Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 05-01-2012, 11:53 AM
hotrod2448 hotrod2448 is offline
Mein Auto: E70 X5, E90 335d
Originally Posted by János View Post
I also recall seeing an animation somewhere, but couldn't find it. This is a good document however; on page 14 it shows several illustrations of how the two turbos work together.
That is a really good document. Thanks.
Old 05-01-2012, 04:52 PM
62Lincoln's Avatar
62Lincoln 62Lincoln is offline
Mein Auto: 335d
Originally Posted by Snipe656 View Post
Looking past that page in that document it looks like the small turbo is on standby for most of the rpm range and the big one does the bulk of the power making.
Isn't the purpose of the smaller turbo to be ready for "immediate" power at the bottom of the power range (because it spools up so quickly)? And then the larger turbo, as you mention, does the heavy lifting beyond that point?
Old 05-01-2012, 04:56 PM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
That is my understanding and the document appears to support that.
--Aaron
Old 05-02-2012, 04:04 PM
Stugots's Avatar
Stugots Stugots is offline
Speed Demon
Mein Auto: '10 335d E90
Originally Posted by Terry @ BMS View Post
Hi Ronin!
Long time no talk. For the JBD we used the dynojet at specialtyZ. You can not compare results from that dyno to another, especially a non-dynojet, as they will vary greatly. If you'd like to get together again at specialtyZ I'd be happy to pay for a dyno comparison of the systems. The JBD is a quick install easy to use type product so we've never been going for the most power with it. But if there really is something else out there making 30hp+ more (which I doubt) even if the install is more involved I would be very happy build a better mouse trap for you more serious guys. We're also working on a D meth kit currently.
Terry,
You know me...I'm always open to suggestions and options. No need for you to pay for the dyno...I'd be happy to throw up the car and the tunes for comparison. I still love the JBD, fwiw, and I still consider myself a very happy owner.
When it comes to the Meth kit, make sure to remember me when it comes time to test it. I have no problems driving up there and getting things set up.
Old 05-02-2012, 09:34 PM
Terry @ BMS's Avatar
Terry @ BMS Terry @ BMS is offline
Mein Auto: I hate PM. Email me!
Originally Posted by Stugots View Post
Terry,
Sounds good! FWIW I'm not trying to come down negative on the DTUK I'm sure it's great too. Just want to make sure people who have not tried either are evaluating them on their merits as much as possible. I'll let you know when the meth kit is ready. To be candid it's been bumped a few times on the priority list for various projects like the N55 OCC, N55 intake, N20 tuning, C250 intake, etc, but it will get done sooner or later.
http://www.burgertuning.com
Old 05-03-2012, 01:03 PM
Stugots's Avatar
Speed Demon
No worries...we're a patient bunch. And I've never spoken ill about the JBD. As I said above, I still find it an amazing solution to getting more juice out of our diesels, and I still recommend it frequently.
Old 05-03-2012, 03:12 PM
NotNormal NotNormal is offline
Mein Auto: BMW 335d E92 MSport
Originally Posted by Flyingman View Post
Here is their Dyno Graph on a 335D. I assume this may be a EU Spec, not US Spec.
Still reseraching asking questions. Comments?
Attachment 321515
Hey, new to this site, but hopefully I can help you out here
Thats my dyno graph, and yes, my cars a UK spec car
Running map 3 at 10%
I'd be interested to know which map that's on, actually. The reason I ask is because I've had the car dynoed (HP only) with the DTUK tune, and I peaked at just over 365HP.
Map 3 @ 10%
So which setting seems to not pull any codes or limp mode? I assume it is kind of like the JDB where if you dot get too greedy with the settings then fear of codes/limp should be nonexistent.
As above, I run my car on map 3 @ 10%, code free....tried map 1 at 10% and it was fine, map 1 at 20% was ok .... Only had one reduced power mode, 4 people n the car, hot day, very very heavy loading in 5th gear from low revs
I've nt tried the JBD unit, but I have run the DTUK single system back to back wit the CRD-T system, but very capable and reward you with impressive power gains.
I kept the CRD-T system, it felt alittle sharper, and alittle crisper .... A more remapped feel to the drive of the car.
