E36 (1991 - 1999)
Old 04-06-2012, 01:26 PM
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
Yes, the rears are much harder than the fronts. They are actually quite a pain in the ass! You will need more than an average set of DIY tools. I had to use a section of inch fine pitch threaded rod, an assortment of very thick washers, several very large sockets (used as bearing press/arbors) and a couple of very hard to find nuts to fit the threaded rod.
I tried using a bearing puller set that I got from harbor freight but I ended up breaking the threaded rod that came in the set. (It wasn't a very high quality set, but I was hopeful that it would get the job done.)
I used these links for guidance:
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
Old 04-06-2012, 02:18 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
my driver front is making a tad bit of noise...will replace it soon enough.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 04-06-2012, 03:56 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
So I was under car for a bit and noticed the front left ball joint has very little (ok almost none) rubber left.
However the right looks new...
Will replace that and see if it helps.
Sent from my DROID2 GLOBAL using Bimmer App
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 04-07-2012, 08:56 AM
Landshark 328 Landshark 328 is offline
Mein Auto: 328is
I forgot to mention how I knew which rear wheel bearing was bad. I jacked up the car and removed the wheels. Then I started up the car and very slowly accelerated up to when the noise began. you need someone to tell you which side is making more noise becasue you probably won't be able to tell from inside your car.
EW///
