Keeping Your 3 Series Origami Top in Tip Top Shape - Page 20 - Bimmerfest - BMW Forums
Old 10-27-2017, 10:59 PM
wheelsonthebus wheelsonthebus is offline
Mein Auto: E93
Hi guys, while lubing the join and seal and I saw this. Rusted top cover hinge rusted. Has anyone experienced this.
Cheers
ID:	697633Click image for larger version
Sent from my VIE-L29 using Bimmerfest mobile app
Old 10-28-2017, 07:04 AM
Ratterz Ratterz is offline
Mein Auto: BMW 320D E93
Oooh! I would get some spray penetrating lubricant in and around there then maybe some grease or waxoil to stop further rust and possible seize.
Old 10-28-2017, 07:22 AM
Mein Auto: E93
Yeah thats what I did, but i guess i better replace it. The car has been garage all its life, so beware, this could still happen !
Old 10-28-2017, 11:23 AM
Stevarino's Avatar
Stevarino Stevarino is offline
Mein Auto: 2008 335 / 2014 X-3
I cannot figure out what I am seeing in this picture. Where in the top mechanisim is this located? Thanks.
Current Vehicles:
2017 440i Cv ED Sept 1, 2016 (ED #6)(PCD Oct 24)
2014 X-3 35i (PCD)
2008 E-93 335i Cv (ED #3) (Keeper)
BMW CCA #272524
Old 10-28-2017, 05:59 PM
Mein Auto: E93
It is under the middle roof panel strip on both side.
Old 11-10-2017, 07:33 AM
e93to e93to is offline
Mein Auto: 2011 E93 328i
Should I apply Kroil before lubricating with Wurth? My E93 is 7 years old, and I haven't maintained the top during the ownership.... The top operates well... But it rattles (always has since day 1). And there is a brief squeaking sound before the top latches.
Thanks in advance
2011 328i E93 - N52, Alpine White, Coral Red, ZSP, NAV, STEPTRONIC, Comfort Access, Heated Seats, Heated Steering Wheel, Through Loading. 06/10 build date. All stock. Original owner.
Old 11-10-2017, 12:06 PM
Hi, Nice motor! re Kroil, I would say not necessary as Wurth product claims to have very good penetrative abilities, I am not an expert but planning to do maintenance on my top as you are. Appreciate your experience if/when you do it.
Old 11-10-2017, 12:16 PM
Hey.
Thanks for your input. I've already created a thread to ask about some products - http://www.bimmerfest.com/forums/sho....php?t=1145953
I am going to use Krytox for rubber parts and Wurth for metal joints. I will be doing it tomorrow, but I might push it back a bit because it is freezing in Toronto!
I see you're located in UK. Are those lubricants readily available there?
Old 11-14-2017, 07:01 AM
Went to a motorcycle shop to buy HHS K lubricant. But he only had HHS 2000. He was not familiar with HHS K, so he couldn't explain the difference between the two.
Is it okay to use HHS 2000 on E93 hardtop?
Old 11-19-2017, 07:14 PM
BMWCCA 149159
Mein Auto: 17Ridge/14JGC/ 17Outback
It is the same. Wurth phased this out sometime after Kat and I wrote this section. 2000 is just fine and the other is no longer manufactured.
Hope this helps.
Old 11-19-2017, 10:34 PM
Hope this helps.
Thank you. And thanks for writing that awesome post on lubricating metal hinges. It really helps a lot
Old 11-30-2017, 04:55 PM
BMWCCA 149159
You are most welcome.
e93 top care, hardtop 'vert maintenace, stuck cabrio top
