Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 03-10-2012, 01:45 PM
BlackonBlackM3 BlackonBlackM3 is offline
Mein Auto: 1997 BMW M3
Pan gasket oil leak.
I guess I have an oil leak coming from my pan gasket... Does anyone know how much that will be to fix?
Old 03-10-2012, 08:07 PM
VANNYBABY VANNYBABY is offline
///M POWER
Mein Auto: 1999 BMW ///M3
A new gasket should do you just fine! About what $35???
Old 03-10-2012, 08:22 PM
Really that's it? I called the BMW dealership and they said parts and labour $550
Old 03-10-2012, 09:56 PM
///M POWER
I'm guessing if the oil is leaking from the rim of the oil pan. If it's leaking at the drain plug, you probably need a new rush washer that goes over the drain plug at every oil change. What did the BMW dealership say it was??
Old 03-10-2012, 09:58 PM
///M POWER
$21.57 for oil pan gasket at Autuhaus AZ.
Old 03-11-2012, 04:43 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Parts and LABOR.
You have to drop the front cross member to remove the pan.
You can DIY, but some special tools will help, like a topside engine support.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
