Old 03-07-2012, 10:43 AM
fhopper's Avatar
fhopper fhopper is offline
Mein Auto: '04 X3 3.0i
FRAM air filter
Check engine light came on.
BMW dealer said the code was a lean fuel code and the fix was to take my new FRAM air filter out and put a BMW one in. $126 for complete service ticket, $24 filter, the rest shop and labor fees.
I told them to put the FRAM in the back! Does anyone really believe this code was the result of using a FRAM filter?
Old 03-07-2012, 11:43 AM
Supercourse Supercourse is online now
Mein Auto: 2004 X3 2.5i
Heard this before - not so much because it is a FRAM, but more because it does not fit quite right.
Can't really see how it would cause a lean code, but if it does fix the problem right away, I guess they are right.
Mahle and Mann filters seem to be the safest bet.
Old 03-07-2012, 12:50 PM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
It sounds odd, at best. Let us know if/when the CEL comes back...
Old 03-07-2012, 02:15 PM
ngcreese's Avatar
ngcreese ngcreese is offline
Mein Auto: '11 X3
I'm reaching here but.... pre-cat O2-Sensors / spark plugs?? (if your mileage is above 60 to 70K...)
'11 X3 xDrive35i -- Coded
'07 X3 3.0si -- Coded & Traded
'91 e30 325i -- Sold
BMWCCA Member
Old 03-07-2012, 02:41 PM
fhopper's Avatar
Milage 67k, car runs like a scalded dog. I kinda hope it throws a code again, we'll see.
Old 03-07-2012, 02:43 PM
Sounds like is the good ol' vacuum leak...
Check the intake manifold where it branches out going to the idle control valve. Probably when you replaced the filter you disturbed it and it cracked. It brittle with time and heat cycles.
Old 03-07-2012, 02:45 PM
PSUEng PSUEng is offline
Mein Auto: 2007 X3
$126!!! Wow. You can pull that air filter in 5 minutes.
I've been running a K&N panel filter in my 2007 for 20k miles with zero problems.
Old 03-07-2012, 02:54 PM
ngcreese's Avatar
Mein Auto: '11 X3
Bought my X3 with 59K miles on it... after getting past the tranny shift issues. I always noticed misfiring, lack of torque and generally poor acceleration.... up until the 100K point at which I changed the spark plugs, and had a mechanic change my pre-cat O2-Sensors....
The difference? Every see Men in Black when Will Smith went for his first ride-along in what looked like an old government car? But when they started driving... the ride was nuts. That's what the difference was like. Way more torque.
BMWCCA Member
Old 03-07-2012, 06:14 PM
chewchewone chewchewone is offline
Mein Auto: X3
so far i have no problem with FRAM filter installed about 3 weeks ago, it fitted quite well actually.... car has 88K miles
Old 03-08-2012, 10:02 AM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i 2005 X3
I am highly dubious that the Fram filter caused the problem. That being said I always use Mann or Mahle. One possibility is that the rubber duct from the airbox the Throttle Body does have a tendency to devlop a crack, typically where the duct splits and one branch goes to the ICV. It normally cracks on the underside & is difficult to see. The act of moving the upper filter housing could easily open or close the crack.
Old 03-08-2012, 12:14 PM
fhopper's Avatar
Thanks everyone, like I said, I kind'a hope it throws the code again. The car drives great, (I do wish it were a little quicker from 65 to 90 but it sure gets to 65 in a skinny minute). So I suspect several of you are right and we will discover another source of air other than the FRAM.
Old 03-08-2012, 03:32 PM
codog2 codog2 is offline
Mein Auto: 5
There actually is a TSB on non-oem filters throwing a CEL. I think it is for the ones without the foam pad.
Anyway I had put in a STP air filter on my 05 X3 and it never throw a code.
Old 03-08-2012, 07:53 PM
Gee3 Gee3 is offline
Mein Auto: Integra and X3
I've run the Fram filter with the foam on it for some time and no issues. The end near the radiator gets chewed up but that's because it's hard to maneuver the air filter box cover when it's connected to the air duct and the intake hose.
Old 11-20-2012, 09:39 PM
jvest2000 jvest2000 is offline
Mein Auto: 2006 X3
That sounds weird unless it was pulling air from somewhere else (a crack, hole)? I thought the MAF sensor was supposed to account for that?
In any case (for the complete novice) ... here is a link to a handy guide on how to easily change out your engine air filter and some suggestions on good quality OEM German filters that i have used. It's an easy and cheap way to make sure your engine is breathing clean air.
X3 DIY Engine Air Filter Change Guide
That's probably a bit of overkill for most people but i wanted it to be simple enough that anyone could try/do it. Hope it saves you some $$$.
