Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 03-14-2012, 07:53 PM
Ligament Ligament is offline
Mein Auto: NADA
335d: DTUK CRD-T Vs. JBD box?
It seems the DTUK-T is a better option as it is a two channel system controlling fuel throughput as well as turbo boost. DTUK is manufactured by DTE in germany which has years of diesel tuning experience for multiple auto manufacturers. JBD only controls fuel, does not control turbo boost, and JBD makes only one module for this one engine.
I could be wrong, please enlighten me. I have been considering buying both myself.
Old 04-17-2012, 05:25 PM
Stugots's Avatar
Stugots Stugots is offline
Speed Demon
Mein Auto: '10 335d E90
This is a tune I've been using for some time now, and it's my tune of choice at this point, fwiw.
Old 04-18-2012, 03:15 AM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
Stug, which version are you using? They show 3 with the top one controlling both CRD and Boost. They offer 4 different mappings for this version, so which do you choose? How do you order and take delivery stateside?
Curious minds want to know!
Old 04-18-2012, 07:23 AM
3ismagic#'s Avatar
3ismagic# 3ismagic# is offline
HerrDoktorProfessor
Mein Auto: '11 335d
Indeed we do.
Entertaining America Since 1975
European Delivery July 26th 2011
ED Video: https://vimeo.com/60051914
ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294
335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns
BMWCCA #448878
Old 04-18-2012, 08:28 AM
Stugots's Avatar
Speed Demon
http://www.diesel-performance.co.uk/...ails.php?id=10
And technically, there are 28 maps (each of the 4 maps has 7 different settings).
Regarding ordering, just talk to Andrew/work through the site, and they'll get you taken care of. Tell Andrew that Ronin sent you if you happen to pick one up.
Old 04-18-2012, 09:10 AM
cssnms cssnms is offline
Mein Auto: '11 335d
Controls turbo boost? What is this box connected to when installed? I want to see a picture of the installed box.
Mein Auto: '11 335d
Why?
Old 04-18-2012, 09:13 AM
Mein Auto: '11 335d
Found this on their site which seems to answer the question.
"Unlike our other common rail modules, GREEN, RED, CRD2, that only connect to the common rail pressure sensor, the new CRD-T also connects to the turbo pressure sensor, allowing us to control and increase the boost settings. This results in an even smoother power delivery, and even lower emissions and even more power and torque."
My question is where is the turbo pressure sensor connection exactly?
Old 04-18-2012, 04:01 PM
Stugots's Avatar
Speed Demon
If you're facing the engine from the front of the car, it's at the front of the engine bay (by the firewall), pretty much in line south of where the last cowl screw is.
Why?
It's the only piggyback tune that hooks into the boost sensor, as well, it has 28 maps to choose from (in this respect, DTUK > JBD > VAC), and it feels more powerful than the 3 I have (and yes, I've done back to back to back comparisons).
My next goal, when I can actually find some time, is to dyno the car with each of the 3 modules, and then I'll have hard data to support what the butt dyno is telling me.
Old 04-18-2012, 05:07 PM
Mein Auto: NADA
I have nowhere near the experience with other tune boxes as Ronin, however after three weeks or so I am very happy with my DTUK CRD-T tuning box. I have spoken at length with the DTUK GM Andrew, and am pleased with customer care and support. My 2011 335d is doing great.
Subjectively, of course, it appears turbo lag is 90% reduced. Power output feels about 30% better across all RPMs. I have not dyno'd it yet so take my claims with a few grains of salt.
Old 04-18-2012, 06:05 PM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
And some Tequila!
It sounds fantastic, too good to be true?
It certainly makes sense to control both fuel delivery and charge air pressure.
They mention a new model with 3 channels, or am I getting confused already?
Old 04-18-2012, 06:07 PM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Ligament, how do you boost your NADA?
Post your ride already.
Old 04-18-2012, 06:13 PM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Why don't they show the Dyno graphs for the 335d?
BMW 335D 286PS - 340bhp and 508.5lbft (687nm!!!!)
What are they hiding?
Stugout/Ligament, any codes or limp mode with this?
Old 04-18-2012, 06:20 PM
Stugots's Avatar
Speed Demon
Limp mode can happen, yes. Running Map 3 at Stage 7 (30%) will trigger limp almost 100% reliably under WOT. Depending on conditions, Map 3 Stage 6 (20%) will do the same (interestingly enough, only under intense acceleration going from 2nd to 3rd). I can reliably run Map 3, Stage 5 (10%) without concern for limp, and a massive increase in power and torque.
