Old 03-20-2012, 06:34 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Sylvania/Headlight restoration kit with UV clear coat (Review)
http://www.autozone.com/autozone/acc...er=272381_0_0_
Okay here it goes.
I was able to get it at Autozone for $20 +tax, all i can say is wow!
Unlike most headlight kits out there, this one has a UV clearcoat that supposedly last for a very long time.
The other kits lack this critical thing and stop at the polishing step and call it a day. (IE. Mothers headlight kit) which I used before and can personally say FAILED BIG TIME. As the hazing came back within a few months.
The Procedure: summarized for the forum (poorly), since they give you very good instructions
1. Tape off paint or just remove the light and take off the trim.
2. Apply a "prep" spray which removes old UV clearcoat
3. Wash it off, then sand with the grits (370 / 1000 / 2000)
4. Apply "prep" spray once more to remove any leftovers
5. Polish that baby!
6. Make sure it's bone dry and clean
7. Remove all tape or reinstall the headlight.
8. Apply the clearcoat in single wipes horizontally and overlap slightly with each wipe.
9. Let it dry for 4-6 hours. (no touching!)
IMO: When the clear is first applied to looks very shinny & reflective, but after about an hour the shine dims down and it looks decent.
Ill report back on this thread if it stays the same or ever hazes again. 1 month, then 5 months.
Pic 1: before / after (pass side had water in the lense... PITA to get it out)
Pic 2: After (1 hour after applied)
Pic 3: Before
Pic 4: Polished, no clear coat yet (lights on) pass side.
Pic 5: Clear coat applied (lights on) driver side.
Pic 6: pass side clear coat just applied
ID:	317710   Click image for larger version
ID:	317711   Click image for larger version
ID:	317712   Click image for larger version
ID:	317713   Click image for larger version
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 03-20-2012, 08:17 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Very well done!
This kit was rated the best in Consumer Reports...
Old 03-21-2012, 12:56 PM
aioros aioros is offline
aioros
Mein Auto: 99 528i auto m-sport susp
I've used the 3M kit with excellent results but I agree with Dking078 that it lacks the UV protectant. I will give the Sylvania kit a try.
Thanks for the write up
Old 03-22-2012, 11:18 AM
You can buy the clear-coat separately at Auto Zone.
http://www.meguiarsonline.com/forums...ht-Lens-Sealer
http://bluemagicusa.com/index.php/bl...t_lens_sealer/
http://www.autopia.org/forum/car-det...-question.html
Old 03-22-2012, 04:52 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Jason,
Have you tried the Blu Magic sealant?
Steve
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 03-23-2012, 09:32 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
We should add this to the list ...
- Headlight plastic polishing & refinishing DIYs (1) (2) (3) (4) (5) (6) (7) & replacing just the headlight lens (1) (2) (3) (4) (5) (6) (7)
Old 03-28-2012, 06:53 PM
Dking078's Avatar
Member Supremo
Updated with 2 more cars
The E39 LCI lense was annoying me alot, having one good & one hazed was irritating so i couldn't wait for results on the other 5.
Overall the lense is about 90% oem look-a-like, If you focus on detail from 1 foot you can see minor imperfections, but any further it looks amazing!
The light beam from the xenon before would be "Reflected" on the lense a bit, but after this, it looks near perfect!
The X was the biggest improvement of them all IMO.
E39 pics show the grits, i only took pics of 400 & 1000. (FYI Pass side is still original, driver side is the only one that got redone on e39.)
This is truely one for the list bluebee!
ID:	318959   Click image for larger version
ID:	318960   Click image for larger version
ID:	318961   Click image for larger version
ID:	318962   Click image for larger version
ID:	318964   Click image for larger version
ID:	318965   Click image for larger version
ID:	318966   Click image for larger version
ID:	318967   Click image for larger version
ID:	318969   Click image for larger version
Old 03-28-2012, 07:59 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 140k
So you did this by hand and without an orbital polisher or drill buffer wheel?
Old 03-28-2012, 08:06 PM
Dking078's Avatar
Member Supremo
All by hand. I tried to alternate directions with each grit of sand paper (one grit L > R the next Up > down and so for.)
The clear coat is done by towel and hand (single swipes across the light) In this kit, polishing is a minor part, thus by hand is fine. The clear cost is the big finale. There is also a DIY by sylvania on youtube.
1 Month: All 3 cars still in great condition!
Old 08-25-2012, 07:44 AM
Dking078's Avatar
Member Supremo
5 Months: Still looking great! Pics to follow
Old 03-19-2013, 09:49 PM
Dking078's Avatar
Member Supremo
Update: Well... throw this one out too, it failed.
The X5 was good for 6 months (it saw rain, snow, ice, road debris, etc) and faded. I reapplied using the wipe method, now it's just peeling again.
2003 540i is still good, not as perfect, and there is some fade in clarity, no yellowing, just fade.
1997 540i, pretty much the same, but it was hardly driven.
Next test will be with a real UV clear any MANY layers of clear and take it from there.