Old 11-22-2012, 08:14 AM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
Fram filters regularly rate very low. They spend all their money on marketing instead of their product. Why try and shave a couple dollars off a low ticket item. Buy an OEM one from Amazon or a discount online BMW oem source. BMW are finicky and partidular about what you implant in them. Don't risk issues.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
Old 11-22-2012, 09:30 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
Originally Posted by x3emist View Post
fram filters regularly rate very low. They spend all their money on marketing instead of their product. Why try and shave a couple dollars off a low ticket item. Buy an oem one from amazon or a discount online bmw oem source. Bmw are finicky and partidular about what you implant in them. Don't risk issues.
+1
Old 11-22-2012, 03:09 PM
todd92 todd92 is offline
Mein Auto: 13 X3 3.5, 05 ZHP
Originally Posted by usaret View Post
+1
Sigh
Old 11-22-2012, 03:49 PM
Allies_X3 Allies_X3 is offline
BMW Rookie
Mein Auto: 2013 BMW X1 xDrive 28i
Seconding Tim Arnold. The y-duct off the main duct seems to tear often and unfortunately you have to take it out to actually see it. The main duct in my X3 looked perfect but the smaller duct was torn.
Allie
-=My Garage=-
2013 BMW X1 xDrive 28i, Premium Pkg, Cold Weather pkg, and Tech Pkg
2006 BMW X3 3.0i, Premium Pkg, Xenons, Cold weather pkg, Nav - RETIRED
2006 BMW X3 3.0i, Cold weather pkg, Nav
2000 Jeep Cherokee Sport
"Well behaved women rarely make history." - Lauren Thatcher Ulrich
Old 11-22-2012, 03:51 PM
BMW Rookie
Might be worth checking to see if you hear a high pitched whistle when you rev the engine. I noticed it upon depression of the accelerator but it only lasted a half a second as the RPMs increased.
Allie
-=My Garage=-
Old 11-22-2012, 06:32 PM
Originally Posted by todd92 View Post
Sigh
I do not understand why stuff like this bothers you so much that you feel compelled to make disparaging remarks because someone's opinion on air filters doesn't jibe with yours.
Or feel the need to call people:
equally clueless.
For wanting to stick with a certain maintenance regime.
If you disagree just ignore it and move on.
Old 11-22-2012, 08:39 PM
The season of goodwill is approaching.
Old 11-23-2012, 11:02 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is online now
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Hard to believe, odd, strange, etc, but it happened to me once. When I bought the X3 back in 2008, Carmax had just replaced the air filter with a non-OEM, the CEL light came on and since it was under the original warranty, I took it to the Dealer, which they replaced it with a BMW one and reset the light. Never came back again. They billed me for the new filter because it was not covered due to non-OEM filter was in.
So yes, I'd stick to OEM air filters.
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 11-23-2012, 12:34 PM
chewywso chewywso is offline
Mein Auto: 2005 x3 3.0, 2002 325i
I had the same lean engine codes. The intake was cracked on the back side of the "y" connection. You should be able to reach and feel it a crack or a hole with your finger. This one went with 120,000 miles @ 8 years. When you buy a replacement ($25 Euro or about $35) you will see why it cracks, when new the "Y" connection is straight and it must be bent to fit the intake. The concern I had was this leak is behind the filter and you are getting unfiltered air directly into the intake. Job takes about 3 hours to do, follow the thread with pics - it is superb. On another note, I do not think you will get a lean condition with a dirty filter - you'd get a rich one. I've run K&N for about 80,000 miles so far.
Old 11-23-2012, 12:46 PM
Madtown Madtown is offline
Mein Auto: X3 Msport, 95 M3 & E39
Fram filters are garbage IMHO. When I owned a Cummins Diesel you either used a Fleetguard or Mopar filter as they could handle the vibration. On the forums many people had issues with Frams failing due to vibration & causing engine damage. Granted the X3 does not create this severe kind of condition but I bet Fram dont do the R&D that is needed to be up to BMW's OEM specs. They design the filter to fit & call it good.
Old 03-14-2013, 07:34 PM
Paule39530i Paule39530i is offline
Mein Auto: 2002 BMW e39 530i
Misleading About The K&N Oil Filter
Hey BeemerHeadz,
Jus wanna give a shout in regards 2 the so called "Million Mile Filter" that ez N question on the forum. Had 1 in my 2002 530i for 2 years, did the research B4 I installed 1. But, started noticin' a decrease in power recently. So, I had a diagnostic performed & found out that the oil, drop-by-drop, over time had build up on my throttle body & caked my intake valves. Both had to be replaced & it cost . I even oiled it ligthly, jus enough to coat the pleats on the clean side as instructed . So, to sum it all up, all U BeemerHeadz out there who is proud to be in the possesion of either a 528i - 540i, no matter what year, do yourself a favor & do not put that oiled filter in you whip. Just think about it, which I didn't do earlier , "Why would U put a oiled filter in an area where it suppose to be dry . I learned the hard way & I'm lookin' out for ya!! As 2 the K&N filter, I give it !!! Now I've installed & have been usin' a Fram CA_5350 Extra Guard filter & it breathe better with no lost of horsepower. I recommend it, it depends on U'r make & model what type of filter to use. Later
