E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
#26
No, it does not, because the car leaning thing is a MYTH. Totally unfounded.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
#27
sag from WEAR.
grow up, man. there is no need for all your bull****!
i said, that if the car leans to the left or to the right, its nothing to do with the drivers position or batteries position, its because suspention on that side is weaker than in other side, and MOSTLY it will show up more than normally, when weight is added on the car! |
#29
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
#30
+E36
![]() but still it will be there, only solution is to get the coilovers and adjusted
#31
It's a myth. How does BMW know if you weigh 110lbs or 300lbs. That would need, different-different springs depending on your weight... If that makes sense.
Your car is what 13-19 years old.... Your springs are clapped out. Plain and simple.
![]() 1995 325i with 120k on clock. All stock, for now. 2002 BMW X5.... Not stock.... At all. |
#32
Huumm...just check with Bentley manual, the ride High measured from center rear arch ( rear fender lips) to the bottom side of rim and found 2cm deviation between left and right .
my old lady has Right driver side anyway...seems I need to check the Coil Spring as mentioned in Bentley....any one know what is the length of unloaded spring, will try to measure it |
#33
more eyereeesh
Yes. It does. Driver position IS the CAUSE. OP drives on right side. Right side SAGS 2cm. You follow? RIGHT side & RIGHT SAG Is that a comma at the end of your SENTENCE? Quote:
![]() Suspension Your sentence composition is getting better.. But, you need to work on your GRAMMAR, twit. weight added on the car? Really? ![]() Quote:
Is that all? ![]() You're giving the rest of the hard working, hard drinking paddy's I know a bad name. Éirinn go brách ![]() Read a BOOK. Quote:
Take the springs from the RIGHT, and put them on the LEFT. Take the springs from the LEFT, and put them on the RIGHT. Drive like normal. In about 2 weeks your 2cm difference will disappear. Cheers!
Hmm..
.. ..Solution? .. I concur.. SOLUTION.
Its normal read the sticky's
#36
Yes.
Its normal for the car to lean. Its cause is from DRIVER WEIGHT. Jeezus.. Does anyone have a picture of the posterior of THEIR RHD E36 from a wrong lane country?? Not pics scoured from the 'net.. WE CAN LOOK AT THEM SIDE BY SIDE in comparison to end this nonsense.
So Ze German, where is the battery located ? I also have a slight lean to the left - maybe previous owner had a fat wife !
Cheap Trick |
#38
this is suspension not the driver what leans the car to one side. especialy for our, hero, bmw-mania, here u go, a pict of my own car, rhd leaning to the left, almoust full tank+ 2 kids on the back, taken aprox 1 y ago. at that point all 4 springs was about 1y old, all front suspention was sorted out from the dealer. are u still thinking, that driver is the problem? ps, the text is all urs, run the spelling check
f..k the fuel economy |
#39
My car has never leaned to either side, because it was not designed to do so.
#40
![]() p.s. like that ur car has straight lines
f..k the fuel economy Last edited by armando325i; 03-23-2012 at 09:11 PM. |
#41
DO IT!!! i dropped mine 3 inches, love it
#43
![]() Holyfck.. you really gave that fcker CPR. ![]() just re-read that drivel.. But, now that we're talking about lean..
#44
And what side is the battery on ?
Cheap Trick |
#45
![]() Open Hood. Open Trunk. Take a guess.
Sorry to revive this old thread but I have owned 3 e36s and every one had at least one broken rear spring when I bought them. One with only 89K miles had both broken. That one was actually not noticable since it sat level. The others sat lower on the side with the broken spring. Not sure if this is a very common problem or if I am just unlucky.
The Bentley manual goes into detail on ride height and the specs it puts forth are the same for both sides. The e36 wasn't designed to lean although I was told that the battery being on the right rear is supposed to partially offset the weight of the driver.
94 318i, 97 528i, 07 335i |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