Codes that can pop up (and will, generally, with a tune) when this happens fall along the lines of Rail Pressure Plausiblity, but I've also seen Air Mass Sensor and Gas Pressure Sensor.
Old 04-18-2012, 06:46 PM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Last thing I want when trying to spank something is to have the engine go limp! That's embarassing.
Do you just have to shut off engine and restart it to reset?
Would a code tool with a reset feature resolve it on the fly?
I emailed Andrew to see if he would send me the Dyno Graph missing from their website.
Looks promising, like the concept vs a reflash of the ECU.
Old 04-18-2012, 07:05 PM
julesandtrish julesandtrish is offline
Mein Auto: 2010 335d
A few questions guys:
1. How is the turbo lag reduction on the dtuk compare to the jbd?
2. How easy is the dtuk to install compared to the jbd?
3. Are you able to clear the tuner codes when they are triggered by the dtuk unit?
4. When you say power output feels about 30% better is that compared to the jbd (at which setting on jbd) or stock?
Thanks.
Old 04-18-2012, 09:33 PM
Mein Auto: NADA
Thanks.
I have no experience with the JBD so cannot comment on 1-2.
Yes I've been able to clear the codes.
Power increase compared to stock. I have not dyno'd the car with the DTUK so be careful how you interpret my subjective reports of increased power.
Old 04-19-2012, 07:00 AM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Here is their Dyno Graph on a 335D. I assume this may be a EU Spec, not US Spec.
Still reseraching asking questions. Comments?
Old 04-19-2012, 07:39 AM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
DTUK also sent me the four programming profiles for the US Spec version of their tuner.
Not sure I understand it but here it is.
Old 04-19-2012, 07:54 AM
Mein Auto: NADA
Ok, so this is the MAP profile I have. I am using Map 1 at +20% currently.
I suspect Ronin and I have our MAPS stored in different banks.
Old 04-19-2012, 08:05 AM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
I can't really read the maps very well.
What are the other three maps then if the first is 20%?
Do you know what the red and yello lines represent? I'm assuming one if fuel rack position and the other is turbo boost.
Old 04-19-2012, 10:13 AM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Here is the response from DTUK.
The four settings represent 10%, 20%, 30% and 40% gain on the output signal to the fuel delivery and turbo boost. Signal is in 0.1V (volt) increments.
Sounds simple enough.
So, is it any better than what the others are offering? Cost is around $550 delivered.
"The 4 programmes are what the box adds when the setting is set on zero.
horizontal axis is the range that the sensors work within.
red line is extra fuel, yellow is extra boost.
when you move to + 1(10% or 2(20%) ure actually adding 0.1v to the additional voltage already added by the system on zero setting."
Old 04-19-2012, 11:00 AM
Stugots's Avatar
Speed Demon
Thanks.
1. Turbo lag reduction is about the same in 1st and 2nd, but the DTUK seems to pull stronger throughout the range overall. There is still a hint of lag on WOT from a dead stop, though, and that is consistent across all of the piggybacks I've tried.
2. Because of where the boost sensor is, it really isn't all that difficult. You just have to thread the second part of the cable so that it's not restricting anything end not in the way of moving parts.
3. Never had a problem clearing codes with my BT
4. He's comparing to stock. The difference between JBD and this probably isn't that dramatic, but without solid #'s, that's a hard question to answer otherwise.
Yes, but you can shut off the engine while driving and start the car back up (press and hold your Start/Stop Engine button for about 3 seconds to shut off the car, then press it again to start the car again...limp mode gone, but if an SES is triggered, that will remain).
I don't think any code tools reset on the fly (could ask Mike at N54 about whether or not the Can Tool does).
Old 04-19-2012, 11:01 AM
Stugots's Avatar
Speed Demon
Attachment 321515
I'd be interested to know which map that's on, actually. The reason I ask is because I've had the car dynoed (HP only) with the DTUK tune, and I peaked at just over 365HP.
Old 04-19-2012, 12:17 PM
jashearer jashearer is offline
Mein Auto: X5d, CTS-V, Silverado HD
Was the 365hp using a guestimated parasitic loss to get back to crank hp? Surely that wasn't at the wheel???
If so I need one of these ASAP
Jay
Herbert - '12 X5 35d / Sapphire Black / Black Perf Nevada / Aluminum trim / ZPP / ZPS / ZCW / ZAV / Apps / 3rd row
Betty - '04 CTS-V / Black Raven / Black Leather & Suede / 6 speed LS6 combo 400 hp & 400 tq
Sterling - '06 Silverado HD / White / Grey Leather / LBZ Duramax - Allison 6 speed combo / Crew Cab Short Bed LT3
HTML code is Off
