Old 03-08-2012, 03:52 PM
dj_2latino dj_2latino is offline
Mein Auto: 2004 X3
Question How To Replace Water Pump
Has anyone seen a good article (with pics) on how to replace the water pump on the X3 (2004-2007)?
Old 03-08-2012, 06:45 PM
Gee3 Gee3 is offline
Mein Auto: Integra and X3
Check out Step 9 in the thread below:
http://www.bimmerfest.com/forums/sho...d.php?t=517819
Step 5 shows you how to remove the serpentine belts. I recommend removing the radiator fan first to give yourself more room to work with. I think one of the steps in the thread also shows this. If not and you have an electric radiator fan there is only one bolt on the left side, a pop clip on the right side and the removal of two electrical connections. Then you can just slide out the radiator fan.
Old 03-09-2012, 06:20 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
Never mind. The above link by Gee3 is better than anything I can contribute.
Old 03-10-2012, 02:28 PM
shendrick shendrick is offline
Mein Auto: 08 M3, 05 e46 zhp, 07 X3
If you are going to keep the X3 and it is a M52/M54 engine (through 2006), you should consider getting a Stewart water pump. Far better than OEM but 2-3X the price. Check out the Stewart site for info.
Old 06-27-2014, 03:21 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
I'm facing this with my X3 but am a bit confused on the pump. If I'm reading this correctly there is a mechanical pump in earlier X3s but an electrical pump on later models
I'm a march 2006 build and think I have an electrical pump?
I'm seriously bummered about the lack of a good manual for my X3. It looks like Bentley isn't going to do this, Alldata doesn't do this, and no way I'm getting into trying to port Windows onto my Macs.
Is the day-by-day subscription the only option right now in 2014?
Old 06-27-2014, 06:34 AM
Mein Auto: 2004 X3 2.5i
Don't think build date within the year matters - you have the M54 engine so you have a mechanical pump.
Fairly easy to confirm that you have a mechanical water pump by looking at the serpentine belt (driving the alternator, PAS pump and water pump).
Should be straightforward to replace compared to the electrical one on the N52 engine.
Old 06-27-2014, 06:29 PM
Thanks super course. I spent 30 minutes with a garden hose listening to the cricket-like chirp and have convinced myself it's the power steering pump, not the water pump.
Finally got SWMBO to gently turn wheel and sure enough cricket chirp changed a bit.
Reading forums PS chirp seems to be chronic but benign Bimmer malady.
Old 06-28-2014, 07:21 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
46 manual
re the lack of a manual ......it's a nuisance .....but .....just plug into the 46 model saloon x drives etc and you'll have the Lions share of what you need
also do the same for internet/fest/youtube vehicle info searches
Old 06-30-2014, 09:45 AM
Thanks swamp.
I did front brakes, rear brakes, and fixed my rear window on my E83 yesterday but can't post procedures/pics for a few more posts yet.
water pump coolant