Old 03-19-2013, 11:29 PM
bluebee's Avatar
Thanks for the long-term update!
This adds value to our knowledge level!
Thanks.
Old 03-20-2013, 06:18 AM
Fudman's Avatar
Fudman Fudman is online now
You may want to try a clear covering, like Lamin-X. I cringed at the price (~$50) when I bought it but figured I really didn't want to have to sand them again as our headlamps & front end get sandblasted here in New England. I've had mine on for 17 mos and 2 winters so far. Headlamps still look good. No new pitting and no haze.
Old 03-20-2013, 08:45 AM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
$20 for almost a year still is not bad.. Just a little perfection is all needed. Thanks for the update.
Old 03-20-2013, 10:50 AM
retiredat44 retiredat44 is offline
retiredat44
Mein Auto: BMW
Thumbs up
I used the Turtle Wax headlight kit on both a 1993 Camry and 2001 530i BMW, and have enough materials left to do 4 more cars.. the Full kit with everything needed was $10.00 at PepBoys. It would have been almost $15.00 if I had gone to Walmart. It worked great on the cars. I can't see paying more if that kit worked for only $10.00. The only thing I used the kit didn't have was an old towel for final cleanup. Just reseal everything that still has use left in it, for some other day. They give you lots more than you can use.
BMW 2001 530i (E39)
No longer own a BMW, sold it.
(Family cars):
2014.5 Toyota Camry Hybrid
Disabled Veteran:
Old 03-20-2013, 10:54 AM
retiredat44
Mein Auto: BMW
Lightbulb
The sand pads in the kit are like a fine sandpaper on a small square piece of heavy foam. Just hand scrub and wipe is easy.
you change from one pad to the next, to the next.. etc... until you reach the end of the process.
BMW 2001 530i (E39)
(Family cars):
Disabled Veteran:
Old 03-21-2013, 04:14 AM
This job requires an orbital ball. Makes the job 1000x easier.
Those pads are crap.
Old 11-03-2013, 02:44 PM
Dking078's Avatar
Member Supremo
Final Update:
Verdict: Sylvania kit = FAIL.
Here are the 3 results
Older 540i (rarely driven): Held up well, still decent, but the car never moved much.
Gray 2003 540i: covered 5k-ish miles, DECENT, not great, but some fading came back.
2001 X5: Covered well over 15k To hell and back: Exposed to every weather element possible, end result: failed clear coat and yellowing came back.
So the more you drive with the kit, the faster the "UV" protector WILL fail.
Moving on to Opti-lens coating, supposedly the best out there, with Autogeek backing it up, I'll be the judge.
Link to new lens project.
Old 11-04-2013, 06:21 AM
Fudman's Avatar
Too bad about Sylvania. My Lamin-X covers continue to work well at 25 months and counting (20K). I had to replace my headlamp adjusters last week and gave them a thorough inspection. Adhesion of the cover is still good and there is no yellowing. Again, these were put on primarily for the added protection factor against road salt & sand. Never even considered the yellowing issue. But the lens are still clear.
Old 11-04-2013, 08:59 AM
Dking078's Avatar
Member Supremo
Just curious, is it possible to put laminx over a freshly polished (refinished lens), that was already been cleaned with IPA solution? I may try that route next if Opti-lens fails.
Old 11-04-2013, 10:03 AM
Fudman's Avatar
Don't know. I don't know anything about IPA except for the kinds I drink. I refinished my lens with the liquids from a Turtle Kit and about 8 grades of sandpaper between 220 to 2000 grit. I applied the sealer they included so I don't know if it's the Turtle sealer or the Lamin-X that is preventing he yellowing.
Old 11-04-2013, 06:47 PM
retiredat44
Mein Auto: BMW
I need to know the car, parts, brand, the car, the climate, the length of time... brand of product used.... etc... just pass fail doesn't give enough info... I did mine last summer 2013, and took the car to Oregon. I looked at it the other day and it still looks good, but think it's not as clear as when I polished it with the kit, but still it looks good.. I have to look a little more and next time I will take pictures to see if they will help keep a record... not sure if pictures will be good enough... too subjective... I would hope if a product can go a solid year for $10.00 that would be ok. Of course being perfectly clear forever would definitely be the best.. but probably not possible..
BMW 2001 530i (E39)
(Family cars):
Disabled Veteran:
Old 11-05-2013, 04:33 AM
The next time I powerball my lights, and add the UV coat, I'd like to spray it with clear coat.
Anyone decided what works? If it's bad, I can just sand it off, so it doesn't have to be perfect.
Old 11-05-2013, 09:26 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
I was told this is the correct way to keep refinished lenses in shape for a long time. The OEM UV coating is removed when sanding, and the aftermarket UV coating is not permanent. You need to keep it there under the Lamin-X.
If I was lied, I'm BS-ing now.
Old 11-05-2013, 10:41 PM
Anyone use this?
http://www.lamin-x.com/BMW-E39-5-Ser...2000-s/799.htm