I'd be be interested in comparing the CRD-T unit I have against the JBD system....as I've done 60,000 + miles in this car on the CRD-T system, and feel I know it quite well. A comparison would be interesting
If anyone has any questions please feel free to ask, if I can answer, I will....
Regards
Tom
Old 05-04-2012, 07:04 AM
Axel61's Avatar
Axel61 Axel61 is online now
Mein Auto: 335d
@NotNormal WTF a whole lot of miles of fun traveling wow. I have put 13k in less than year here in Puerto Rico thats 100 miles x 35 miles LOL. Sorry I love driving my DIESEL!!! Anyway finally people are coming to grasp at the potential our BEASTS have and are being unleashed. I am happy the RENNtech flash I have. I almost bought Terry's product which BTW my mechanic here in Puerto Rico sells alot. I support RENNtech's product as well as Terry's and anyone who tries to make our babies drive how they were intended to be driven.
Old 05-04-2012, 07:06 AM
cssnms cssnms is offline
Mein Auto: '11 335d
Map 3 @ 10%
Regards
Tom
Hey Tom,
Glad to see you found the "other" site!
On your dyno, did you get a bseline? Peak hp # mean little since every dyno spits out different peak hp numbers where some read higher and some read lower. I am interested in are gains from the baseline on the same dyno.
Guys - Tom is the guy that ordered the EGR by-pass for his d. Looking forward to seeing how that goes.
Old 05-04-2012, 11:21 AM
Hey, sadly no, I've not got the baseline HP figure to hand....next time I go past the dyno place I'll pop in and find out the uncorrected figure
Egr pipe....arrived today but I wasn't around when the postman came, collecting it for the sorting office tomorrow
If I get chance I'll set too fitting it .....
Old 05-07-2012, 05:33 AM
Axel61's Avatar
Mein Auto: 335d
Kepp us informed amigo
Old 05-13-2012, 01:34 AM
Sorry folks, it's been a while ..... I would have liked this fitted and sorted by ow but the pat week I have been quite ill.
Starting to feel better now, si I'll set to fitting it this week
Tom
Old 05-19-2012, 09:02 AM
Well....fitted my EGR blank, effortless and simple, as expected.
Done 60 miles or so, stretched my cars legs alittle .... First impressions, marginally quicker spool, seems alittle stronger midrange and has a crisper more constant feel to the power delivery top end too
The shock so far, no engine management light. Although, I'm sure that'll pop up in due course haha
Booked in for a remap on Thursday, so I'll see what that yields !
So far so good....
Old 05-19-2012, 10:37 AM
bigjack bigjack is offline
Mein Auto: 2011 BMW 335d M Sport
Thanks, keep us posted...! Hope you are feeling better.
Old 05-19-2012, 01:58 PM
Mein Auto: '11 335d
Hey Tom,
Thanks for the follow up! Did you install or did a shop do that? Can you walk us through the install process?
Also can you post up the link for the part that you purchased?
Old 05-19-2012, 03:53 PM
Thankyou, yes, feeling allot better
Done about 100 miles now, mixed driving, from town stop start to high speed hard acceleration too.
No lights as yet.
Originally Posted by cssnms View Post
Hey Tom,
Hi, yes, sure, I fitted it myself.
Not at all difficult ... One bolt was alittle awkward/fiddly button stress.
*remove engine cover
*removed the central air duct above radatior
*release boost hose from throttle body
*disconnect electrical connector for throttle body
*remove three torques screws (t30)
Throttle body comes off at this point
*undo the jubilee clip on the left of the egr valve
*remove vacuume pipe on right of egr
*undo four 5mm allenkey bolts holding egr on
At this point you have an open inlet manifold and are ready to fit the egr removal pipe
Clean the faces of any oil residue
Refit the egr blank in the reverse process of the above
Please note, you will loose one of the mounting points for the engine cover, but fear not, it doesn't effect it in any way. There are enough bolts on the engine cover to keep it secure and you'll not have any rattles.
Here is where I got my kit from :
http://www.ebay.co.uk/itm/BMW-E60-E6...ht_2013wt_1501
It comes complete with bolts ect... But tbh, I felt more comfortable reusing the standard BMW bolts
Any questions, please feel free to ask.....if I can help, I will .....
