Old 05-18-2012, 08:50 AM
jsimon7777 jsimon7777 is offline
Giant Robot
Mein Auto: Scion FR-S
I got this car to drive it quickly in comfort, not to listen to exhaust drone.
2013 Scion FR-S
2007 550i Sport - GONE
2008 528i - GONE
"What are you going to replace your BMW with?"
"Another BMW, with a bigger engine!"
Old 06-11-2012, 07:27 AM
skohler skohler is offline
Mein Auto: 2011 550ix msport
Originally Posted by ArtchredTTU View Post
Ya, unfortunately we do not have this valve on newer 550's. i also checked.
There were a few posts asking if the msport still had this valve assembly and had not seen a definite answer so I went out and looked. '11 550 msport here, I do have a valve that covers the inside exhaust exit on each side. I did as others here have done with removing the drivers side trunk liner and bypassing the black switch. The valves are now both open and the sound is deeper, haven't had a chance to drive much but will report back if drone or other issues come up.
Edit- just noticed this is in the E60 forum, so disregard the above!
Old 06-26-2012, 06:06 PM
Punchy04 Punchy04 is offline
Mein Auto: 05 545i
Anyone know where the vacuum line coming from the engine is attached to the motor? Think I have a vacuum leak too
Old 06-28-2012, 07:26 AM
Giant Robot
It has to be attached to the motor or the rest of the vacuum system. Vacuum isn't magical.
2013 Scion FR-S
2008 528i - GONE
Old 06-28-2012, 07:57 AM
borderchris's Avatar
borderchris borderchris is offline
Was ist los? Der Hund!
Mein Auto: F10 528i
Originally Posted by jsimon7777 View Post
...Vacuum isn't magical.
Is too.
Old 06-28-2012, 02:48 PM
Mein Auto: 05 545i
Smile
OK found a broken vacuum line at the pump. All fixed and mod done
Old 09-27-2012, 07:48 AM
Tatrajaan Tatrajaan is offline
Mein Auto: 545i
No clamp, no zip, no crazy glue.
Here are the pics:
ID:	343445   Click image for larger version
ID:	343446   Click image for larger version
ID:	343447   Click image for larger version
Old 09-27-2012, 10:05 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
Amazing Thanks I will try it
BMW CCA Member, Capital Chapter
Old 10-03-2012, 06:00 PM
phlfly's Avatar
Mein Auto: 07' 550i
I did this as Tatrajaan suggested and work fine, so no check engine light.
Old 10-04-2012, 02:22 AM
volavet volavet is offline
Mein Auto: 2002 M3
Do you have the car running when you do this procedure? And the little connector is something you get at an aquarium store, correct? Thanks.
Old 10-04-2012, 06:00 AM
phlfly's Avatar
Mein Auto: 07' 550i
Do you ask me?
I just same thing as post 82, with car was off, but soon as i turn back on, valve opened.
Old 10-04-2012, 07:01 PM
ArtchredTTU ArtchredTTU is offline
Mein Auto: 550i
Originally Posted by phlfly View Post
Do you ask me?
What year is your 550???
I guess the new LCI 550 doesn't have this vacuum.
Old 10-04-2012, 10:08 PM
Metalcolt Metalcolt is offline
Mein Auto: 2008 M-Sport 550i
Originally Posted by Campfamily View Post
I think I have confirmed that my car (thus, likely any 2008 or newer 550 with the Sport Package) does not have this valve. I am guessing that the valve is removed as part of the special exhaust tuning that BMW claims is included with the Sport Package. So, this mod is already part of our car model.
Anybody else with a 08 or newer 550, please chime in.....
Keith
I have an '08 M-Sport 550i and checked behind the drivers rear tail light; no solenoid or vacuum lines. Also, exhaust is always comming out of both pipes.
Old 10-05-2012, 06:54 AM
nguyendot nguyendot is offline
Mein Auto: 2008 528i
Yeah it seems the M-Sport just leaves it wide open 100% of the time. Still not loud at all compared to my dual magnaflows on the last car.
Old 05-17-2014, 06:58 PM
Barryellis23000 Barryellis23000 is offline
Mein Auto: 2014 550i XDrive
On a 2014 550i do you bypass the vac line from solenoid and that keeps flaps open?
Is it by drivers side taillight in trunk?
Old 05-18-2014, 10:14 AM
6825786 6825786 is offline
Mein Auto: 2004 545 M sport
Hello all,
This is a great way to get that low and rumble! I have a 545 and used the vacuum line process as previously shown, and it sounds fantastic. You not only get the low end melody, but anything above 4k rpm sounds sweet as well!
Old 01-24-2015, 02:32 PM
bagmanindy bagmanindy is offline
Mein Auto: 97 528i, 85 318i, landcru
Smile
I just stumbled across this thread while looking into a muffler delete for my 2007 550i. Went right out in the garage and did it. I found a small fuel filter for a weed eater and cut the end off that hooks to the fuel line. It worked perfect for me. It does sound better at start up already. I can't wait to drive it to see how much better I can hear the exhaust note. I am not going to mention it to my wife and see if she notices.
Old 06-04-2015, 02:07 PM
Michael201193 Michael201193 is offline
Mein Auto: 2007 550i
Tried this today and my valves still wouldn't open. But I can move them manually. Either the flaps/valves are broken or i have a vacuum problem. But the real question is: Do i finx the source of the vacuum problem or do i just use wire and manually open up the valves and forget the leak.
Old 10-05-2015, 11:31 PM
blink2814 blink2814 is offline
Tatrajaan's method works exactly the same for a 2014 550i. Did it in about half hour. The hoses are very stubborn to get off. My question is now that I bypassed the module in the trunk....do you just take the one end of the hose and plug it in to the other end of the module or just leave it all open and hanging? I just left it hanging there open.
I just did it and drove a couple miles, no warning lights or anything weird. Valve is permanently open now on both sides. Low rumble more noticeable, not really a big change so far, but a quick fun project.
ID:	532624   Click image for larger version
ID:	532625   Click image for larger version
ID:	532626   Click image for larger version
ID:	532627   Click image for larger version
