E46 (1999 - 2006)
Old 03-25-2012, 07:28 AM
zhpboy zhpboy is offline
Mein Auto: 05 330CIC ZHP
Couple of wet spark plugs!!!
So I changed the spark plugs yestarday as the car just passed the 60k. The DIY costed me loosing a washer-nut from the engine cover and a torx screw from the cabin filter housing unit somewhere in the engine bay (I am very impatience) but saved a lot of $$$.
Anyways, as I was taking out the original BOSCH-BMW plugs, I noticed that few of the tip of the plugs were soaking wet and others had dry tips with white deposit (which I was expecting from all of them). 100% of the plugs were wet around the thread area.
Is that normal? Should I be concerned? BTW, the car has turned to a beast with the NGK 3199s.
Upload
Old 03-25-2012, 07:40 AM
ckleung100 ckleung100 is offline
Mein Auto: '99 323i
No, that is not normal. BMW plugs are not BOSCH. BMW OEM plugs are NGK BKR6EQUP.
When you say soaking wet, was it wet from gasoline, oil or water (coolant)? It could mean the difference between a CCV failure or a head gasket although any of these should mean other symptoms present.
Were you washing the engine before changing the plugs.
Old 03-25-2012, 11:45 AM
johnnygraphic's Avatar
johnnygraphic johnnygraphic is offline
Mein Auto: 330i Performance Package
Please don't take offense, but IF the issue is the Valve Cover Gasket (VCG), I would not suggest that you DIY.
Imola Red 2004 330i ZHP, Sunroof, Cold Weather Pkg, Assist, Navi & Leather. Upgrades: Front & Side Clear Lens, Clutch Stop & CDV Delete. 10.2006-Differential Swap to 3.46! 12.2006 - UUC SSK, DSSR and Tranny Mounts (Red).
Old 03-25-2012, 04:26 PM
firstgen92ext firstgen92ext is offline
Mein Auto: 2001 bmw 330i
I Just bought a 01 330i and did a valve cover gasket job on it. I didnt run in to any problems, and I am NOT a import guru. Ive always worked on chevys.
Old 03-25-2012, 08:46 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
This......
Old 03-26-2012, 09:53 PM
The plugs that I pulled out had BMW BOSCH written on them. I saved one of the plugs and will post pics once I get a chance.
The car had its valve cover gasket replaced less than 1k miles when I took did the 60k miles inspection. The extended warranty took up the tab. I should have mentioned it in my original post but occured to be later.
I suspect that the oil (not gas or water) was leftover from the previous leak?
Upload
Old 03-27-2012, 06:25 AM
Mein Auto: '99 323i
BMW BOSCH may have been stamped on them but they probably weren't meant for your car. The NGKs are the ones that are OEM for e46s so that's probably why you say there is a performance difference with the NGKs.
The car had its valve cover gasket replaced less than 1k miles when I took did the 60k miles inspection. The extended warranty took up the tab. I should have mentioned it in my original post but occurred to be later.
That may explain the oil on the threads but was there oil on the tips of the plugs too? That would indicate a CCV failure among other things.
Old 03-27-2012, 07:19 AM
smolck's Avatar
ROLL TIDE!
I did some research on this. My local salvage yard sells new and used BMW parts. They have BMW branded boxes that contain Bosch spark plugs. Seems BMW interchangeably ran NGK or Bosch in the newer cars (probably around 02-03). This is my observation and isn't anything more than a "best guess" so I could be wrong. But BMW branded Bosch plugs do exist. I have seen them with mine own eyes.
As for them being "wet". It was likely from the previous leak that allowed oil in your spark plug holes. Very common.
Old 03-27-2012, 07:42 AM
Mein Auto: '99 323i
Ya, I don't doubt that BMW Bosch spark plugs exists. I'm sure they do. They also have many, many models of cars and motorcycles so I figure they could have been OEM for one of them. To my knowledge, I haven't seem a BMW oem spec. for a Bosch plug in an e46 though.
