Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 03-20-2012, 03:24 PM
tom @ eas's Avatar
tom @ eas tom @ eas is offline
european auto source
Mein Auto: BMW
eas | EDC Elimination Coding for aftermarket coilover Suspension systems
Through a joint venture with the Autologic team, we are now able to properly remove EDC coding for those that have upgraded to aftermarket coilover setups.
Supported Coilover systems include (but not limited to):
- Bilstein PSS10
- KW Suspensions (not required on Sleeve-over kits)
- Moton Street Sport
- AC Schnitzer Racing Suspension
- RD Sport/Racing Dynamics Chassis Kit
- AST 4100/4200, 4150/4250
- Ohlins
- JRZ
Coding eliminates the need to purchase external code isolator kits, which can look unsightly under the hood and get extremely hot after extended use. For those not local to our facility, the Macht Schnell EDC Emulation Module will keep the hood clean from unsightly external resistor packs and produce zero heat, as emulation is performed digitally instead of using resistance.
Coding can be reinstalled at any time if you should change your mind in the future.
If we can save money, we'd like to pass along those savings to you. All EDC-equipped coilover installs now include EDC coding removal at no additional charge, allowing you to pocket the additional savings.
