E36 (1991 - 1999)
Old 03-28-2012, 04:03 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
It will be a guessing game regardless.. the only difference is they take an educated guess at the issue.
the car looks to be in good shape, just needs some tlc, good luck with it
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 03-28-2012, 08:06 PM
luckeedog luckeedog is offline
Mein Auto: E21,E36
Have you checked your fuel pressure regulator? If it goes bad fuel can pass through the valve and actually be sucked into the intake manifold through the vacuum hose going to it. Pull the vacuum line off the regulator and see if there is fuel present, there shouldn't be.
Old 03-28-2012, 08:16 PM
rampage601 rampage601 is offline
RAMPAGE
Send a message via Yahoo to rampage601
Mein Auto: 2001 330xi 5spd
thank you so much that sounds easy enough i think someone has told me that once before
im gonna make a list of everything and see how much i can get done tomorrow
Old 03-29-2012, 04:04 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
Originally Posted by rampage601 View Post
but im still wondering if its throwing the lambda code could it just be as simple as an egr valve or something?
and if i take it to a shop and let them do diagnostics will their test be able to pull exactly what it is
or is it still a guessing game regardless...
no egr valves on obd1 bmw's...
Originally Posted by armando325i View Post
of course, real mechanich will know right away, and they will have all the tools to get all tests done
just like a doctor, a technician will be requiring additional tests to check the systems are operational.
as for the descriptions, it sounds as if you are not getting spark to the business end of the plug that is *not* getting fouled. the others are running super rich, as evident by the heavy carbon described.
i believe that i had mentioned the fpr, which is definately a possibility. check the vacuum line to it. it should be dry. if there is any fuel in the nipple, then you need an fpr.
and change the oil, when done...
df
Old 03-29-2012, 04:10 AM
RAMPAGE
Yes sir
I was so rather to check it I almost did it last night
But the shop light was... Acting stupid.
So today as soon as I get my check license reinstated and home I will start on this list.. And change the oil when done
Old 03-29-2012, 09:55 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
hold on armando. may as well check everything first. Also you're using some lingo that I've never heard of. lambda code is O2 sensors here in the states. and productivity would be called a fuel trim test. Rampage, i know on OBDII cars you can check the fuel trim with a handheld reader. i dont know about OBDI cars such as yours. Can any of the older guys (DF, ZeGerman, Horn, any of the Chads) comment?
rampage you could take it to an independent BMW specialist for a diagnosis but it could be hit or miss. and thats assuming you have the money. we know you have spark. lets try and make sure you're running on all cyl first by checking off fuel and air.
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 03-29-2012, 01:09 PM
the best way to check for proper spark is to use a spark tester. it replicates the conditions in which the coil will experience when trying to spark in the combustion chamber.
simply holding a spark plug against a block/head @ atmospheric pressure will do nothing of this sort.
you have to look at spark as being a little lazy. it wants the least resistance to ground. if it finds another way other than through the sombustion chamber, then hc will be off the charts and will run rough.
and also not fould the plug with carbon, but rather wash it very clean with fuel.
hope this clarifies some things.
as for checking the o2, the best thing is to use a power graphing meter so you can see the signal. expensive, yes, but soooo much more accurate than a dvom. even a fluke88, which is quite pricey.
ya wanna play, ya gotta pay. and with the level of "diy'ing" going up as cars have become more sophisticated, specialty tools are going to be the norm.
of course this is also why some car clubs have pooled their resources and purchased big ticket items for use with their members.
just something to think about,,,,
df
Old 03-29-2012, 04:55 PM
RAMPAGE
I called around to a couple places BMW: 225/hour
The other guys: 65-150/hour
The most highly recommended charged 75..
I'm nervous about going to a shop!
Old 03-30-2012, 05:49 AM
DinanM3e36's Avatar
DinanM3e36 DinanM3e36 is offline
WayTooFastWhitey
Mein Auto: Dinan BMW M3 e36
Wow 225$ hour!!!! 100$ here in Tx.
Stealerships!!!
Old 03-30-2012, 06:29 AM
RAMPAGE
Oh my god I wish they would charge me that!! I might actually take it to them then
Old 03-30-2012, 08:49 AM
veteran011's Avatar
Mein Auto: 97 328is
going to a dealer is usually not worth the extra money. if you can find a reputable indy mechanic (preferably one who specializes in BMWs) then he should be fine. Just be prepared for a long list of expensive parts. You may get lucky and it may be one cheap sensor or a few new injectors or something but i wouldnt bet on that.
so you've given up on trying to self-diagnose?
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 03-30-2012, 08:55 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Originally Posted by veteran011 View Post
going to a dealer is usually not worth it at all as they tend to not be overtly familliar with older model cars unlike a reputable indy mechanic that deals with (usually) older cars on a regular basis. Just be prepared for a long list of expensive parts. You may get lucky and it may be one cheap sensor or a few new injectors or something but i wouldnt bet on that.
ftfy.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-30-2012, 09:23 AM
RAMPAGE
Yep
Too much time I don't have at the minute
I work at a law firm and we've had a bunch of new cases walk in
Plus I can't keep driving it I go too many places I'm puttin alot of stress on it so I need to just get it fixed and have someone take me to work
Old 04-20-2012, 06:04 AM
RAMPAGE
Well the shop hasn't found anything
The codes aren't pointing them to any answers
They don't even know if it's electrical or mechanical or both
I'm stumped on what I should do next
I don't know how far I should take this
HELP!
fuel / air mixutre, fuel system, maf sensor, rich, suspension
