E90/E91/E92/E93 (2006 - 2013)
Hi, I was just wondering what all of the E92 335i owners have to report about this car? I am really excited about my opportunity for this to be my first machine, and I had a few questions. What kind of mileage are you getting? How often did something large as in expensive break? I will be performing all of my work myself but i can't be spending thousands on parts. Also what is the deal with the oil coolers? If i have a 6spd manual, with a oil cooler, will I have any issues? I do plan to track the car when I turn 18 and what would you recommend in terms of performance upgrades beyond stiff suspension? What performance mods are less that 1k and good for everyday driving and having a little fun on the streets? I know this car is fast, but I drove a sl55 amg last month and it changed my perspective on speed. Also what is faster a E90 or a E92? Or are they relatively similar? Thank you for all the advise in advance!
Whats faster e90 or e92?? The hits keep coming around here.
Your information is all over this forum if you search. It is easy.
To answer you question about things breaking.......Anything that breaks is expensive. Maintenance is expensive. For example, if you need an water pump and thermostat (which seems to last around 60K miles) you can buy them for about $550 from Tischer or $750 from your local dealer, not including installation. Spark plugs require a special $45 socket and cost around $22 each. Run flat tires are around $300 each. It goes on and on. Overall, it is a reliable car though. And if you want to do a lot of maintenance yourself you should have a tool like barvarian technic for diagnostics and initializing new components like the battery believe it or not. The computer needs to know when you install a new one. I have to ask though. You aren't 18 yet and you have this car and evidently test drove an AMG. Aren't your parents worried that you might kill yourself? Both are way too much car for an inexperienced driver. No offense, I am talking from the point of view of a father who remembers my first couple of years of driving. |
http://www.bimmerfest.com/forums/sho...27&postcount=1 |
Sorry. I read both but didn't connect the two...
I just picked up a new OEM water pump from wold pac for 375. The spark plug socket is just a 12 point 14mm which you grind down the sides on making a 3 dollar tool and I got a set precision sports for 650 all 4. And I have driven lots of nice cars and my parents realize that I am responsible. I know my limits and they are way more concerned about the fact that I have my pilots licence. Cars are only as dangerous as you make them. And I may be slightly inexperienced but I've probably driven close to 15k miles this year. I'm new but I'll just take it easy till I get the feel of the car.
Sent from my WX435 using Bimmer App |
Haha amen to that
Thank you for clarifying
For maintenance
Google the Mike Miller maintenance schedule. google Mike Miller BMW
The turbo hardware and injectors seem to be a common thing that eventually needs to be replaced or changed . The most informative sourcre of e9x material Is found in the following link. http://www.e90post.com/forums/forumdisplay.php?f=16 Do you own a body shop?( I saw the picture how are you straightening that thing out.) My Indy put redline D6 in my manual it smooths shifts out a lot. Last edited by ctuna; 03-14-2012 at 09:49 AM. |
Can do! Thanks for the link! And no I am only 16, I work at my dads shop. We don't really do body work but he let's me use a alignment rack on Sundays. This isn't the first one I've done, just the first one for myself.
Also using the alignment rack and hydraulic rams to straighten all the rail and what not.
Setting up for track use costs....expect $7500 in parts to really do the job. Saw the pic - you may have some cosmetics to fix, possibly mechanical. Hey, you're replacing parts anyway....keep us posted! You might want to visit n54tech and e90post. Last edited by CALWATERBOY; 03-14-2012 at 10:05 AM. |
You will want to do the CDV valve delete.
google it the retrofit part is only 25 bucks, Can also be found in the other links. |
Just wondering what's a cdv valve?
Diverted valve??
Search these here forums for "clutch delay valve." Millions of posts about it.
BMW CCA Member |
| Bookmarks |
| Tags |
| 335, brakes, jb4, oil cooler, suspension |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
