kicker Comp VT 65. Those of us with earlier versions with the premium Harman-Kardon system got two-speaker subwoofers that could not be retrofitted with anything on the market, and even if replacement speakers were available, it would still sound poor. After looking everywhere for a single-speaker sub box, I finally decided to borrow a line from Dr. Suess:
Did that stop the old Grinch...?
No! The Grinch simply said,
"If I can't find a reindeer, I'll make one instead!"
So I decided to make a subwoofer box that virtually matched the BMW HK single-speaker box. It wasn't too hard, but it did take some time. Basically, I made a plywood mount for the speaker (Fiberglass doesn't hold screws), formed three inner moulds out of green flower foam, fiberglassed them until they were strong enough to handle, dug out the foam, assembled the pieces into a box, and fiberglassed the entire assembly to the final thickness.
One of the biggest questions I had was how thick to make the fiberglass, and I had to decide that before making the moulds. I settled on 1/4 inch*, which is a reasonable planning factor. The final thickness was slightly less than that. I stopped adding layers when the box was rigid, and that turned out to be about four layers, two before assembling the halves and two after.
Kicker recommends a sealed volume of 0.2 cu ft. There really isn't enough space available to achieve that. I tried to use every bit of space available, but could only come up with 0.17 cu ft or so. The first thing to go was the mounting brackets. I'll be using some high-density foam blocks to hold it between the roll hoops and some sound-deadening foam sheets to keep it off the steel bar. I also sprayed the inside of the box with sound deadening spray ("Quiet Kote") and I filled the box with poly-fill in an attempt to make it sound acoustically larger.
I actually made two versions. Since I had never worked with fiberglass, I expected some mistakes. I also felt the shape would be too complex to get it right the first time. I was right on both counts. The first version was good to put into the space to understand what would fit and where to trim. The second version was much better. Another thing I did on the second version was to wrap the flower foam with plastic food wrap before fiberglassing. It took some extra time to glue the plasic wrap to the foam and trim it, but it made the foam come out much easier.
I could have made the box a bit prettier with the addition of a layer of Bondo or even just a coat of paint, but it is entirely hidden, so I didn't bother.
It was interesting to hear what a difference a sealed box made to the sound. At one point, I just mounted the speaker to try it out. While the box wasn't sealed, it was very tight. At moderate volumes, there was an objectionable cackle in the sound. Later, after I had sealed the wire hole and the speaker mounting flange with silicone, the sound was much nicer and accurate.
Fiberglassing materials are readily available at hardware stores and home centers. You'll also need to pick up measuring cups, disposable paint brushes, latex gloves, and a good respirator mask. I got sound-deadening foam sheet and Quiet Kote from PartsExpress.com. I got 100lb XX high-density foam blocks in sample size from BestwayFoam.com. Poly-fill came from a fabric store. Flower foam came from a craft store.
* My apologies to the non-US members. Here in the US, we long ago rejected the arbitrary British notion of driving on the left, but steadfastly hold on to the nonsensical British measurement system, long after they abandoned it.
