Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 03-08-2012, 11:57 AM
binocs binocs is offline
Mein Auto: 2002 M5 and @000 Z8
Check Engine Light
Hi,
My2002 M5, with 35,000 miles on the clock, check engine light has been on quite a while now. The car runs fine. I took it to the dealer here in PHX and was told that either my cam sensors, the vanos solenoid or the entire vanos system needs to be overhauled. According to the tech the fault codes turned up more than 40 hits reporting vanos error and over 100 hits for the cam sensor. His recommendation was to replace the entire system and be done with it. This doesn't seem right to me. Any suggestions?
Old 03-09-2012, 08:38 AM
Wayne's World Wayne's World is offline
Monkey Wrencher
Mein Auto: 2005 325i Sport 5spd
Sounds like theyre trying to take you for a ride. It is common to have the CPS fail. Id find out which ones as theyre not cheap. As for the VANOS solenoid there is an aftermarket fix and diy for that. Check out drvanos.com. This issue is also well documented on m5board.com.
Sent using BimmerDroid
2002 Sterling Gray M5
'nuff said
Old 03-09-2012, 10:26 PM
GBPackerfan1963's Avatar
GBPackerfan1963 GBPackerfan1963 is offline
Retired Official Welcomer
Mein Auto: 2015 i3, 2013 M6
Buy a Peake Code Reader. Then go to the M5Board.com forum and post your codes.
2015 Arravani Grey i3 with BMW i Frozen Blue Accent / Tera Dalbegria Brown Full Natural Leather Parking Assistance Package
2013 Alpine White Convertible M6 DINAN Stage 1 Black full Merino Leather Executive Package 20" Wheels Comfort Access Rear view camera Bang & Olufsen Stereo
Old 03-23-2012, 05:13 PM
ard ard is offline
Resident Curmudgeon
SPOT ON advice.
The knowledge there is 1 to 2 orders of magnitude past here...
Originally Posted by binocs View Post
Hi,
There are many things it can be, and over on the other board we can go throuhg it...but first"
Read the codes, CLEAR THEM. Drive. What comes back. This is important
What maintenance has been done?
You will probably need: vanos orings ($50 parts, 4 hours); a cps sensor or two,
You might consider: mafs, plugs, O2 sensors, fuel filters...the low miles makes these less of a immediate recommendation.
Go to the other board, it will save you THOUSANDS.
A
Old 03-26-2012, 02:57 PM
///Mdriver ///Mdriver is offline
Mein Auto: 01 M5
My mechanic is in Phx and works on my M5s... give him a shout; Alex at Vaughan Motorworks 602.380.8262. He is a good and honest mechanic. I wouldn't own a M5 if it wasn't for Alex.
Sent from my ADR6300 using Bimmer App
Old 03-28-2012, 09:21 AM
vernon3rdw vernon3rdw is offline
Vito
Mein Auto: 7 series
Hey guys i have a 2008 bmw 750i
I pulled an NO-NO. Last night i put gas in the car while the car was running. I then came back to the car and the engine light came on. Do u guys think me leaving the car running was the culprit?
