E46 (1999 - 2006)
Old 03-10-2012, 07:49 PM
iggy119 iggy119 is offline
Mein Auto: 2004 330xi
Question Power Steering Fluid Level
I just purchased a 2004 330xi and the previous owner knew that there was a power steering hose that was leaking. I wanted to check to see if the car is low on power steering fluid however i am not too familiar under the hood of this vehicle yet and i dont have an owners manual. So my question is how and where do i check the power steering fluid? is it the cap marked ATF 4? and where should the level of the fluid be at?
Old 03-10-2012, 08:25 PM
ckleung100 ckleung100 is offline
Mein Auto: '99 323i
The pictures are from KrisL's DIY. Checking the power steering fluid is just like checking engine oil. The level should be between the two marks.
Name:	power steering.jpg
ID:	315942   Click image for larger version
Name:	power steering2.jpg
Old 03-10-2012, 08:48 PM
Thanks! that answers my question completely
Old 03-12-2012, 11:31 AM
Gaza77 Gaza77 is offline
Mein Auto: Burbank, CA
iggy119,
What are you going to do about the possible leaking hose? Are you going to attempt to replace it yourself, or put it into a shop? I'm curious because I think I might have the same issue. I'm investigating. Wanting to know if I should attempt to tackle it myself.
Cheers,
William
Old 03-12-2012, 02:05 PM
Well I'm not completely sure what I'm going to do yet, I had a shop quote me 150 total for parts and labor but at the same point I can get the hose and do it myself for 30 or so. So I'm debating but it seems like the shop might be the better bet since I'm not too familiar under the hood of my bimmer yet
Old 03-12-2012, 02:21 PM
moiz21's Avatar
moiz21 moiz21 is offline
Mein Auto: '99 323i 5-Spd
Neither was I when I first got mine. I wasn't familiar with any car to be honest. But ever since I got mine I've been tackling all the maintenance myself as well as my family's other vehicles. It's a lot easier to work on these cars than you might think at first.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S/ 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
Old 03-13-2012, 11:02 AM
well that gives me a little hope then! I'll probably venture on under the hood here this weekend and see what i can do
Old 04-24-2012, 10:47 AM
Turns out that my leaks were caused not from bad hoses, but the clips were bad or you could say loose. Maybe they are called clamps. Anyway, I replaced them and now the leak is gone. These are like $2.00 clips/clamps. Takes more time to look and discover what's really going on, but some much cheaper. Hope that provides a little insight.
Cheers,
William
Old 04-24-2012, 11:03 AM
Spikes007 Spikes007 is offline
Mein Auto: 02 325xi ZSP
Cheers,
William
That's the kind of post I like to see.
You can save tons of $$ by doing jobs by yourself. Of course it will take time but if you like your car it shouldn't bother you.
English is not my first language. Sorry for the mistakes.
