Old 03-23-2012, 11:41 PM
Zuzax's Avatar
Zuzax Zuzax is offline
Calvinball Professional
Mein Auto: '07 M Roadster
Time for a new battery in the Z4M
Even my trusty CTEK can't keep the charge up anymore, so I rang up the dealership and they wanted $295 for an new battery for my 07 M Roadster.
Auto parts stores are running around $155 for an AGM battery, so I think I will be going aftermarket.
I've gone through several threads including Ron's Batteries one but I still have some questions.
Size - need to verify that the Z4M battery is an H6 (48) and not an H8 (49).
Should I need to do anything maintenance-wise with the vent tube other than just plugging it in to the new battery? Where the heck does that thing vent the acid fumes to anyway?
Any particular brands of aftermarket preferred? I'm leaning towards the Duralast Platinum H6-AGM. It looks suspiciously like the BMW 61 21 7 553 952 that BMW of The Woodlands thinks is worth $295, but with Duralast stickers instead of BMW ones. The Batteries post made it sound like all US brands of AGMs are made by the same two companies anyway.
Any other tricks or gotchas when replacing the battery on a Z4M that is different than replacing the battery on a mere mortal car?
2007 Z4 M Roadster Sepang/Sepang-X/Black, Premium, Nav, BMW Strut Bar, Stubby Antenna, Dice, UUC clutch stop, Star Specs, and the rest joyfully stock.
Old 03-24-2012, 03:50 AM
tonywintn tonywintn is offline
Drivin' the dream
Mein Auto: 2005 BMW X5 & 2007 Z4 si
I just bought a new BMW battery for my 07 si a couple of weeks ago at the Dealer. It was $160. The M version is really a different battery?
Old 03-24-2012, 05:36 AM
wifesauto wifesauto is offline
Mein Auto: sloporsche
the h6 can be had for under 100.00.........auto zone/walmart etc....easy to change on an 05
Old 03-24-2012, 06:52 AM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
The H6 should be the one. Yes- it looks EXACTLY like the battery you will remove. No special stuff on the vent tube(just gasses so it won't be clogged). Just unplug the old tube and attach it to the new battery. I went with the Non AGM version as it was $115 and had the same warranty as the AGM version. I got mine at O'Reilly as did Ron but I understand they may not be carrying that battery any more.
It is amazing how much some dealers charge for a battery. As some have said, prices are vastly different at various dealers so it may pay to check with another one if you want an OEM battery(although I see no advantage to this).
Old 03-24-2012, 09:29 AM
Zuzax's Avatar
So far so good. I've done the swap and now I'm just letting it sit for a bit with the new battery before I try to crank it - let the electronics reboot and all that.
The Duralast Platinum H6-AGM is an identical twin to the BMW battery, at least externally. Specs are slightly different but then $155 + tax is much better than the best price of $275.18 + tax I could find for OEM.
I have full pictures that I will post later, but I must say it was a PITA due to the cramped area getting to the positive terminal. Hooray for hand mirrors.
And once again, one single picture posted by Ron Stygar saved me from being in a world of hurt when removing the positive terminal assembly.
Old 03-24-2012, 01:47 PM
Jax5 Jax5 is offline
Mein Auto: Z4 Coupe 2007
For regular over the counter folks, the BMW dealer in Jacksonville FL (Tom Bush) will charge you 100% over retail for parts. Yes you heard correct, if the MSRP is $10 they will charge you $20. That's double over retail which already has plenty of mark-up.
Max Stealer Level achieved.
Old 03-24-2012, 02:27 PM
Zuzax's Avatar
To benefit battery searchers in the future, a link to my installation photos and incoherent comments is found here.
Old 09-07-2013, 09:09 PM
freshembassy freshembassy is offline
Mein Auto: 07 M Coupe, 00 Boxster S
Awesome post! Saved me some serious $$$ on my '07 M Coupe's battery. Make sure you get the H6-AGM and not the H8-AGM. Also make sure that you get the AGM (better battery internals). Thanks again for this great post! Changing the battery took.. what... maybe 2 minutes to remove the battery, 30 minutes to drive to/from autozone and 2 minutes to put the new one in. $161 as of 9/7/2013.
