E36 (1991 - 1999)
Old 04-19-2012, 03:58 PM
Jon Shafer's Avatar
Bimmerfest Founder
Mein Auto: E92 M3 Cp
Angry Arrrrrrr! Ignition Tumbler Failure
Old 04-19-2012, 04:00 PM
Eight Thirty Eight Thirty is offline
Hellawut??
Mein Auto: who knows?
Its not too bad of a fix.
should be up and running in no time.
-Franklyn
Old 04-19-2012, 04:07 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
What kind of failure? They can misbehave in a couple of ways. Either way, it's a pretty easy fix, but will likely require a new one to be shipped from the Motherland.
1998 BMW 328is
1966 Pontiac GTO
Old 04-19-2012, 04:17 PM
Jon Shafer's Avatar
Bimmerfest Founder
Well, I went to drive home, and when I turned the key, that starter solenoid didn't engage, and there was no resistance to turning the key. Fortunately, I was parked close enough to the dealership that a Tech was able to walk over and take the bits apart and at least get the car started (so I wouldn't need a tow .1 miles). He says that I should replace the whole kit and kaboodle...
So, what parts are needed. There's the coded driveaway protection component too, right?
Old 04-19-2012, 04:25 PM
ZeGerman's Avatar
Warm Leatherette
Although it's a somewhat painful video to watch, it is helpful:
Most likely you'll just have to order a new tumbler from Germany.
1998 BMW 328is
1966 Pontiac GTO
Old 04-19-2012, 04:44 PM
r33p04s's Avatar
r33p04s r33p04s is offline
Mein Auto: E36/4/5
Ugh BMW why!!!!
Mine will spin free if I don't push the key that last fraction of a mm... I'm just waiting for the day it doesn't catch -_-
Old 04-19-2012, 04:45 PM
ZeGerman's Avatar
Warm Leatherette
^Better order your tumbler now.
1998 BMW 328is
1966 Pontiac GTO
Old 04-19-2012, 06:23 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Jon your avatar is rockin!
I guess you did that on purpose. Good luck with the tumbler.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 04-19-2012, 09:30 PM
r33p04s's Avatar
Mein Auto: E36/4/5
When does the parts ordering stop!!!!
Old 04-19-2012, 10:02 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Jon, make sure it's the tumbler before ordering. The lack of resistance to turning makes me believe it's not the tumbler, but instead it's the link between the tumbler and the ignition switch. You can't order just the link, you have to buy the entire column lock assembly. They're about $130-$150, and they're a bit of a pain to replace, but do-able at home.
The EWS coding ring fits around the tumbler. You reuse it. Pelican's DIY for the Tilt Wheel retrofit has the DIY on removing and replacing the column lock assembly within the article. Just ignore the column removal and use the info on removing the security bolts, etc.
http://www.pelicanparts.com/bmw/tech...t/E36-Tilt.htm
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 04-19-2012, 10:35 PM
Leusent Leusent is offline
Mein Auto: 328is
I've read up on this a little. Replacement is easy, just pop out the old tumbler and pop in the new one. Its only /really/ difficult if the old tumbler is so broken you can't turn it to pull it out. Pulling out the old tumbler requires a bent paperclip in the small hole in the ignition.... or something like that.
Craig
Winter: 1997 DOHC I-6 2.8L 5Spd BMW 328is (2-Door)
Summer: 1992 DOHC I-4 2.0L 5Spd Toyota MR-2 Turbo (2-Seat)
Summer: 1983/1984/2007 Honda CB550SC/VF500F/CBR600RR (2-Wheel)
Old 04-19-2012, 10:45 PM
Jon Shafer's Avatar
Bimmerfest Founder
My avatar is actually the one I made especially for the Bimmerfest 2004 event. I look a little older now..
It just seemed apropos to bring it back with Bimmerfest just a month away.
Thanks for all of the great info in the follow-up posts!
