Old 01-18-2012, 06:32 PM
usernamehere usernamehere is offline
Mein Auto: 2007 328Xi Coupe
Anyone ever Plasti Dip their kidney grills?
I'm thinking about just using Plasti dip on my grills rather than buying black ones.
Anyone ever do this? Have any pics of the final product?
Old 01-18-2012, 07:03 PM
gcreese gcreese is offline
Mein Auto: 2010 535i Sports Wagon
The answer is yes. I've seen the posts, but no idea where they are. Try a search. This usually comes up when people are discussing performance grills, so you might try a query mix of "black" "grills" "performance."
2010 535i xDrive Sport Wagon (April 2009): Deep Sea Blue / Cream Beige / Sport, Premium, Cold Weather Packages
2011 335i xDrive Coupe (April 2011, European Delivery): Le Mans Blue / Oyster-Black / M Sport, Premium, Convenience Packages
Old 01-18-2012, 09:05 PM
Thumperx Thumperx is offline
Mein Auto: BMW 335i coupe
I painted mine black. This is great free weekend project. At least an hour of work time, 3-5 hour of drying time (you don't want finger prints on the drying surface), and 5 minutes of placing the grills back. It was quite simple:
  • After removing the grills from the front bumper,
  • I realized the grills come in 2 parts which have snaps around the perimeter to hold them toghther.
  • Undo them.
  • The outer grill is the only item that needs to be painted (you can elect to do the inner vertical slat portion if you wish).
  • Light scuff the surface with 220-300 grit sand paper for tooth.
  • Thoroughly clean surface with wax and grease remover solution.
  • Dry for a couple of minutes
  • Paint outer grill part, black. I used Krylon black spray, and I followed up with Duplicolor's clear gloss coat for wheels. Using this clear coat is formulated spray prevents pitting from the stone and bugs that the grills will encounter. (http://www.duplicolor.com/products/wheelCoating/)
  • Dry (3-5 hours)
  • Place grills back on to car, step back, and admire your work
Once you done it. The once outer chrome part will be now painted black, and in my case, the vertical slats were left alone. From a distance, you can tell, but as you come closer, the chromed vertical slat gives off a subtle accent touch.
Give it a shot.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | OCC | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | 6000k Lamps | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
Old 01-19-2012, 04:52 PM
DontHait DontHait is offline
Mein Auto: 2011 328xi
I used the same process as stated above and here is my outcome. The Plasti-Dip is kind of cool, if you don't like it rip it off and no primer needed. Just clean it off prior to spraying! And most of all, it's self leveling, so it will look like crap when you first spray but as it dries your jaw will DROP
2011 328xi
Old 01-20-2012, 07:19 AM
dmatre dmatre is offline
Mein Auto: 2011 E90 328i
I used Plasti-Dip and if you take your time (remove the grills from the car, disassemble the chrome surround from the grill, sand the chrome, then spray), the results are 100% perfect.
There's no way that I would spend >$10 for black grills, given how easy it it and how good it looks.
Old 01-20-2012, 10:01 AM
nolemike93 nolemike93 is offline
Mein Auto: 2008 335i
I'm looking to this for my jet black 335i. Should I consider a glossy black or will matte look good enough?
Whoa Black Betty bam ba lam!
Old 01-20-2012, 10:23 AM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
Mein Auto: 335i
matte black all the way for long lasting appearance
BMW CREE LED ANGEL EYES ALL BMW MODELS MTEC V3 V4 DTEC V7 V8 V9 V10 V11 V12 V13 RGB V14 NO ERROR
BMW ACCESSORIES and PARTS
BMW LED INTERIOR KITS ALL BMW MODELS
please PM/Email us for Bimmerfest member BMW discount/combo pricing
info@e92-lighting.com "e90post5" for 5% off as the promo code at checkout
Old 01-20-2012, 02:34 PM
Thanks for the info everyone...I'll be tackling this project tomorrow!
Old 01-20-2012, 06:31 PM
There's really no point in sanding. A benefit of plasti-dip is the ability to remove it. If you're going to sand it, you might as well prime it and paint it too
2011 328xi
Old 01-20-2012, 09:30 PM
I like the gloss look.
Old 01-20-2012, 11:39 PM
rdkind62's Avatar
rdkind62 rdkind62 is offline
Mein Auto: 2011 BMW 335is, 2015 X1
Matte black has my vote.
BMW 335is, Cobb tune with VRSF intercooler, Injen CAI, and BMS downpipes. 382/414 rwhp/tq. Le Mans blue with Black Dakota leather, Convenience and Premium packages, 19" wheels, 7 speed DCT, heated seats, Nav., Harmon Kardon Logic 7 stereo w/ Satellite radio. 2015 BMW X1 28iXdrive M Sport, LeMans Blue, with Black Dakota leather, Premium and Technology packages, with heated seats, satellite radio.
Old 01-21-2012, 01:14 PM
How long between applying plasti dip and applying the clear coat?
Old 01-21-2012, 02:03 PM
OK, here's the before and drying process. I'll post once they are dry and installed again.
You'll notice the pitting on the close ups. Let's hope everyone is right and they settle as they dry.
Old 01-21-2012, 02:06 PM
And since I'm sharing pictures...my old rig:
Old 01-21-2012, 02:13 PM
I put on about 4 coats with 10-15 minutes between coats
Also they're holding up great!
And one last, I never heard of clear coating it. I don't think the clearcoat would Adhere or dry properly on rubbery plastidip
2011 328xi
Old 01-21-2012, 02:31 PM
I only did 2 coats....but pretty heavy coats. They've already been drying for a while so I'll see what happens. The pitting is starting to settle.
I prefer the matte look so no clear coat or anything.
Old 01-21-2012, 02:35 PM
The clear coat is a protectant. It doesn't make matte glossy.
Old 01-21-2012, 02:39 PM
AH...and it adheres OK?
Old 01-21-2012, 02:44 PM
Old 01-21-2012, 02:48 PM
I'm not saying that putting clear coat is a bad idea, but my plasti-dip saw the wrath of october snow for over an hour long drive, tons of rain, miles of highway and hasn't chipped or even show any signs of wear.
2011 328xi
Old 01-21-2012, 02:53 PM
Cool...I'm just gonna put them back in with only the Plasti Dip. They're starting to look better and better the longer they dry.
Old 01-21-2012, 03:41 PM
Yup, don't forget to post pictures! =) i waited <4 hours for them to dry, giving that it was a rather warm, dry day
2011 328xi
Old 01-21-2012, 04:05 PM
I took them inside. I'll probably let them dry overnight. I screwed one up and it chipped when I was moving it and had to re-paint it. Now there's a big goo spot so I may have to redo the one side.
Will keep you guys posted.
Old 01-21-2012, 04:42 PM
I've got almost one year and 10k miles on my Plasti-Dipped kidneys. They've held up great, no stone chips, no fading, no problems.
The Plasti-Dip does have a slight texture to it, but you only notice it from within a foot or two. Anything farther than that, and you never notice it.
Old 01-22-2012, 06:42 AM
Here's are the finished results:
This is the section I screwed up...I hit it while it was drying and took a piece off. Tried to repaint over the bare spot but you can see where it didn't even out.
