E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
How to replace Thermostat e-60 (535 xi)
Just finished replacing the thermostat in my 535 and I am sharing learnings.
Expected time to perform for home mechanic: 2 hours. Pro: 1 hour max. Thermostat is located in the non-driver side below the engine. Procedure: 1- rise your car so you can reach all the lower splash panels/cover in the bottom of the car 2- secure the car so it does not move 3- take out front and back splash (around 20+) screws 4- remove lower protector plate ( 6 big bolts). You will need air powered tools or heavy and good wrenches. 5- remove bolt and move hydraulic hose to the left so you can make room. 6- remove hoses from the thermostat 6.1 - start removing the ones that have the secure wire to keep them in place. Take out the wire lock (you can pry it with a small screwdriver) and then pull the connector out of the each one. (you can drain your system at this time :-) ) thus, have a handy container to collect the cooling fluid. 6.2 - remove the 2 bolts that keep the thermostat in place 6.3 - pull the thermostat to the side so you can see and reach the other 2 hoses 6.4 - gently unscrew the clamp that holds the small hose - fluid will drain when you remove the hose- and then pull to the side to remove the hose. 6.5 - gently unscrew the clamp that hold the big hose - fluid again - and with one hand reach the hose from the back of the frame and pull with your other hand the thermostat. Installation procedure is the opposite. good luck!. |
| Bookmarks |
| Tags |
| change, procedure, replace, thermostat |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
