Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 03-13-2012, 04:28 AM
kaos_325i kaos_325i is offline
Mein Auto: 1994 325i sedan
Boosted Tuning for BMW's
Hello all
I am a new owner to bmw, and my e36 325i, I am just wanting to know from the people that are boosted, what means of tuning they are using?
What is the most commonly used/easiest means of tuning used in bmw's?
My long term goal for my car is 350-400rwhp, but I won't be able to even think about this for a year or two so in that time I want to research and learn as much as I can.
Thanks ahead of time for any info that you all can share
Old 03-21-2012, 09:35 AM
bimmerguy055's Avatar
bimmerguy055 bimmerguy055 is offline
Send a message via AIM to bimmerguy055
Mein Auto: turbo'ed 3'er
its unfortunate that no one has replied to you. here is my thread on my the turbo kit I made my self. good luck. http://forum.e46fanatics.com/showthread.php?t=806066
"without failure there is no success"
Top-mount turbo + meth
Old 08-03-2012, 07:49 PM
imp.the.dimp imp.the.dimp is offline
Mein Auto: 2000 528i
I might not be the most credible source but basically there isn't much in the way of tuning methods for BMW. The general concensus is that megasquirt and vems are your best options for engine management, but there have been whispers of safc's being used. I think you have obd1 not obd2 which makes things easier, but you will have to ask someone else about that.
Old 08-04-2012, 01:50 PM
Ultimately it depends what your goals are besides the hp. For example, is the car a DD? do you care about having SEL's, traction control, etc on the dash?
I know of only the few that had used a m52/4 engine to run MS3. Its not for the faint at heart. you have to understand that EMS's like mega squirt may be cheap solution saving you money, but you have ALOT of R + D to get the engine to be happy (switching sensors over to GM, etc) and even more time into keeping the dash lights off (SEL, DSC,yellow brake light etc.) again depending if this car is used as street car or track and/or if you don't care about those things. after thinking about these variables and overcoming them, you would obtain an extra DME and connectors to make your own piggy back to "try" and keep the DME happy by controlling the dash, and various sensors. I was going to personally take this route due to tight budget, but after looking at what I said above, no way. Realistically it would take a year to figure out the EMS to work decent with the DME, and thats if you know your stuff, according to a guy who swapped a m54 into a e30 who ran MS.
Other option is to get your stock ECU tuned, I know a guy in NY-NJ area who actually can do this, other than the "nick g" guy in FL who is a joke. here is the info http://www.f1tuning.com contact
Tonino Petrolo
516 807 3983
tpetrolo@f1tuning.com
OR you can go with Pro EFI, which is the best EMS that I know of, and is Plug N Play, has alot of features, and it can keep all the warning lights in the dash OFF! I'm currently runing it now, Great EMS. it may be a little pricey up front but well worth in the long run.
Your welcome.
Old 09-17-2012, 09:15 PM
CleanE60's Avatar
CleanE60 CleanE60 is offline
Mein Auto: 2010 535i xdrive
There's no hacks for the older obd1?
Keep it clean!