Old 12-10-2013, 06:38 AM
Master Apex Master Apex is offline
Mein Auto: Z4MC
Is Die Hard Group Size 48 AGM just as good?
http://www.sears.com/diehard-gold-au...2&blockType=G2
Old 12-10-2013, 02:42 PM
rmjames007 rmjames007 is offline
Mein Auto: 2009 135i
I love interstate batteries.
Old 12-10-2013, 10:43 PM
dkl's Avatar
dkl dkl is offline
Mein Auto: E53 X5, E86 Z4MC
Diehard "Gold" is LeadAcid. If you want AGM, you'll need to get their "Advanced Gold" series.
Old 12-11-2013, 07:56 AM
ebruder's Avatar
ebruder ebruder is offline
Mein Auto: '07 Z4MC, Porsche 928S4
I took my 2007 MCoupe to my indy shop yesterday to check out the charging system and battery, as in the last few days I noticed that the engine wasn't springing to life immediately as it always has. And it's cold here (Cleveland) and getting colder.
The charging system was fine, also the draw down test was fine, but the battery was weak @ 9.6 volts under load. I authorized them to pop in a new Bosch battery at a price that was higher than I would have liked, but since I had a $50.00 off promotion from the shop, it was OK.
I trust these guys, and when I asked about whether computer resets were really needed for a battery replacement, I was told that that was absolutely true. They even enter the cold cranking amps of the battery so the correct charge rate is outputted. German over-engineering at its best.
Ah, well, batteries do fail, I have a bum back so no awkward lifting for me, the shop knows what it is doing, and I had $50.00 off coupon. A slight time inconvenience, and not so slight cost, but I won't be stranded.
EB
Old 12-11-2013, 08:28 AM
dkl's Avatar
dkl dkl is offline
Battery registration is only required on cars with the MOST system. Our cars are not MOST. Something sounds fishy if your indy is able to register the battery on your car. For references, see these articles:
http://www.munichmotorsport.com/wordpress/?page_id=164
http://www.motor.com/article.asp?article_ID=1479
FYI...Cranking Amps (CA) or Cold Cranking Amps (CCA) has nothing to do with the battery's capacity. You need to look at the battery's Reserved Charge (RC) rating to determine battery capacity.
Does Bosch make an AGM? AGMs usually have better capacities than regular Lead Acid batteries, which means that you can leave the car sitting longer without needing a recharge.
Old 12-11-2013, 08:50 AM
As DKL said this would be the FIRST time I have heard of a dealer actually being able to "program" the Z4's new battery. The only need for "reprogramming" should be the clock and window auto-up feature. An exception would be if your car went into transport mode.
Old 12-11-2013, 09:04 AM
ebruder's Avatar
Hmmmmm?!
The invoice shows reset of time and one other thing (I don't recall), not anything related to setting computer charge rate.
I hope this is just a matter of the billing/counter/appointment guy not knowing what they did in the shop. Otherwise, my trust is greatly diminished.
Thanks for the above two replies.
EB
Old 12-11-2013, 09:37 AM
Living Dead Living Dead is offline
ZEDHEAD
Mein Auto: 2015 sDrive35is
I just had my battery changed by my local mechanic, it cost only $155 including installation and took a total of 10 minutes. I would have done it myself but nothing would have been saved and it would have taken longer with returning the dead battery.
The only thing I had to do was reset the clock.
Sometimes I find it amusing how posters here think that a BMW is so special that only someone specially trained can do something so basic as change a battery, oil, spark plugs etc. on a BMW.
A good mechanic can work on just about anything. If they can't then they aren't a good mechanic.
“Thou art to me a delicious torment.” Ralph Waldo Emerson
Old 12-11-2013, 02:38 PM
dkl's Avatar
dkl dkl is offline
Your statement is true for the most part. But if you would have gotten a different model, then something as simple as a battery change will required a battery registration with the car's computer or your new battery would go "kaput" in a relatively short time. If you or your mechanic don't have the software or interface to do this, then the dealer would be your only other option.
