Old 03-24-2012, 02:25 PM
Zuzax's Avatar
Zuzax Zuzax is offline
Calvinball Professional
Mein Auto: '07 M Roadster
Photos: Duralast Platinum H6-AGM Battery into Z4M
As set up in this thread, I didn't want to pay $275 - $295 for an OEM battery. So after a quick trip to AutoZone, I returned with a Duralast Platinum H6-AGM and got started:
One of the hardest parts was getting my hand in there to loosen the Velcro straps. Thankfully those little knobs on each side raise the tray the top folds into. Marginally.
BMW Strip-o-matic fasteners hold the bottom and three massively torqued 10mm nuts hold the top. This is the worlds most securely fastened flimsy battery cover.
Opening the wrong door on the positive terminal. Shut that now and never touch it again.
The correct positive terminal door. Thanks Ron! This level of visibility is impossible when changing the battery in a roadster.
Duralast Platinum H6-AGM left, BMW 61 21 7 553 951 right. Twins except for the stickers.
Duralast Platinum H6-AGM left, BMW 61 21 7 553 951 right. Note that the BMW battery has one of the venting holes plugged. You'll need to remove this and transfer it over to the Duralast. These batteries have vent holes on each side.
The vent plug.
Vent plug installed with vent plug installation tool.
Slightly different specs.
And now to hook up the negative terminal so we can test start it. Note the impressively tall screw for the battery bracket.
Started up like a champ. Reassembly commemorated with one last terribly fuzzy iPhone photo. Now to reprogram the Nav for clock/date and reprogram the auto-up on the windows. It somehow remembered my radio stations.
One extremely happy, unexpected change is that somehow my DICE came back to life with the new battery. I thought I had fried it with my CTEK during a reconditioning cycle, but it works once again, quirky DICE functionality and all.
Also the remote unlock and roof opening range has increased from about three feet to at least 25. I have not tested to determine its max range.
2007 Z4 M Roadster Sepang/Sepang-X/Black, Premium, Nav, BMW Strut Bar, Stubby Antenna, Dice, UUC clutch stop, Star Specs, and the rest joyfully stock.
Old 03-24-2012, 04:50 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
Nice write up! I guess that since I still drive my same OLD Z and the battery in under the hood I won't be able to enjoy the benefits of your instructions. OH wait! The M3 has a buried battery too! Any chance you can make the drive next weekend? It's kinda like the year you were the ring master.
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 03-25-2012, 11:55 AM
Starscream88 Starscream88 is offline
Mein Auto: Imola Red ///M Roadster
Wow they look totally identical!
Imola Red Roadster
Old 03-26-2012, 12:24 AM
Hoops432 Hoops432 is offline
Forever Fast
Mein Auto: '06 M Coupe, '08 K12S
Hahaha.... hilarious!
Thanks heaps for the write-up.
2006 IBlue BMW Z4 MC (OZ spec) - ESS VT1 Supercharger, KKS gated exhaust, TMS camber kit, ST Trophy BBK with CL R6E pads, Ultimate pedals, PerformanceBox, Street Wheels/Tyres: Volk G2s and Potenza, Track Wheels/Tyres: Volk TE37SLs and BFG R1 slicks, Recaro Pole Position (driver), APR GT wing, OEM front brace, Carbon engine cover
Old 01-21-2013, 09:03 PM
senser senser is offline
Mein Auto: 540i/6 E39
Sweet dude. I put one of these Duralast Platinums ( H8-AGM ) in my 540i and it works nicely. I wanna see how long it will hold up though.
Old 01-22-2013, 11:19 AM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
I am sure it will last as long(if not longer) than the OEM battery did.
Old 01-22-2013, 12:18 PM
SD Z4MR's Avatar
SD Z4MR SD Z4MR is online now
(formerly SD 335is)
On realoem.com it looks like this fastener is #8, p/n 07147120304 (plug). Can anyone confirm this? My car didn't have any of these fasteners although I noticed that the holes are there.
- Tom
Old 01-22-2013, 12:53 PM
I sure hope so. The OEM battery had a production date of September 2001 so almost 12 years is awesome. Some research says that AGM batteries don't last as long as traditional lead-acid.
Old 01-23-2013, 06:30 AM
keeton keeton is offline
Mein Auto: '07 3.0si
Originally Posted by senser View Post
...Some research says that AGM batteries don't last as long as traditional lead-acid.
What research is that? The original Miatas used AGM batteries and 10+ years was the norm for those.
What will destroy an AGM battery is a fast charging rate that a wet-cell battery could more easily tolerate.
Old 01-23-2013, 07:08 AM
salameh13 salameh13 is offline
Mein Auto: 325i BMW 06
Battery Replacement
Hi,
My batter died in my 2006 BMW 325i, and I am looking to buy the Duralast Platinum from AutoZone, I remember I called the dealer one time and asked them about battery replacement, and they told me the battery has to be registered at the dealer after you install it, its gonna coast $140 just to do the registration,so if i buy it and install it myself, i will still have to go to the dealer, is this true?
Old 01-23-2013, 10:17 AM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Registration electronically mates the new battery to the car's charging system and can extend the life of the new battery by charging it more intelligently.
http://www.bimmerfest.com/forums/sho...gister+battery
However, registration is not cost effective if you must buy a new battery from the dealer that costs $350 including registration. Or if you buy a $150 Duralast from Autozone and must pay a dealer $140 to register it with your car's ECU.
It is cheaper to just buy the Duralast and replace it when it goes bad in 3 to 5 years. Like we have done for decades.
Old 01-23-2013, 03:13 PM
Originally Posted by salameh13 View Post
Hi,
I would assume an 06 325 is similar to the E85 Z4. If so there is not a registration process so the dealer is pulling your leg. I could be wrong and the E46 forum should be able to confirm, but I think I saw threads there where folks were swapping E46 325i batteries on their own.
Old 01-23-2013, 09:25 PM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
A 2006 325i should be an E90, they do require battery registration. The E46 3-series was the same as the E85/6, not requiring registration.
Old 01-24-2013, 06:35 AM
Ok, I bought a battery Yesterday from Autozone, and I was able to install it myself, and i started the car, it worked fine, the next day, I start the car,it start but with a weired noise, so i turn it off and start it again, the noise is gone, so once i started driving i had the ABS light comes on suddenly, and the radio Led were so weired,it seems they were getting more current than what they should, and also i noticed that the turn signal light, when i turn it on it wont go back to be off by itself ,like it used to be, i had to move the controller back to turn it off, so I parked my car and turn it of again and turn it on , and everything went back to normal like it was before,radio led is normal, turn signal back to normal, the ABS light is gone,so i am wondering if its gonna happen or its gonna be ok.
But I really want to thank every body for their response.
Old 01-24-2013, 08:31 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
Sometimes when a battery supplies marginal voltage, the car's electronics go "crazy" (yea, that's a technical term). Perhaps the battery came with only a partially charge. Did you charge the battery before the first use?
Old 01-24-2013, 08:43 AM
No I didnt, i just bought it and install it.
Old 01-24-2013, 10:09 AM
formerly updmst
Double check the battery's connections are clean. Then charge with one of the "smart" chargers (CTEK, Battery Tender). The battery may recover.
Old 01-24-2013, 10:48 AM
I will double check it once i get home, thank you though so much for your responses.
I have a question i don't know if i should ask it here, I read in one of the forums about resetting the throttle by holding it all the down to the ground for 30 seconds then push the start button, i know the process steps right,but what does it do to my car if i do it?is it gonna be like adding more power when i press the accelerator paddle cause i am not really satisfied with the way it is when i go from the 0