Old 05-20-2012, 05:31 AM
Mein Auto: '11 335d
Tom -
Many thanks. Needless to say this is promising! Unfortunately we don't have a tuner here stateside that can code for this (yet). Maybe Evolve has something? But perhaps based on your experience so far it is not needed. Iwould be interested in seeing if your light ever does come on. I realize you are taking the car in to have it tuned for this but man wish I could convince you to drive it another 500 miles or so to see if that damn ses light ever comes on
Is the part sold by the same guy I spoke to a while back and is this part different then the one I was looking at?
Chris
Old 05-20-2012, 08:20 AM
Chris, yes, same bloke, but it's listed for a different vehicle
His English is appalling but his product is good.
The item I linked you to is the one for the 335d
I'll have covered more than 500 miles before I t ale my car in. At the moment, if all stays the same, I'll not bother with the remap at this rate. We shall see ......
Old 05-20-2012, 09:37 AM
62Lincoln's Avatar
Mein Auto: 335d
Here's some info from BMW on the EGR in the U.S. E90:
Compared to the European version, the high pressure EGR is equipped with the following special features:
• Electric EGR valve with positional feedback
• Temperature sensor before high pressure EGR valve
• EGR cooler with bypass.
The electric actuating system of the EGR valve enables exact metering of the recirculated exhaust gas quantity. In addition, this
quantity is no longer calculated based solely on the signals from the hot-film air mass meter and oxygen sensor but the following
signals are also used:
• Travel of high pressure EGR valve
• Temperature before high pressure EGR valve
• Pressure difference between exhaust gas pressure in the exhaust manifold and boost pressure in the intake manifold.
This enables even more exact control of the EGR rate. The EGR cooler serves the purpose of increasing the efficiency of
the EGR system. However, reaching the operating temperature as fast as possible has priority at low engine temperatures.
In this case, the EGR cooler can be bypassed in order to heat up the combustion chamber faster. For this purpose, there is a bypass
that diverts the flow of the exhaust around the EGR cooler.
This bypass is actuated by a flap which, in turn, is operated by a
vacuum unit. The bypass is either only in the "Open" or "Closed"
position.
Those first 3 items (electric valve, sensor, cooler) make me believe that our EGR is significantly different from the Euro EGR, so we need to tread carefully. I have an image of our EGR part (including the cooler), but I haven't been able to figure out how to get it posted yet.
Old 05-20-2012, 10:25 AM
62, post that image.....upload it to a photobucket account or similar
I'll have a look and compare with my euro version
Old 05-21-2012, 12:37 AM
This is the installed item :
As you can see, the throttle body, vacuum pipe and exhaust feed pipe are all still connected and mounted securely
Although the last two have no functionality any longer.
Old 05-21-2012, 07:53 AM
62Lincoln's Avatar
Mein Auto: 335d
I'm working on the image, in the meantime, here's a comparison (from realeom) between the U.S. and Euro setups:
U.S.:Euro:
In both drawings, the EGR valve is just aft of part number 7. They appear very similar, even though the U.S. has much more "junk" upstream of the EGR (that's the cooling thing mentioned in my earlier post).
I'll get the drawing from the BMW book up soon.
Old 05-21-2012, 07:55 AM
62Lincoln's Avatar
Mein Auto: 335d
Here's the image of the U.S. EGR and its associated plumbing from the BMW manual. The final drawing is the accompaniment for the final 2 paragraphs from my earlier post.
Old 05-21-2012, 08:09 AM
62Lincoln's Avatar
Mein Auto: 335d
Found these images of the EGR valves themselves on realoem (part number 1 in both images):
U.S.: Euro:
Old 05-21-2012, 12:47 PM
62lincoln, if your egr has the throttle flap and stepper motor in one, then the kit I links above is of no use to you
If the egr is separate to the throttle and is vacuume controlled rather than electronically controlled then it'll be a simple and painless mod to do.
If your egr has electronics directly on it, and/or is part of the throttle flap, it'll be more difficult
Take an actual picture of your set up n your car
HTML code is Off