Old 12-18-2013, 04:20 PM
f1fork f1fork is offline
Mein Auto: 2007 Z4 Coupe
Your dealer sux
Even my trusty CTEK can't keep the charge up anymore, so I rang up the dealership and they wanted $295 for an new battery for my 07 M Roadster. :yikes
Wow - my dealer sourced me a BMW battery for $154 for my 3.0si Coupe. NO reset needed.
Old 02-21-2014, 05:44 PM
coolvt coolvt is offline
Mein Auto: 2007 Z4 3.0si
Guess I'm lost. How can someone get the wrong battery? If it's 12 volts and will fit into the space without terminals hitting anything it should work. As far as reprograming clock and windows. there is a device that takes a 9 volt batter and plugs into the cigarette lighter. This will keep any memories that you might have. The device sells for about $4 and most smart shops use them. Mark
Old 07-13-2014, 03:27 PM
eekflyer eekflyer is offline
Mein Auto: x3 28i xDrive
I just bought a new battery at Advance Auto since my 07 3.0Si was cranking slower than I'd like. I bought it online so I could use coupons and just picked it up (and traded the core). I was told there that I can change the battery but the dealer needs to "reprogram" the battery to keep from overcharging/frying it. Their words, not mine... The guy at AA restated this and said it had to do with the charging rate of the battery controlled by the computer. He showed me a somewhat weathered piece of paper that was taped to their break room fridge. It stated something about BMWs 2006+ needing a battery registration. I bought a non-AGM to replace a non-AGM. About $150 for a Group 47.
On a related note, the battery doesn't fit neatly in the box. The terminals are fine and in place. No problem. It is the right/rear side slider clamp. The bottom clamps are there where one is a screw fastener and the other is a slider (right/rear side). The slider doesn't stay in place well. I need to remedy this, for the battery will move side to side. I bought the car used, and suspect the battery has been moving around in there (probably explaining a klunk from time to time). Anyone else seen this with the battery mount? The battery seems to be the same as in my (former) Z3, but the Z3 had two screw fasteners, IIRC.
I should also add, after having the battery out of the car for over an hour, only the clock and windows need resetting. A/C still works.
Old 07-13-2014, 05:46 PM
As has been said countless times on the boards- NO REGISTRATION NECESSARY on E85/86 Z4's The info you got is incorrect. The clock and windows are the only things you need to do.
Old 07-13-2014, 06:08 PM
I think my point was that there is misinformation out there. Now, my battery box question is another story.
Old 10-17-2014, 03:31 PM
lomax lomax is offline
From Beemers to Bimmers
Mein Auto: 2003 Z4
This seems to be as good a thread as any to ask.
I have a 2003 Z4 2.5 build date 2/03 and am wondering if I disconnect the batter for a short period what am I going to lose.
Will it just be having to reset the radio stations and clock or will the whole thing need to be reprogrammed by the dealer.
It is pretty much a heater/key model so no fancy auto top and rain sensors or any of that foolishness. LOL:
Marc
2003 Land Shark Z4 2.5
Old 10-18-2014, 08:55 AM
Bucko521's Avatar
Bucko521 Bucko521 is offline
Proud Canadian, I'm Sorry
Mein Auto: 06 Z4 3.0i & 01 Z3 2.5(2)
Check out his for any battery information. Hope this helps.
https://docs.google.com/spreadsheet/...qTUlvQUE#gid=0
01 Z3 2.5i Sapphire Black, 01 Z3 2.5i Topaz Blue(SOLD), 06 Z4 3.0i Jet Black
ZSCCA Area Rep and Member - Prairie CruZers
Old 10-18-2014, 08:57 AM
Bucko521's Avatar
Marc
You do NOT need the car 'registered' by the dealer. Now what you may want to ensure is any fault codes related to a weak/dead battery are reset.
You will/may need to reset radio dial stations and reset windows (one-touch feature).
Hope this helps,
