Old 03-24-2012, 07:17 PM
the540wgn's Avatar
the540wgn the540wgn is offline
Mein Auto: '02 540iT
Plasti Dipped my Trim
Sorry I didnt take any pictures during the process to do a DIY
I blacked out my exterior trim today with plasti dip.
It gave the (originally white) trim a nice matte look that matches with the rest of the car.
Took me quite a while to complete the whole project maybe 4+ hours
Overall I was pleased with how it turned out.
Its in no way perfect because I slacked when masking certain areas...
IMO I would rather do this then buy M style molding. Main reason is for $$ because I paid 16 bucks for two cans of plasti dip and painters tape, and It looks pretty good
My main advice:
Take extra time to mask the areas well.
If you dont, youll prob have white spots, or spend a ton of time cleaning up overspray
I took like two pictures, I'll try to post more tomorrow.
ColdWeather + Summer + Sport -- 20/30 Ceramic Tint -- Euro Armrest -- JL 13tw5-3 Subwoofer -- LED AEs
Old 03-24-2012, 07:49 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Why didn't you take the trim off the car to do it?
No masking or overspray to worry about.
The trim just pops off.
2000 540/6 Slightly tweeked...everywhere
Old 03-24-2012, 07:56 PM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
Originally Posted by jimlev View Post
why didn't you take the trim off the car to do it?
+1
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 03-24-2012, 08:21 PM
the540wgn's Avatar
I was afraid of breaking one of the fasteners that hold the trim in place.
Should I not have been worried about this?
Old 03-24-2012, 08:36 PM
GreenTiger GreenTiger is offline
Mein Auto: 7/98 NonVanos 540iA
I'm considering doing this myself. But will plastidip wear off with the exterior elements? Or is paint better?
Old 03-24-2012, 08:46 PM
the540wgn's Avatar
I have heard good things about its wear resistance, there's a video floating around of some guy pressure washing his p-dip and it not coming off
I went with plasti dip because I can take it off if I decide I don't like it and it was inexpensive to do.
Overall paint will last longer, yes.
Old 03-25-2012, 04:24 AM
Not a problem, I pull mine off every year for cleaning before the yearly concours here in Boston. When you pull off the door molding strips start at one end and move your hands down the strip as you pop the strip off so you are not bending the strip from the end.
The bumper strips are harder, take them off the same way.
Old 03-25-2012, 08:07 AM
the540wgn's Avatar
Dang If I had known it would be that easy...lol
Oh well, I might need to redo some sections. If this is the case, I will definitely just pull off the trim.
Thanks for the tip Jim!
Old 03-25-2012, 12:06 PM
Interesting. I recently painted my exterior trim (spray paint) and it started chipping off right away. Maybe I didn't do a good job. Even though I sanded the trim and applied multiple coats (maybe 5 coats).
Old 03-25-2012, 12:36 PM
Did you use a primer first and put a flex agent in both?
Old 03-25-2012, 01:33 PM
blackandcoke's Avatar
blackandcoke blackandcoke is offline
New York
Mein Auto: 528IA
4hrs it should have come out perfect..I would use a can of clear coat for protection.
Old 03-25-2012, 02:50 PM
RomanEmpire's Avatar
RomanEmpire RomanEmpire is offline
Mein Auto: 2001 BMW 525i 5spd
Just did mine today. As JimLev indicated the trims pop right out (top ones take a bit longer) I did both sides today with a complete removal. Sanded them (Ouch my teeth), primer, paint, and clear coat 3 hr job
Before and After pics
Name:	window trim 1.jpg
ID:	318454   Click image for larger version
Name:	window trim 2.jpg
Old 03-26-2012, 12:03 PM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is online now
Mein Auto: Dinan //M5, Dinan 4.8iS,
What paint did you use? or is it Plasti-Dip?
Any more tip on removing the window trim? such as where to pull first.
Thanks in advance.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 03-26-2012, 12:53 PM
New York
Mein Auto: 528IA
If you do a write up and including tools you need for the job and how long it take would be A+ a lot of BMW owners would be intrested and maybe blue bee can add this to one of his links especially the trim removal part.
Old 03-26-2012, 01:29 PM
Docta Boom Docta Boom is offline
Mein Auto: 540i
@Roman
Look so much better now, good stuff
Old 03-26-2012, 04:06 PM
No primer. That's what I thought the problem was. But is flex agent necessary?
Old 03-26-2012, 04:27 PM
Thanks in advance.
No I didnít use Plasti-Dip. I Sanded them first and primer, I used Flat Black spray paint, crystal clear coat. Start removing the trims from the doorís edge with a small flat head screw driver. The top ones you will need a pair of pliers. Its more or less self explanatory once you do one door
I already took the pictures to do a DIY, however havenít had the time to do a write up. Will write one when I get the chance.
Originally Posted by Docta Boom View Post
@Roman
Thank you and I agree with you looks much better
Old 03-26-2012, 05:17 PM
johnd1976's Avatar
johnd1976 johnd1976 is offline
Mein Auto: 2007 530xi
Is there any way to bring the chrome 1s back 2 life?
Old 03-26-2012, 06:26 PM
No, the way I did it is permanent and will not go anywhere. Plus why would I want it chromed again by looking at the difference
Now concerning the Plasti-Dip if you asking I am the wrong person to answer that as I have not experienced that product
Old 03-26-2012, 06:30 PM
I thought you guys were talking about the plastic trim on the lower doors and around the bumper, not the chrome around the windows.
Old 03-26-2012, 06:42 PM
the540wgn's Avatar
lol yeah johnd1976, who was the question meant for?
I did the plastic trim around the doors and bumpers.
RomanEmpire did his window trim to resemble shadowline
Here are some more pics of mine:
ID:	318666Click image for larger version
Old 03-26-2012, 06:43 PM
Lol now to think of it maybe I may of misunderstood the OP as well
Either or the trims still pop right out
Old 03-26-2012, 09:13 PM
bcbp14's Avatar
bcbp14 bcbp14 is offline
Mein Auto: '87 535is
Night and day RomanEmpire. Looks great esp on black e39s.
Old 03-27-2012, 10:23 AM
If you do a write up and including tools you need for the job and how long it take would be A+ a lot of BMW owners would be intrested and maybe bluebee can add this to one of her links especially the trim removal part.
Corrected
Old 03-27-2012, 10:28 AM
Thank you
Corrected
Wait I am having a "blonde moment" isn't bluebee a dude or you talking about his vehicle?
e39, exterior trim, plasti dip
