Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 08-19-2013, 08:03 PM
Robin750 Robin750 is online now
Mein Auto: 2013 BMW 750i
No, the E65 does not need load resistors.
Old 08-19-2013, 08:26 PM
BMW745ISliver BMW745ISliver is offline
Mein Auto: 2003 745I
So by installing them ill be fine?
Old 08-19-2013, 08:31 PM
Electrically, yes.
Old 08-20-2013, 10:44 AM
So i wont have a light come on the dash lol? So what about the light bulb that actually lets us see at night?any suggestions
Old 08-20-2013, 11:14 AM
It is a parking lamp, not the low beam. On newer models, the angel eyes are monitored because they are the DRLs.
Old 09-03-2013, 07:09 PM
eibbed eibbed is offline
Mein Auto: bmw 760li
I have an 06 760li and I'm wanting to use the angel eyes as drl's like alot of the new BMW's. Is it possible to use the newer BMW bulbs to replace mine or do the newer cars not use bulbs. Basically I'd like something as bright and white during the day as the new cars. Any suggestions ?
Old 09-05-2013, 12:30 PM
samadkins29's Avatar
samadkins29 samadkins29 is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i
You will need to get them programmed to be able to use them as DRL's.
Old 09-05-2013, 06:03 PM
Ya I figured I could get them programmed up to use as drl's or just turn them on when I get into the car but I need to know which bulbs to buy first.
Old 09-21-2013, 11:12 AM
4Bimmers 4Bimmers is offline
Mein Auto: X5d,750Li,1200RT&C
Ok I finally am getting the left angel eye fixed. Got a set of 12W BMWLED and the kit includes what looks like 2 heat sinks per side and bulbs that are set in a fancy looking aluminum ridged housing.
So there are two sinks with wire going out to bulb. Then there is a pigtail with small and large connector.
Where do these get hooked up?
May let an independent do it as bumper needs to be dropped on the 750 -06. And he can do some service at the same time. And replace other bulbs.
The high beam flash on my car is the only function for the inner light. May be the drl as well but not set on mine. What bulb is it as it seems so dull, I would like to switch it to a brighter bulb at the same time.
Have a great day enjoying your ultimates
4Bimmers and 2Beemers
Old 09-22-2013, 09:03 AM
@4bimmers, these kits should be plug and play. When you take your old angel eyes out, the connectors will go to the replacement ones. Use the guide provide on the first page to figure out which bulb your high beams take.
Old 09-29-2013, 10:03 AM
E92-Lighting's Avatar
Mein Auto: 335i
angel eyes for all E65 E65 up to year 2008 are 100% fully plug and play, but some angel eyes will require an extra resistor/ballast.
BMW ACCESSORIES and PARTS
Old 11-04-2013, 06:30 PM
jkess114 jkess114 is offline
Mein Auto: Motorcycle
Does anyone have a comparison of all the different bulbs for Angel Eyes? I have an '06 e65 and one of the angel eyes has gone out. I would like to replace both sides with LED's but I don't want to get the brightest LED's that I've seen. I think there are some that are so bright they won't look good on my car. So, where can I see an intensity chart for these LED options?
Thanks folks.
j
Old 11-20-2013, 09:38 AM
DIYmad DIYmad is offline
Mein Auto: 730D Limo
.... and. Also, be careful with front lamp washer jets. It is quite easy to break them while moving the head lamps forward. Better to unscrew the jets and push them back-down. Then push the head lamp forward. Anyway, the designer of these front lamps should be hang by his balls and kicked in his as..... Same about air filter replacement .... another idiotic design by BMW. Cheers
Old 11-23-2013, 04:38 PM
datpoet datpoet is offline
blessed
Mein Auto: 2003 BMW 745li
help!!!!!!!!!!
I am a car buff but I have been driving caddys and am a fish out of water when it comes to bimmers. Got a 03 745li if I can get it back from my wife I need some new bulbs. angel eyes aren't lighting up on either side what bulbs do I need on a $50 budget. thanx gentlemen
Old 11-23-2013, 04:51 PM
Mein Auto: 335i
please PM us.
Old 11-26-2013, 08:32 AM
wwrbd9 wwrbd9 is offline
Mein Auto: 2002 BMW 745I
Hey everyone just bought my self my first BMW. Its a 2002 BMW 745i. I would like information on the best angel eyes to buy. I have been reading and I think there are bulbs I can buy to replace the existing angel eye bulbs? Also is this a hard task to do? Also would be interested in a full led package for the entire interior any help will be greatly appreciated.
Old 12-05-2013, 11:41 AM
Mein Auto: 335i
PM's replied back
Old 12-08-2013, 05:35 PM
Nitro7 Nitro7 is offline
Mein Auto: 745LI
Drl
Hi everyone been doing alot of reading on this site. Trying to find an answer. Is the high beam bulb the same bulb as the drl bulb I know it's an H7 type. Also if I switch it to an led bulb do I need load resistors. thanks for any help
Old 12-09-2013, 02:18 AM
blessed
.yes the high beams h7 bulb normally I would tell you no you don't need a resistor on a BMW I'm not quite sure depends on what why don't you get if you get lower than a 35 watt or 55 what you may need it
God can do all you can't do!!
Old 12-09-2013, 10:53 AM
Mein Auto: 745LI
So what is the drl bulb
Old 12-09-2013, 12:07 PM
blessed
D2s
Old 12-09-2013, 04:11 PM
D2s
I dont think thats correct? Arnt the DRL's in our car using the high beam side (H7 bulb type)? I mean, what would the be the point of switching them to LED unless they were being used as DRL's.
Old 12-10-2013, 07:35 PM
Mein Auto: 745LI
Yes that's what I am doing. I just want an updated look.
Old 12-11-2013, 07:16 AM
blessed
yes you're correct sorry about that replied at 2 o'clock in the morning why was still sleeping shouldn't do that too often I believe fog lights are H 3's not h7
Old 12-20-2013, 09:49 AM
Mein Auto: 335i
D2s
these are your HID low beams, it can be D2S or D1S, the newer models comes with D1S
HTML code is Off
